Tires - what am I missing here ?
/ Tires - what am I missing here ? #1
amashinga
I have a ford 1100 with 7-16 ag tires. The specs are basically a 16x6in rim, 29.3 in overall tire diam, load cap of 1100. I am looking for turf tires and having a real hard time finding them in my neck of the woods, since Firestone discontinued the 23x8.50-12's.
Then I twigged just how common a rim size this is, and started looking at light truck tires. I found an agressive offroad tire that fits a 6 inch wide rim, in a 225/75/r16 spec. The tire diam is 29.4, so I dont believe it is enough to concern myself with messing up my 4wd ratio. The load capacity is much higher than my current tires, no problem there. So what am I missing ????. This is too easy to actually work out :p
/ Tires - what am I missing here ? #2
I'f you've matched rolling circumference.. then you should be ok.. remember.. the reduced tread will likely slip more anyway..
soundguy
/ Tires - what am I missing here ? #3
Ditto what Soundguy says. I have used the truck tires on several grey market tractors that had the same issue. Your little tractor is a US model of the same tractors I put the tires on.
/ Tires - what am I missing here ? #4
I'm trying to do the same thing. Is there a decent website that compares tire diameters?
/ Tires - what am I missing here ? #5
If you go to Firestone's Ag tire site and lookup a tire and ask to view full specs you will see all kinds of dimensions including rolling circumferences.
Firestone Agricultural Tires
Andy
/ Tires - what am I missing here ? #7
You can use Front Tractor 3 Rib Tires F2's in the sizes of 6.50-16 or 7.50-16. Overall Diameter is within the 7% allowed by your drives. The size choice is your preference.
/ Tires - what am I missing here ? #8
3 Rib probably wouldn't be the best tire for a 4wd though.:eek: Should allow plenty of driveline slippage.:D Just goes to show, don't believe everything you read on the Internet - even if they claim to be a professional.:p:rolleyes:
FOUR RACKS OF MISC FILTERS (A68842)
FOUR RACKS OF MISC...
2018 GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A67714)
2018 GENERAC...
PORTA POTTY (A68842)
YALE 4K FORKLIFT (A67714)
YALE 4K FORKLIFT...
KANDI KRUISER GOLF CART (A67714)
KANDI KRUISER GOLF...
2013 INTERNATIONAL PROSTAR+ 113 (A67714)
2013 INTERNATIONAL...
