Different PT 425 problem
/ Different PT 425 problem #1
larrydman
Member
Southern West Virginia
PT 425
Been reading you guys problems with your 425's and was wondering if any of you has a line on mine. I've got 70 hours on mine and ever since I got it, it will choke out and die if I'm running anything other than the mower. With the mower it will run fine for hours on end, but with the bush hog or loader or anything else, it will run fine for a while and then choke out and die. After it sets a while it will restart and run a while longer. I'm no mechanic, but I've talked to a few and they are stumped (none of them have PT experience). I'm like Chris from PA, I love the machine when it runs, but I get aggravated at the stoppages. I can't trust the thing to do anything but mow grass. I don't know if it's something with the Robin engine or caused by hydraulics or what. I've cleaned and changed air and fuel filters religiusly but it makes no difference. Any help appreciated.
/ Different PT 425 problem #2
Are you running it with Wide Open Throttle (WOT) with the mower, and with the engine idling otherwise? The air cooled engine isn't really designed to operate at idle speeds for extended periods of time (it will overheat).
Usually the choking and dieing problem is associated with vapor lock, when the gasoline boils in the fuel line or fuel pump (which is unfortunately mounted right next to the exhaust muffler). Several people have insulated their fuel line or relocated their fuel pump. Usually, however, this sort of failure is independant is more likely to occur after a long mowing session.
Maybe the blower fan on the top is helping keep your engine cooler while mowing (since the hydraulic temps get hot enough to trigger the fan), and your engien is overheating the rest of the time. Try jumpering out the temp switch (located on the cooler on the top inside of the motor cover) so the fan runs all teh time and see if you get different results.
Note this last isn't a permanent solution, since you would rather not purposely cool down your hydraulic temperatures as ambient temperatures drop below 60F, as it can make your tractor a bit sluggish.
Have you tried calling PT and talking to Terry, their mechanical genius?
/ Different PT 425 problem #3
Welcome to TBN.
A couple of questions: By choke out, do you literally mean get too rich and die, or do you just mean sputter and stop from some unknown cause? A lot of folks have been having problems with their machines' vapor locking (the gas boils in the fuel line and the engine starves). You can search here and find a number of threads on the subject, with possible solutions.
If it was just the brush mower you were having problems with, I would wonder if you were just trying to cut too much material too fast, getting it too hot, and vapor locking. Since you are having the same problem with the loader, which doesn't use the PTO, I am stumped. Normally, running the loader doesn't stress the engine nearly as much as mowing, so I wouldn't expect you to get a vapor lock doing that kind of work if you don't get them when mowing.
Just to be sure, you do understand that the treadle is a kind of transmission control, not just a speed control like a car, and that when the engine bogs down because the load is too great, you let up on the treadle, not push down on it? A few folks new to PTs have not understood this point initially.
Lastly, are you operating the machine with the throttle wide open? You should. That is how they are designed to operate. The "throttle" is really an RPM control. The real throttle is controlled by the governor. Running with less than full throttle reduces engine cooling and lubrication.
/ Different PT 425 problem #4
Welcome to TBN.
I'm concerned about several people saying that the machine is designed to be run w/the throttle wide open.
I did that for a short time, made a lot of noise, used a lot of fuel, and the engine compartment was VERY hot, boiling the fuel in the tank (steel tank in cover).
Since then, from 20 to 650 hours, I've used 1/2 or slightly more throttle at most, with no overheating issues, and am using a lot less fuel.
However, I am NOT mowing, which probably requires WOT, but am using the mini-hoe and front end loader for excavating, backfilling, and using the plow for snow plowing.
Mark H.
/ Different PT 425 problem #5
Mark H.
That suggests that there is a design problem with your layout and/or muffler. It can't dissipate heat properly. By running the engine at less than full "throttle," you limit the amount of work it can do, since you are hard limiting the power that the engine can put out, but you are also limiting the engine's ability to cool itself. At a lower RPM, the fan will not move as much air, and the oil pump will not pump as much oil.
The best way to limit engine output is to back off of the treadle. The engine will do less work and use less fuel, but will still have full cooling available.
/ Different PT 425 problem #6
If you are having a problem when using the loader I am wondering if the PTO circuit is "on". This could put excessive load on the engine. It would be consistent with your statement "I did that for a short time, made a lot of noise, used a lot of fuel, and the engine compartment was VERY hot, boiling the fuel in the tank (steel tank in cover)."
When you remove the mower and use the loader--do you turn off the PTO? When you turn the PTO off does it appear that the load is actually removed from the engine?
/ Different PT 425 problem #7
Bob,
If engine is running, I don't think he could disconnect the hydraulic lines if the PTO switch was on. If the PTO switch switch is on when starting, will it even start or start and kill the engine since you are only pushing fluid against the relief valve. If the PTO switch is off, there is no pressure, PTO pump is just pumping fluid back to tank.
/ Different PT 425 problem #8
Bob,
JJ, I generally agree with your observations. I don't ever connect or disconnect the PTO lines with the engine running and I guess I just assumed that everyone does it that way. Maybe I should have said that perhaps the PTO valve is sticking in a partly open position--just enought to put excess load on the engine but not enough to prevent engine starting.
Hey Guys,
Thanks for all the input. The vapor lock theory seems reasonable. I do run the loader and tree shear at reduced RPM and maybe the bush hog but I think I run the boom mower at high RPM and it has happened with it, but it's possible I didn't have it that fast when it happened. I'll try it out when the weather breaks and see if it makes a difference. Like I said, I'm no mechanic and can't tell whether it's a flooding or starvation problem.
/ Different PT 425 problem #10
Also, you may have a little bit of more than one problem, which all come together under the right circumstances.
