Whats going on with the PT429
   / Whats going on with the PT429 #11
   / Whats going on with the PT429 #12
I bought a 1430 because the gas 425 was limited to 25 degrees of slope. It has over 250 hard hours in 2 years and no mechanical problems except the front wheel motors were replaced under warranty. I do not like trying to get the parking brake off when on steep slopes and will probably modify the handle at some point.
The 429 would be a good idea if it has an oil pump so it can be used on slopes but it may end up being too close in price to the 1430 to be cost effective.
Thanks to everyone for the feedback on the 1430. The quiet on the machine is a good sign and it sounds like everyone is happy. I could get it and build an adapter for the 422/425 attachments. I might also get a few 1430 attachments like the 4 in 1 bucket. Any suggestions on this. What 422/425 attachments would be a poor choice for the 1430?
   / Whats going on with the PT429 #13
Forks. The 1430's are adjustable. They are much more versatile than the fixed 425 forks, which are also a bit short for my taste. Sales told me that PT has provided 1430 forks on 425 QA plates for some people.
   / Whats going on with the PT429 #14
I've bent the living heck out of my PT425 forks many times, so on a larger machine, they would not do well at all. ;)
   / Whats going on with the PT429 #15
How in the world did you manage to bend them, Moss? The forks and the light materials bucket are about the only things PT-425 related that haven't bent or broken on me.
   / Whats going on with the PT429 #17
Is it only the attachment plate that keeps attachments from one being used from the 425 to the 1430? No hydraulic system differences?
Thanks,
Chris
   / Whats going on with the PT429 #18
Thanks,
Chris
The 1430 has a 12 GPM PTO versus 8 GPM for the 425. Both are 2500 PSI. I don't know if the QDs are the same or not.
   / Whats going on with the PT429 #19
I have the 4 in 1 and often think I would be further ahead with a standard bucket and maybe a light material bucket plus a grapple. I have not found the PT 4 in 1 to be as versatile as advertised.
   / Whats going on with the PT429 #20
I often think that when you have a hammer, every problem looks like a nail. I think this is very much a YMMV issue, depending upon what you do with the tractor.
I have the 4N1 and the LMB, and the 4N1 is probably my most used attachment by a factor of 3-4. Almost none of my projects are light enough for the LMB. A grapple would be nice for brush removal and pruning, but so far, I haven't had to do a lot of it.
I use the 4N1 for dragging (back blade) and leveling (clam shell open) corals, and roads, , applying gravel and mulching materials (false bottom mode, which I find very useful, since I can see exactly where the material is going to go, unlike the LMB or regular bucket), and I use it as a bucket for heavy materials, wet clay, gravel, etc. I have used it to trench down to a broken pipe in wet soil and to make small sloped drainage ditches, and terraces. On my 1445, it is sized such that wet clay soil or granitic gravel is right at the upper end of the lift capabilities. The LMB is too large to handle my soils, but it does great with mulch.
The 4N1 seems to hold about 0.5 cu yard, and the LMB about 1 cu. yard. (At least on the 1445, the 1430 is 54" wide instead of 60, but I don't know how much the height and depth change.)
The one thing that I can't seem to do well is use the blade in a push mode: it seems to catch the soil, the blade digs in, and the tractor suddenly stops. Did I mention that the soil is very very hard here?
Given how hard my 1445 works, and it works really well, I am really impressed at all of the work that gets done by the green machines.
Bob: converting the 1430 to use your existing attachments is easy, except for the trencher, bush hog, and stump grinder which are setup for a lower flow PTO. Then again, a 429 might have a higher output PTO, which would have the same issue....
All the best,
Peter
2022 Carry-On 5'x8' Trailer (A53316)
2022 Carry-On...
(15) 1 RANCH 1RGPM GROUND PROTECTION MATS (A57193)
(15) 1 RANCH 1RGPM...
2016 Ford F-150 Pickup Truck (A55852)
2016 Ford F-150...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A55973)
2021 Ver-Mac...
DEUTZ MARATHON...
2011 FORD F350 SERVICE TRUCK (A52707)
2011 FORD F350...
