L3240 HST -power/ rpms
/ L3240 HST -power/ rpms #1
digdug1
Member
Austin, Texas
Kubota L3240
I recently purchased a 3240 with 724 fel. It seems relatively weak until the RPMs reach about 2000. When lifting and pushing at the same time you can easily stall the tractor unless rpms are high. At low rpm the tractor seems to struggle with very simple tasks (going up a hill). I take very good care of my equipment and try to run it at the lowest rpm possible. I usually operate the tractor in medium range and flip between turtle and rabbit depending on the load. I dont like having to rev the engine all the time just to do relatively easy tasks. I am looking for feedback from other 3240 or 3130 owners. What RPM do you normally operate the tractor at when using the fel? What range? Is it normal to use more rpms on a HST machine? Any feedback is greatly appreciated.
/ L3240 HST -power/ rpms #2
I have a new l3940hst and was brush cutting w/ it for the first time last weekend. The first thing I noted was that it didn't like hills. Even a mild slope would require quite a bit more throttle. When asked my first impressions, I said I wish I had 10 more hp.
I was trying to take it e z during the break in and kept the r's about 2000 to 2200.
And I have the rattling chain syndrome when going down a hill at speed.
/ L3240 HST -power/ rpms #3
I have a 2007 L3940 HST. I cut pastures with a Woods PRD8400 (7' wide). At 540 pto rpm I'm running about 2600 engine rpm. The tractor will do this ALL DAY LONG and it is designed to run at that rpm all day long. That's it's optimum power band range. I do this in medium range on the tranny.
When I use the FEL I tend to use the automatic throttle control. That's the setting that ties the HST peddle with the throttle. Medium range as well on the tranny.
When I'm operating the Woods BHX-90 backhoe I set the throttle to about 2500 rpm for optimum digging force.
These tractors are designed to RUN. Don't be afraid of some rpm's :D
/ L3240 HST -power/ rpms #4
I have a L3130 DT and in light clipping, with a 5 Sqealer Bush Hog. I cut in 2 gear high. I guess you would say 6 gear around 2000 rpms.
As far as loader work, my loader works as well a little above idle as full throttle.
/ L3240 HST -power/ rpms #5
I have an L3240 hst and agree with Happyman. The machines are made to be run up in the rpm's.
For bushhogging and such I run the tractor up around 2200 rpm and don't have any issues. I always run with the stall guard and auto hst on. I only use the auto throttle when doing simple driving around.
For bucket work I've found that keeping the rpms around 1900 up is best and all is fine.
I never had a tractor that could be worked with the thing running at idle. :rolleyes:
/ L3240 HST -power/ rpms #6
One other point. I use 4wd when operating the FEL. This helps a great deal with the pushing force when digging or moving dirt/gravel from piles.
And I'm with SCtractorguy...I always have the tractor on auto HST and stall guard. I set it there when I got the tractor and have never changed it.
/ L3240 HST -power/ rpms #7
I wondered about this too when I first got my tractor...but the point is that you don't want to do any 'work' under 2000 RPM. My tractor only has 3 cylinders so it needs the RPM to build HP. For driving on flat with no load I usually run about 1800.
It is good to know that rpms are no problem for this machine. When I keep them up around 2000 the tractor does seem quite powerful. I was just trying to be good to the machine by keeping rpms around 1500 or less. Thanks for all the input!!!
/ L3240 HST -power/ rpms #10
Yea man, don't worry about the rpm's. Crank it up.......
You own a 'BOTA :D
/ L3240 HST -power/ rpms #11
I had the same first impressions with mine. After I broke it in in the first 50 hours of varying the rpms, I now do loader work in either low or med range depending on the material and at about 2200 rpms.
When mowing with the bush hog I am at about 2400 rpm with the response dial set to quick so it will react quickly enough if you hit a tough spot or encounter a hill. If not it wont react quickly enough on the hydro and will drop you below 2000 rpms pretty quick and the power drops off quickly.
I don't know if it is me but I swear it has become considerably more powerful after about 70 hours. Maybe everything is now seated?
It will do more than you think as long as you don't ask too much from the hydro by using too high a range and getting close to the relief valve point.
/ L3240 HST -power/ rpms #12
I now have a L3240HST FEL. I had a B7800 and traded this year. Has been hard adjustment. Have to keep RPM's of L3240 up around the 2675RPM (what the owners booklet says) to keep the PTO rpm's right for my rear finish mower. Really slows down at the top of steep hill. That seems high to me after the B7800. The L series are considerably heavier than the B's so guess it needs it to move the body weight of the tractor. I do move it around at lower RPMs and have tried all the different goodies on it but upping the RPMs is what works. Several people that know alot more than me about diesel engines say to run them at high rpms and don't worry because that's how they are designed to work. Being a 60's car guy causes me much distress when I do this but it ain't a car and it ain't a 60's model.
