Maintenance comment / question
/ Maintenance comment / question #1
woodlandfarms
Super Member
Los Angeles / SW Washington
PowerTrac 1850, Kubota RTV x900
Doesn't it seem like the oil filters get changed rather quickly in the PT's. I mean, I am replacing my Hydraulic filter every 50 hours. Terry says Engine at 100 and Fuel at 500.
On a car, 50 hours @ 50 mph is 2500 miles. I guess that is old school filter changing times...
But my engine is at 100 hours (with oil change) although the engine manual says 500 hours in dirty conditions. I am using synth so I am thinking 250 hours on my engine change. It is weird how black the oil gets immediatly, but I guess it is a diesel.
Fuel is at 1000 hours according to the Deutz manual.
So what I am getting at is there is a major discrepency between Deutz and PT. I do not mind being cautious, but there is cautious and then there is wasteful.
Also, what is the proper time to change out Hydaulic oil (not the filter, the oil).
Looking forward to some insight on this.
edit
So, I just saw some fine print in the Deutz Manual. "maintenance in chart is maximum values - please follow operating instructions of equipment manufacturer". Now here is a legal weirdness. Wouldn't PT be obligated to suggest maintenance in writing? They are all wound up about no photos at their factory for "legal reasons" it seems kinda stupid not to document maintenance items for warranty purposes.
/ Maintenance comment / question #2
We change the oil and filter in our car every 2500 to 3000 miles, so its not that different changing the hydraulic filter that often.
But now cars are saying 5K and some are saying 10 or more. Studies are showing that oil is good for quite a bit longer than the oil companies wanted us to know. I know it is a lot about precision of manufacture, and there is a difference between diesel and gas, but this is hydraulic...
I mean in the grand scheme of things I will continue to do it until someone says change, but
/ Maintenance comment / question #4
Dear Carl,
You raise a number of issues. Yes, 50 hours is the equivalent of 2500 miles @ 50, but think of the difference in exposure to water, dust, and just plain grit. You want to keep an eye on the oil behaviour so that you know when you are developing excess blow by. Different diesel are more or less prone to blow by. The old navistar 7.3l diesels have a lot of blow by, but they seem to run forever, so blackness isn't necessarily evil, since a little bit of carbon black will color a lot of oil. If you have a lot of black oil immediately after an engine oil change, you may have an excess of sludge on the bottom of your oil pan that is overwhelming your oil's detergent capacity. MY PT is too new to have any idea of how these engine run for black oil. The old ('80s vintage) Deutz's got pretty black, but emission standards have tightened up a lot since then.
Deutz's legalese is pretty straight forward; you should change the oil filter at least as frequently as they suggest, but more frequently if the equipment manufacturer, e.g. PT, suggests it. This is deferring to the knowledge of the manufacturer about the true operating environment. Again, dust, and water are really tough on oils. Your PT is out in the wet, salty air of the PNW, and probably could use a relatively frequent oil change.
Buried in my pickup manual is the required maintence of re-greasing the U-joints daily if operated in mud or water. I don't know a 4WD enthusiast who actually does it. Then again, the major threat to most of their trucks isn't wearing out. :)
I guess that what I am suggesting is that the PT are used under rather harsh conditions of dust, grit, and water, all of whom eat into equipment lifetimes. Synthetic oil doesn't help much with sand, but filters do, and you want to change the filter before it goes into bypass mode. Could you go longer? Probably, but you would want to monitor oil quality, and the oil filter pressure differential at a minimum. If you go longer, you might want to consider adding a second engine oil cooler, or upgrading to the ag oil cooler that Mike OConnor mentioned awhile ago to help keep the engine oil cool, and therefore unfried.
In a prior post, I mentioned that for fun, I let my 100 hour filter drain, and discovered lots of fine metal particles in the oil coming out. I would much rather have the filter changed often, and the particles out of the system.
If you are really losing sleep over it, have some oil analyzed. My bet would be that the oil itself is in OK viscosity shape, with some acidity, but you will have lots of wear particles caused by dirt, which are probably giving the detergent a work out. The same is probably true for your hydraulic oil. (Cue Jaws music, and the rereading of the posts on why you might, or might not, want a detergent oil in your hydraulic fluid.)
In the case of hydraulic fluid, you would probably want to change the hydraulic oil when you start to lose some of the additive chemistry, since loss of detergent chemistry isn't quite the issue it is for an engine. However since your hydraulic filter is an intake filter, if your hydraulic filter ever clogs, it would collapse, sending who knows what kinds of debris into your drive pump, which would more less wipe the drive pump out. Personally, I'd rather change a few too many filters, rather than deal with that certainty. But again, a differential pressure gauge would let you know when it is clogging up-be sure to read it at WOT cold for worst case.
