Whats "equal"? Usually field work is non threatening as far as punctures,and you can take the traction benefit of Ags without any real world increased puncture risk. When you do get into ruffer work, like in the woods, the Ags will be a trade off between great traction and ground compliance, and really paying attention to small tree stobs that may punch thru them. The industrials are likely to take you harmlessly thru such hazard. Turfs are not as tuf, but they shine in optimum surface conditions and dont mark.everything else being equal, do Ags have a higher pucture rate with field work?
But John, why would a 10 ply ag be more likely to puncture than a 10 ply R4? Is it just the aggressive tread? Does it apply to sidewall as well?
Wow! didnt know they made such thick carcass AGs. I imagine the stiffness causes a small detriment to traction, esp over obstacles. Ply for ply puncture resistance seems like it would be pretty close - the slight advantage to the more rubber encased Industrial. Theres also a possible variable in the hardness of rubber used. Anyone know if different rubbers are used?Right, and as John Bud says, the available options make many generalizations open to correction.
Edit: Firestone makes a severe service 12 ply ag tire. I suspect its possible that an ag tire like this might be more puncture resistant than a dealer spec R4. Of course, they probably cost twice as much as a regular R1.
Second edit: They actually make an 18 ply ag tire in their basic 23 degree bias. I'd guess they'd be pretty puncture resistant.
Tractor tires will last 10 - 20 yrs. Cost is not such a great issue esp if the tuffer tire prevents puncture failures which are extremely costly.I guess if one was making doctor or lawyer money, they could buy expensive 12 ply ag tires, but let's face it, most of us don't make that kind of coin, so we po folk must get by with lesser ply tires that puncture easier.![]()
10-20 years? I can wear out a set of backhoe tires in 4 years.Tractor tires will last 10 - 20 yrs.
larry
One the size of your wrist? Many run filled tires as well.10-20 years? I can wear out a set of backhoe tires in 4 years.
hmmmmm....cost is a big issue for me.I can fix a puncture with a $20 can of slime.
Yep, running on the road is hard on tires. Especially if you forget to take it out of 4x4!
