SAND BARRELS ALONG SLOPES
/ SAND BARRELS ALONG SLOPES #1
escavader
western maine
bx-23 ,
HI
Any body got pics of sand barrels beside their drive ways for winter use.Igot two 55 gallon drums with the tops cut off.Iwas thinking about laying them on the side[proping up one end somehow]I also will take my mig welder ,and weld ahinge on it,so it can have a plywood end, to keep the weather out. Probably a stupid idea:confused:cause the salt i have to mix in to keep the sand from freezing will eat the barrel.But the PRICE OF free:Dwas in my range ,for the drums.
Ihave 650 feet of driveway to keep blown out ,and some real steep places,to keep sanded.Currently i lug the stuff in 5 gallon pails from a shed,but doing that after each storm gets old.SO AM I:p
AFTER THOUGHT ,should i spray some undercoating or something on the inside to slow down rusting out from the salt?
Iappreciate your thoughts on this.
ALAN
/ SAND BARRELS ALONG SLOPES #2
How about some pieces of Tyvek that has the HL company name all over it? Got to be some scraps around....
:rolleyes::D
Jay
:rolleyes::D
Jay
NOW Ifeel stupid,WHY DIDNT I THINK OF THAT??THANKS
By the way, Ihavent seen the sister to my BLOWER in your drive ,on my way home.It was there all summer.im assuming its all on the tractor ,and your just chomping at the bit to use it:D:D:D
Iwent back to HAMMOND TRACTOR and got every thing i needed to make my chute control work good guys over there.Isee the guy who sold me mine ,he laughed with me saying i stole it for what i got it for.Ioffered to sell it back for the new price.:D:DIdont think they sell pronovost now,they went to METEORS because they are cheaper.
oooppps im rambling ....back to sand barrels.................
ALAN
/ SAND BARRELS ALONG SLOPES #4
1*But the PRICE OF free:Dwas in my range for the drums.
2*AFTER THOUGHT ,should i spray some undercoating or something on the inside to slow down rusting out from the salt?
ALAN
1*That's a good price.
2*To bad they aren't plastic.
L . B .
/ SAND BARRELS ALONG SLOPES #5
One of my summer projects was expanding a storage space so that I could get the implements under cover, which is where they are now. I also built a couple of dollys - one for the wood chipper and the other for the snow blower (or BH) so I can move them around as needed.
You're right, the BH is off for the season and the snow blower is mounted and ready to go. I also added front and rear work lights - now all we need is some snow, which will be here all too soon, I'm sure. :rolleyes:
Jay
Jay
IM STILL FIBERGLASSIN THAT DANG CAB OF MINE:rolleyes::rolleyes:SNOW IS comeing soon and ive got to
1finish the prep work
2 prime the cab
3 paint the cab
4 install it back on the tractor
5 install all the glass
6 ive got a friend with a junk yard...ive got to go rob a heater out of a car and install it in my cab ...LOOKS LIKE THE BOTA WILL BE PART DODGE OMNI:D
7 install the blower,and mount the spool valve.
Its a darn good thing i still have my walk behind blower,think im gonna need it;);)
ALAN
/ SAND BARRELS ALONG SLOPES #8
Don't have pics, but in NewHamshire a few years back I noticed a cool idea.
They mounted 45gal drums on saw horses with the front legs shorter than the back ones.
Also they only cut off 1/2 of the tops.
With the tops only half cut the sand would not spill out.
Being tilted the top was protruding over the half opening preventing water from entering.
The saw horses served to have the drums higher than the curb snow banks.
Apparently the city kept the bbls full and it was up to the merchants and homeowners to do the spreading as required.
Smart thinking!
/ SAND BARRELS ALONG SLOPES #9
I picked-up some used large blue plastic barrels (about 50 gal) with large plastic lids at Clark's farm supply store in NH for about $5 or $10 each. I don't know what they were originally used for.
I keep them on a simple low wood frame that tilts the front up about 15 degrees. As they are plastic there is no problem mixing salt with the sand.
/ SAND BARRELS ALONG SLOPES #10
Being from a mild winter climate I'm kind of guessing on what you are wanting to do, but I have found the plastic barrels also with removeable tops going for about the same price. Feed and farm supply stores that carry bulk quanities of feed might be a good place to look. Here most carry barrels of some sort. Off brand tool dealers and Flea market type places often have some around here too. Most of what I see are individuals that have them advertised on the side of the road. As to the original contents most don't ask or tell.
/ SAND BARRELS ALONG SLOPES #11
yeah i know,wish i could lay my hands on some large plastic ones cheap.
They do make drum liners. May not last forever, but cheap, and easier than painting with undercoating.
Mark
/ SAND BARRELS ALONG SLOPES #12
I just pick up some sand in the bucket and run out to the hilly section, then raise the bucket so I can just see under it and let the sand trickle out a bit at a time. When it hits the ice/packed snow it bounces and spreads enough to do the job. My biggest problem is finding enough cheap sand and keeping it dry so it will flow when dropped....
/ SAND BARRELS ALONG SLOPES #13
Good Evenin Alan,
I got one of those 55 gal poly drums and cut about 1/3rd of one end with my jig saw. I then made up a frame out of 2x4's to raise it off the ground. I have mine situated on the steep section of my 800 ft drive ! I still fall on my a&& when Im spreading the sand with the shovel ;) so I guess I really need a 3 pt spreader ! :)
Here is a pic ! :)
/ SAND BARRELS ALONG SLOPES #14
Good Evenin Alan,
I have a 650' steep drive and also used to fall on my butt a lot spreading sand. Now that we have the tractor, with chains on 4 wheels in the winter, I put sand in the bucket and get my wife to drive slow down the drive. I walk in front spreading sand ahead with a shovel, as it is downhill the spreading is easy. As I am always walking on sanded sections, no more sore butt.
Good Evenin Alan,
Here is a pic ! :)
EVENING SCOTTY,
Imight have found a source for some plastic ones[now that i welded legs and hinges on my two metal ones ,last night:rolleyes::rolleyes:]If i fall on my a&& when im spreading ,i might break up the ice,since its getting so big eating wifeys cooking:pROBLEM SOLVED!!! Thanks for the pretty pic of your drive.NEXT time shovel out that barrel so ONE can ACTUALLY see it :D:D:D.
Im dreaming of a 12 volt atv spreader i can throw in the bucket.some dy someday...
ALAN
WOODY,
It would be easier to pull out all my teeth,then to get her outside,in the cold ,to drive the tractor:D Igotta do it all:)
Then again now that i got a heated cab......
ALAN
/ SAND BARRELS ALONG SLOPES #17
EVENING SCOTTY,
ALAN
Good Evenin Alan,
Sure buddy no problem !!! ;)
Woody,
Thanks for that tip, all I have to do is convince the wife ! ;):)
2011 Freightliner B2 School Bus (A61568)
2011 Freightliner...
TSURUM HSZ3-755 PUMP-1 PHASE INDUCTION PUMP (A62131)
TSURUM HSZ3-755...
UNUSED WOLVERINE BC-13-72W 72" HYD BRUSH CUTTER (A62131)
UNUSED WOLVERINE...
2005 Manac 48' x 102" Aluminum Fixed Spread Axle Trailer (A62613)
2005 Manac 48' x...
2013 Freightliner 122SD Truck, VIN # 1FUJGNDR3DDBZ7701 (A61165)
2013 Freightliner...
2008 Freightliner B2 Bus, VIN # 4UZABRDJ88CZ17960 (A61165)
2008 Freightliner...