I can see it now, a computerized dashboard with remote pressure sensors, warning lights and alarms to let you know when the various filters are nearing their change limits. You could probably do it with three differential pressue transducers and a NEMA4X triple pressure guage, with programmable alarms to let you know when to change various filters and oils. Perhaps you have a buddy over in FX that could rig you up a waterproof touch screen version? Maybe redo the paint job? Perhaps add a flame thrower for the really tough blackberries? Or.... :)
All the best,
Peter
/ Maintenance comment / question #5
Yes, but this is for high precision automobiles that leak very little gunk into the oil, and are driven out on the wide open, clean, interstate.
Water, dirt, dust and stop and go, all cut into that high mileage oil change interval, and we have all four.
Other factors also trigger earlier oil changes, e.g. 5% Biodiesel alone cuts the oil change interval in half for the new Navistar diesels.
Basically, I think off road equipment is very hard on oil for dust and dirt reasons alone.
All the best,
Peter
/ Maintenance comment / question #6
There is an additional issue with the hydraulic filter mounted on the supply side. A dirty filter will reduce flow and can result in significant negative pressure (vacuum) on the intake side of the charge pump. If the charge pump does not receive adequate oil supply cavitation in the pump can occur with resulting damage. My opinion is that the potential for cavitation with a filter mounted on the intake side is the reason for the very frequent change interval specified by PT.
/ Maintenance comment / question #7
I agree that oil lasts longer than listed, but still do the changes at my 2500-3000 mile intervals. Why? Because we'v ealways done it that way! :D
I do have a 1985 lawnmower that has never had an oil change. It takes about 3-4 tablespoons of oil each spring. Still starts on the first pull each and every time.
/ Maintenance comment / question #8
edit
This guy seems knowledgeable.
Get the hydraulic information you need!
/ Maintenance comment / question #9
Hmm. This is the same guy that recommends taking your suctiion strainer out and throwing it away. I would be very careful about heeding his advice. I would like to find out how he knows more than almost every major manufacturers engineering department.
Carl, you want to change your hydraulic oil at least yearly for a variety of reasons, especially if you have an open system which I believe the PT has. A closed system is completely sealed, no air enters, no breathers. Basically only used on hydraulic systems with only motors and double acting cylinders that have a low volume as compared to the reservoir tank. An open system has a breather letting outside air into the tank to take the place of oil going into your cylinders. This outside air contaminates your oil with fine airborne particles. One thing you could do is to get a very good breather and keep them clean. If you went this route, I would get 2 and rotate them and clean them at your convenience. There is also condensation that forms in your tank from the heating and cooling cycles of your oil. The condensation is pulled into the tank with the air through the breather. With how fragile the hydraulic systems seem on these PT's, it seems like changing the fluid and filters would be cheap insurance to me. 50 hours seems like an extremely short interval to me, but I don't have one so I don't know. I guess if that's what PT recommends and I used the machine a lot, I would find somewhere and buy a case of them at a discount.
/ Maintenance comment / question #10
Either you or Casey need to go back to school on hydraulics. What he is actually saying is that if your tank is clean, you really don't need an input filter, but everyone knows, it is sometimes difficult to keep water and other contaminants out. Power Tracs hydraulic driven machines like WOODLANDFARMS and I and a bunch of others own , use a combination closed loop and open loop system. The drive system is closed loop system with a 10 micron filter on the input to the charge pump on the variable speed hydraulic pump, and is the only filter in the hydraulic system , the PTO and the steering uses gear pumps , all three pumps sharing a common reservoir. All the filtering for the complete system is the fluid going through the charge pump, which is a makeup pump, IE, making up the difference in the fluid lost through the drive motors via the case drains, and the case drains on the VSP pump..
Replace 20 gal hydraulic oil yearly, you got to be kidding, although it would be good for your business. Regular motor oil, at $3.00, would cost us $240.00 If you uses synthetic oils, at $6.00 a quart, the cost would be $480.00
On the subject of input filters, I think that I agree with him on the damage to the pump caused by suction restrictions caused by clogged up filters. Personally, I think each circuit should have it's own filter with alarms to indicate replacement. I think I would depend on an oil test to determine when to replace oil. The external filter units would also be a good idea on a weekly basis. Good tank filters are a must. Clean fluid with the right chemistry is the only way to get the longevity that we paid for. I don't know how long you have been in the hydraulic business, but common sense with a little knowledge goes a long way. By the way, do you own, and use any piece of hydraulic equipment? Do you actually go out to someones broke down hydraulic machine and diagnose the problem and fix it? Are you a salesman or a hydraulic technician/engineer?
