Backhoe CK30HST - Can't connect backhoe HOSES?
   / CK30HST - Can't connect backhoe HOSES? #22
Not sure if I made my point so here it goes again. This is not an ordinary quick connect coupling! This one has a small pressure relief valve on the tip. With very little pressure you push the little button on the tip against any rigid surface and it opens releasing the residual pressure in the backhoe. You can also simply insert it into the female connection and when it encounters the valve it will relive the pressure and EASILY go in until it completes the connection. Here is a link to the manufacturer's page with a picture showing the small valve on the end. So by purchasing this product you can put away your whacking devices and just slip it in with ease. :cool:
Parker Hannifin Decompression Nipple - Dultmeier Sales
Yes I just saw the comparable coupling at TSC. Pioneer VP8010-15P-DC and the sku# is 8250600200. I thought the price was around $13.00 but not sure about that.
It looks like the same coupling as the site that you directed us to.
C-YA RL
   / CK30HST - Can't connect backhoe HOSES? #24
You guys are very funny.
   / CK30HST - Can't connect backhoe HOSES? #26
Just had this problem today (loader), I used two wrenches and bled off at fitting to hose connection. Took me at least 10 minutes of silent looking and thinking and looking and thinking to figure out what was up. The kick in the head part was, when I finally hooked everything up, my bucket controls moved the boom and my boom controls moved the bucket. Didn't take long to figure out that no matter how hard I blew into those fittings there was no way I was gonna loosen things up. PS, Hydro doesn't taste so good.
   / CK30HST - Can't connect backhoe HOSES? #27
Anybody got that?
84" HYD ROCK GRAPPLE (A52706)
84" HYD ROCK...
2022 Wacker Neuson PDT2A 2in Portable Diaphragm Pump (A55851)
2022 Wacker Neuson...
78'' rock / skeleton grapple (A56857)
78'' rock /...
Pallet of UV Solid Hardwood Flooring (A55758)
Pallet of UV Solid...
Cushman Electric Cart (A55853)
Cushman Electric...
2023 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A55973)
2023 HarbinGer V3...