One of them may be a clogged fuel line. The angled hose barbs under the tanks have a habit of clogging with trash, especially on new machines. Check your clear fuel filter. It will have what appears to be an air pocket in it. It's actually fuel vapor, and is normal. If it grows as you operate until there is no fuel in the filter, it is an indication that your angled hose barb may be partially clogged.
Run a wire up into that fitting, if you think it is clogged. Needless to say, don't do it with a hot engine or any ignition source around, as you will inevitably spill some gas in the process.
/ Different PT 425 problem #11
Hey Guys,
When it starts to bog down if you choke it some and it revs back up it's a fuel starvation problem. If it's flooded and you choke it, it will stop quickly.
/ Different PT 425 problem #12
Is it true you should always run the 425 WOT? I'm sure when I picked up my PT I was told you only had to run WOT when mowing or using the snow blower. Other times I run it about 1/2 open, then increase the throttle as needed. Anyone else heard different?
/ Different PT 425 problem #13
The Robin engine owners manual states 'Whenever high speed operation is
not required, slow the engine down (idle) by moving the speed control lever to save fuel and extend engine life."
I operate mine like yours; WOT for mowing, idle for everything else and throttle up a little when it seems to start to bog down.
I think PT recommends the high speeds to ensure maximum cooling air flow through the engine; maybe it is in the PT manual.
/ Different PT 425 problem #14
I also do this. If I need a lot of torque I go full throttle, but for example if you are driving down hill just carrying dirt, no way do you need full throttle.
/ Different PT 425 problem #15
I pretty much run my 2001 model year PT425 with the Kohler engine wide open all the time. Mowing, loader work, forks, snow plowing, etc... When hauling heavy loads up and down hills, I have better control and more braking power.
My late 70's International 2500B (50 PTO HP, big gas engine, hydro tranny, cab, 8000 pound tractor) operator's manual said to run it at the PTO speed on the tach all the time to provide proper pressures and safe operation.
I drove hydraulic articulated aircraft moving equipment for a living for 6 years back in the 70's and 80's. They were wheelhorse tractors with no front axle, a heavy steel fork articulated off the back. The seat was on the hood and you drove with the steering wheel between your legs. Attached is some pictures of them. We always ran them at full throttle, too.
This is one of the reasons small hydro tractors use so much more fuel than small gear tractors. You need the full engine RPMs to keep the pumps at proper operating pressures. Larger hydro machines will throttle up and down the engine as it senses the need for more pressures, but the small machines do not have these features and need to run all out most of the time.
/ Different PT 425 problem #16
Pretty much the same.
/ Different PT 425 problem #17
Those cantelevered front-ends turly look odd.
On the subject of throttle position: WOT when using PTO circuit (mowing, auger, mixer) and about 3/4 or more as needed when using non-PTO attachments.
I had a football coach that used to say, "Run wide-open all the time, that way if you make a mistake, you make it at full speed!" :D In PT terms, that means if something is going to break or go wrong... it'll be something to remember! GO BIG or don't go!
/ Different PT 425 problem #18
The control labeled "throttle" isn't really a throttle. It is a RPM control hooked to the governor. The governor controls the real throttle (the carburetor butterfly).
There is nothing wrong with running at reduced throttle with non-PTO implements during low load conditions, except maximum ground speed will be lower and lift capacity will be reduced. However, these engines are designed to run at maximum speed, with the governor adjusting the real throttle according to the load. Kohler, for one, even calls the two throttle extremes low idle and high idle. Running at other than high idle will result in less cooling air and reduced oil flow. Running at high idle, while taking it easy with the task at hand, should result in better lubrication and cooling than throttling back.
With some PTs, there is another issue to consider. That is the PT designed and built muffler. I know mine was defective, either through design or manufacture, and choked off the engine badly. When I junked it and installed a Kohler muffler, fuel consumption dropped dramatically and run-on disappeared.
It may be that engines that still have a PT built muffler will benefit from running at a lower throttle setting, if the muffler can't flow enough exhaust at the full throttle setting.
Anyone running gas with ethanol in it should also be aware that the ethanol raises exhaust temperatures in these engines. I opened a thread on the subject here.
It seems possible that the combination of a defective muffler and ethanol in the fuel raises the operating temperature of these machines to the point that running them at their full rated output will likely result in early failures, along with very high fuel consumption, in which case, throttling back seems like a wise thing to do.
Each and every owner needs to evaluate their own unique situation and fuel, modify, and or/operate their machine in a manner suitable to the circumstances at hand. Unfortunately, there are no magic answers.
/ Different PT 425 problem #19
Larry,
I believe and hope it's as easy a problem as I encountered in 2004 after only 30 hours of my brand new PT. I discovered at the bottom of my gas tank some litter had blocked the gas from getting into the lines and periodically I'd hit the right bump or ditch while mowing and it' would clog. I changed my filter and drained my gas tank and blew out my fuel line and never had a problem since.
We'll pray that works for you!!! I know how discouraged I was after only a few hours. I now have 575 hours and love this thing almost like my wife and kids.
Good luck man
John in Maryland
Caterpillar 980G Wheel Loader Service Manuals Vol. 1 and Vol. 2 (A63117)
Caterpillar 980G...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
2011 Cadillac Escalade AWD Crew Cab Pickup Truck (A61573)
2011 Cadillac...
2006 Volvo VNM S/A Day Cab Truck Tractor (A61573)
2006 Volvo VNM S/A...
2012 Freightliner M2106 Bucket Truck, Terex Hi-Ranger HR52M, 52FT Platform Height (A63689)
2012 Freightliner...
CASE INTERNATIONAL 3020-25' TERRA FLEX GRAIN HEAD (A63291)
CASE INTERNATIONAL...