/ Maintenance comment / question #11
Bob has hit the nail on the head regarding the 50 hour intervals specified for the hydraulic filter.
Diesel fuel filters are frequently changed when there is no need. Racor and other manufacturer's offer vacuum gauges to indicate when the filter needs changing. I installed a generic vacuum gauge on my diesel engined boat, along with a fresh filter. I never changed the filter again.
/ Maintenance comment / question #12
Hmm, no need for me to post my resume here. I don't need to justify my schooling or experience to anyone. I guess I don't know anything about this stuff. Just ask all the people here that I have helped. There's no need to get personal or attack anyone about this stuff. I know exactly what Casey said about a suction strainer. Sure, if a tank is clean, you don't need one. Now show me a tank out in the real world that is clean enough to not need a suction strainer.
Almost every major equipment manufacturer I can think of in my experience recommends changing out hydraulic oil by hours or every year, whichever comes first.
/ Maintenance comment / question #13
Hours or time is a great way to ensure that the oil chemistry is not depleted. Analyzing oil will enable one to do a better service job, by;
a) Ensuring that the oil is still on spec
b) Detecting failures in the machinery via particle or elemental analysis.
Since it is hard for most people to stomach the cost of regular oil analysis, most manufacturers and users just go by miles/hours. Is it optimal? Of course not. Is it a sensible cost/benefit result? For most users, yes. For heavy equipment operators, people with large oil usages, analysis pays for itself pretty quickly. So, my takeaway is that it depends.
If you analyze the oil every XX hours at $30 a pop it adds up. Whether it adds up to more than the oil changes.... I would suggest that it depends on usage, part failures, Murphy.
Is there even a recommended service interval on the PT hydraulic oil? My manual just says change it when discolored or contaminated, which are pretty gross indicators of oil depletion.
Keep up the great advice WCH. We certainly benefit. Can you suggest particular vents? The vent on my tank is a multi-layer foam. One problem that the PTs have in general, is that there is an obstruction issue with the seat being very close to the tank lid, so that many higher profile water/low micron caps don't fit.
WCH: I'm with you on the cleanliness of tanks in the real world. Perhaps on a medical device line in a clean room you could get away without one, but why take the chance? Anywhere else, forget.
I am always impressed with the ability of users to screw up. Like the technician that used a brass regulator on an HCl gas line on Firday at a semiconductor plant, and went home for the weekend. By Saturday night, it had eaten its way through the regulator. By Sunday morning, it had dissolved in the ultra clean water. By Monday morning, every gas line, every piece of equipment that used water was corroded out. The entire plant was shut down for six months while it was rebuilt. Frankly, I'm impressed that it only took six months.
I think that the internet has a tendency to allow people with statistically uncommon points of view to air them. For neophytes like me, the problem is sorting the wheat from the chaff.
J.J. I think that we all agree that the hydraulic oil on the PT could be better handled; you and others have made useful modifications, via additional filters and external filtering that I am sure improve the quality of your oil. Just because a service is expensive, doesn't mean that you shouldn't do it. I used to drive a car that the clutch replacement required pulling the engine. Sure, the clutch was only $65, but the labor... Like with oil, you can change the clutch on a mileage basis, or you can change it when it is showing signs of failure. In the case of hydraulic oil, signs of failure might be rather pricey, as it is likely to be system wide wear due to poor oil.
I think the bottom line is "yous paysa your money, and yous takesa your choice." What one person deems prudent might seem like overkill to another, and vice versa. Just because I had one car that I drove 200000 miles on one clutch doesn't mean that I think that ought to have been the manufacturers recommended service interval. I just thought that the downside to changing a clutch too late-worn thrust bearing- was minimal, and I was willing to wait until a problem showed up. But that is just my opinion. Oh, and I am sure that I got lucky. The prior owner only made it 70,000 miles on the first clutch.
All the best,
Peter
/ Maintenance comment / question #14
Those questions were simple questions, and I was hoping you would answer at least some of them. I don't want your resume. If you have been working with hydraulics for 20 or 30 years, that would tell me something. If you went to an engineering school, that would be a big plus. If you learned it on your own, then I commend you . I think people in general would like to know those things. I wasn't trying to attack you or offend you in any way. You probably have helped many people here and other places, I have learned a thing or two from you. I don't live with hydraulics every day, nor do I want to. I am just an old timer, learning more as time goes by. If you have the knowledge, put it out, but don't assume that everybody else is wrong. There are some smart people on here.
