Backhoe Backhoe for a LK5054
/ Backhoe for a LK5054 #1
OFarrell
NH Workmaster 60
I ran across a Bradco 9HD hoe w subframe for a great price. As far as I can tell, I think it's close in size and performance to the new 609 backhoes. Is this going to be too much for my tractor?
/ Backhoe for a LK5054 #2
I'd try to find what Bradco recommends for hydraulic pump flow requirements;early 3054's didn't have much in the way of pump capacity, less than 9 GPM I think. My '04 only has 10 GPM. The mechanical aspect of the tractor can support it, IMO, but I question the pump capacity:confused:
The previous owner set it up with a PTO pump and tank. Can my tractor handle a 1500lb backhoe?
/ Backhoe for a LK5054 #4
Well, thats about half again the weight of a 2375, which is on mine. I've yanked pretty hard on some oak stumps and haven't hurt or broken anything, but that 9 footer, with a seperate PTO pump might just put a fatal strain on it. However, you'll be aware of what's on it, soooo
/ Backhoe for a LK5054 #5
Well the post states it's a LK5034 unless this is a gray market Kioti to my knowledge never made a 5034.
Is it a 3054?
If that hoe is a 9 foot hoe, I would NOT even think about putting that size hoe on it.
/ Backhoe for a LK5054 #6
LK3054???
Make sure it's subframe mounted. That's a lot of backhoe to hang on the 3-point hitch of a 3054. We saw a 3054 that had a woods 3-point backhoe on it and there were some signs of distress at the Bell housing and mid case. The subframe eliminates the transmission case from stressing under the weight and activity of the backhoe.
Is it a 3054?
sorry, LK3054
I was thinking it was too heavy but that confirms it.
/ Backhoe for a LK5054 #8
First, I'm thinking your front wheels would be off the ground, just too heavy.
As far as stress, a hoe that big will throw your machine around like a rag doll.
I'd stick with the hoe purpose built for the machine (7.5 foot).
I have to say, i really like my 2376 with single lever attach. Mounts nice high and tight to the machine, perfect weight for the machine, really nice fit.
Joel
2008 Ford F-550 4x4 Landscape Dump Truck with Lift Gate (A61568)
2008 Ford F-550...
2025 40in Tilt Bucket Excavator Attachment (A61572)
2025 40in Tilt...
2006 Hummer H3 4X4 SUV (A61574)
2006 Hummer H3 4X4...
Willmar 4550 Wrangler Articulating Loader (A63689)
Willmar 4550...
2024 CATERPILLAR 68" HYD 4IN1 BUCKET (A62129)
2024 CATERPILLAR...
Rake Mini Excavator Attachment (A61572)
Rake Mini...
