4310 rear hydraulics don't go down all the way
   / 4310 rear hydraulics don't go down all the way #1
fishpick
The part of NY with high taxes
L4760 & BX24
On a JD 4310 with a FEL...
The 3pt goes up fine... but no matter how the drop rate knob is messed with the implement on the 3pt will come down about 1/2 way based on knob position (more open the faster) - but then the last 1/2 or so of the descent to the ground the implement moves very - very slowly down...
Thoughts?
   / 4310 rear hydraulics don't go down all the way #2
The Rate-of-Drop valve need to be disassembled and cleaned I think, there have been a few issues with them...
That's within the Rock shaft assembly - right? A real bear to do!
   / 4310 rear hydraulics don't go down all the way #4
It should be on the front of the tranny, under the seat:
2000 Kenworth W900 - 3406E CAT Engine - 78,980 Miles (A52748)
2000 Kenworth W900...
Pallet of UV Solid Hardwood Flooring (A53424)
Pallet of UV Solid...
UNUSED FUTURE BTJ10 TIRE CHANGER (A54757)
UNUSED FUTURE...
2012 Dodge Ram 1500 Tradesman Crew Cab Pickup Truck (A55788)
2012 Dodge Ram...
Galvanized steel Fence (A53424)
Galvanized steel...
BOAT MOTOR TRAILER (A53424)
BOAT MOTOR TRAILER...