/ Maintenance comment / question #15
I am going to make a rough guess that only about 10 % of the people that own tractors or anything using hydraulic fluids change out and flush their systems. How long does the ATF stay in the automobile before being changed. Some never. I have heard it said that the fluid never wears out, but the additives do, and the rest get contaminated in some way or another. So let us use some common sense here. Where do the contaminants come from. Wear and tear on moving metal parts, rubber breaking down, water getting in the system through condensation, overheating. Return line filtering would not let things from that circuit get in the tank., therefore a clean tank, and assuming that we have a good tank breather cap. I believe in suction filters, that is what the PT uses for total filtering, but if it clogs up and starves that $1500.00 VSP pump. You just ruined that day for sure. So what do you do about it. Get a filter with a change indicator on it. My PT is an early 90's model, and has been working good so far. The pumps that had to be changed, were the ones not directly filtered. Rules are rules, and you know we all follow rules. Not.
/ Maintenance comment / question #16
Hydraulic filters for the PT-425 are not too expensive, if you don't order from Tazewell. Like a lot of owners, I use a Wix 51551, also sold as a Napa 1551. I picked one up at the Napa store today. It was $11 and change, including 9% tax. I can get them a lot cheaper with a $50 minimum order from Filter1, when I remember to order in time. :eek:
Cheap insurance, IMHO.
/ Maintenance comment / question #17
The problem is, most of us do not put that many hours a year on our machines. An annual oil change would cost me $120.00 minimum plus I would have to dispose of 10 gallons of oil. I look at it and it is nice an clean. I add a quart to it every 50 hours when I change my hydraulic filter. I think, as long as I keep the connectors clean, the filter changed and the filler area clean, I should be good for a decade or more.
/ Maintenance comment / question #18
Oils are the most misunderstood part of any machine. You can't see it wear out so you still think it's okay. Now if you don't put many hours on a machine, it may be okay to let the fluid go a couple or three years. But a decade? Now you're talking a crap shoot. Sure, I know of machines that used the same hydraulic oil and filter for a decade and had no issues. But the law of averages were not in their favor. I used to know women that looked nice and clean too. But, you wouldn't want to touch them.
Okay, my experience and schooling. 2 year electronics degree, 22 years as a forklift with my specialty in electro-mechanical hydraulic systems. I have at least 15 one week schools at factory training centers. I won the Top Gun award at the school for the most technologically advanced forklift made. I even scored higher than the factory rep I was supposed to call for technical help. About 6 years as a field service foreman, a couple years as a service manager for a forklift dealership and 2 years as a maintenance manager for a large warehouse. I've owned my own hose and hydraulic shop part time for the last 8 years and fulltime for the past 20 months. I am the premiere shop in the county, bar none. My shop is a Weatherhead Affiliate Distributor and a sub-dealer for Cleveland Brothers Caterpillar. When the big boys around here have a problem, they call me. I have yet to have a cylinder that I worked on come back with a problem. When my competition screws something up, it always ends up in my shop and that's where the problems end. When the crane for the largest construction company in NEPA had a hydraulic problem, they called me to troubleshoot it and I nailed it within a half hour. My customers will drive past at least 5 other shops to come to mine and that is not an exaggeration, that is fact. I usually get the tractors in my shop that the local dealers couldn't diagnose, hydraulically speaking. I haven't had one in my shop yet that I couldn't diagnose rather quickly. So I would guess that I am qualified to answer the questions that I do answer. No, I am not always right and I do openly admit when I am wrong. Much of what is discussed here are opinions and many times, there is not a correct one, but some more correct than others. When I do anything, I try to make it as if I was never there, like the machine never needed a repair in the first place. That to me is the ultimate compliment a mechanic can be given, when a customer tells me that it runs like or better than it came from the factory.
To me, someone that has a degree doesn't impress me. I have proven more engineers wrong in my career than I can count. I have also known some great ones. You can send them to school, but you can't make them think.
/ Maintenance comment / question #19
aint that the truth, no matter what the profession or the school. some people can test well, have a 4.0 GPA but cant "pour water out of a boot that has the directions written on the heel". they are great as long as they can follow the script they ave memorized but once they get beyond that script, they flounder about and are worse than useless.
Aaron Z
/ Maintenance comment / question #20
Thanks, At least now, I/we know where you are coming from.
2017 Ford F-250 Pickup Truck (A61568)
2017 Ford F-250...
2019 FORD F-150 STX CREW CAB TRUCK (A59823)
2019 FORD F-150...
Yamaha Golf Cart (A57149)
Yamaha Golf Cart...
Black Jet Dock Drive-On (A59228)
Black Jet Dock...
40' High Cube Multidoor Shipping Container (A60463)
40' High Cube...
2012 HEIL TRAILER INTERNATIONAL CRUDE TRAILER (A60736)
2012 HEIL TRAILER...
