Posthole Digger Post Hole Digger
/ Post Hole Digger #2
I don't like the way that one is built (tube ends crushed for attachment - gearbox looks light, too). I bought mine from Northern Tool for less money and it is very heavy built. I can't tell you how many 14" holes I have dug not to mention 9s and 6s for fence posts. It digs a 4' hole, too. I don't know what you have for a tractor, but the one from Northern is a Cat 1 toplink hookup. I cut their bushing off and welded a Cat II in it's place for my tractor...
/ Post Hole Digger #3
You need to look at them in person, if you haven't already done so. My local TSC had different units in stock than depicted in their catalog under the same SKU. The augers only had a single bolt hole, as opposed to the industry standard two.
It seems to make a difference where the store is located.
/ Post Hole Digger
Thank Yall for the responses and your knowledge. I went ahead and purchased a 91 Case IH 1140 last night for $4000. Going to go to TSC this week or weekend to purchase the dirt bucket and look at the post hole diggers. Probably make a trip to Northern Tool as well. I dont have to have the post hole digger right this moment but I do need one. I need to put up a barbed wire fence for some cattle. Never put one up before but I feel like it shouldnt be to bad a deal. I have been looking at several fences and researching the "net" about it
/ Post Hole Digger #5
I have the red tractor supply one. mine looks fairly similar. I have punched well over 7,000 12" holes with it and it is in great shape. I use it to plant trees in the nursury. I would buy that unit over and over as it has not needed anything but grease. No leaks either!
/ Post Hole Digger #6
I looked at TSC and Fleet Farm units. I got mine from FF but it looked to about the same. I have put in a lot of fence so far with no problems.
/ Post Hole Digger #7
To my knowledge the northern stores in houston have no 3pt implements so call ahead first. just fyi
/ Post Hole Digger #8
I don't know what brand the TSC is, but it looks very much like my Leinbach 7200 PHD.
I've had good performance out of it for a few jobs around the ranch. You probably know this already, but if that one comes with a position bar, watch it when you raise to clear the dirt out of the hole and off the auger. It swings quite a bit and is hard to hold onto. My wife got her hand caught between the end of the bar and the back of her seat and got a pretty good cut from it. I ended up bending the end into a big round handle shape. Some guys take them off completely.
You probably know this too...when you position the auger, let it down on the spot and then move the tractor forward a bit ( about 4 to 6 inches) so the hole goes down straight instead of angling toward the tractor. I use low speed just above idle to operate mine. Always be super careful using a PHD. "Auger Off" is the only way to be around if you need to get close to it.
/ Post Hole Digger
Thanks for the information. I didnt know any of that, I am new to tractors. I do tend to research stuff to death though, then for some reason I still have to learn the hard way.
/ Post Hole Digger #10
You get the best hole if you move the tractor while you're digging. What I do is start plumb, and then I watch the top of the gearbox (it's perpendicular to the shaft). When the gearbox starts to not be level, I move the tractor (in the lowest gear and I am at ~1200 RPM like Rob) just a touch until it is. Nice straight holes with no arc to them. When I'm done digging, I run at the bottom of the hole for 15 seconds or so (bottomed out). Then I shut the PTO off with the auger still in the hole, lift it and move the tractor so it comes straight out. It's loaded when it comes out and leaves a nice clean hole. Pull forward a few feet, bump the PTO lever to spin off the dirt, move to the next hole...
/ Post Hole Digger #11
One thing that hasn't been said yet, don't get too small an auger.
I bought my PHD used with a 6 inch auger. The original owner bought it to plant a couple of hundred 4x4 fence posts. He learned the hard way that the auger needs to be more than two inches greater in diameter than the post. He would have been a lot better off with a 9 inch auger. You need clearance to level and back fill the post, and to account for the odd bits of dirt that crumble off of the side of the hole.
/ Post Hole Digger
Thanks for that. I would've bought one that was two small
/ Post Hole Digger #13
I just purchased one of the PHD's from Tractor Supply and its a "Farm Force" brand. It looks exactly like the Leinbach models. Got the 12' auger with it and have yet to even put it together, so i cant comment on its performance.
/ Post Hole Digger #14
The TSC PHD I bought is labeled FarmForce by Speeco.
Apparently they are having more than one company make their "FarmForce" brand PHDs....
/ Post Hole Digger #15
How many of you that recently bought augers from TSC got one with only a single bolt hole?
/ Post Hole Digger #17
I bought my PHD at TSC about 4 years ago and have drilled over 250 9 inch holes and it has performed flawlessly. Busted a lot of shear pins but thats what they are in there for. Mine was a Speeco PHD they msold at the time..
/ Post Hole Digger #18
I notice you are looking at "new" stuff. Tractor attachments and three point stuff don't get old quick. Look for some used and save. When I sell an old/unsued tool, it goes at a price that makes it move. I.e. kinda cheep. If you can, take a few weeks and read the newspaper adds in your local area or visit your favorate dealer, he gets tradeins. Cheers
/ Post Hole Digger #19
I have one like that or very similar I bought at TSC 10 + years ago. It has put in a couple hundred holes. No problems. I got the 12 in auger, it allows me to be a little sloppy on positioning and angle. Much easier to locate the post accurately.
/ Post Hole Digger #20
Single bolt hole where? Are you referencing the single bolt that holds the bit on?
UNUSED WOLVERINE BC-13-72W 72" HYD BRUSH CUTTER (A62131)
UNUSED WOLVERINE...
2015 Chevrolet Express 2500 Cargo Van (A61568)
2015 Chevrolet...
New/Unused Wolverine 84in Quick Attach Snow Plow (A61166)
New/Unused...
2006 Generac SD0150 187kVA T/A Towable Diesel Generator (A61567)
2006 Generac...
2015 John Deere 210G Hydraulic Excavator (A61567)
2015 John Deere...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59905)
2018 FREIGHTLINER...
