What causes hydraulic pump to "groan" ?
   / What causes hydraulic pump to "groan" ? #1
andrewj
South Carolina
JD 5105
groans when I steer and when I raise the lift, and more importantly, it is "bumpy" where it cuts in and out rapidly when I steer, causing me to muscle the wheel around...? fluid is not low.
   / What causes hydraulic pump to "groan" ? #2
Check the easy things first.
Check any filters in the system and make sure they aren't restricted. It sounds like you have some restriction on the suction side of the pump.
Is the fluid milky or foamy? Water in the system might also be an issue. Waterlogged foamy fluid will not pull as well into the pump and over the long term will cause damage.
   / What causes hydraulic pump to "groan" ? #3
from my experience it sounds like your pump is on its way out, either from age or water in the system, water will score the viens and the pump cant put out its full volume or pressure causing a jerky motion in both the loader and the steering
   / What causes hydraulic pump to "groan" ? #4
I'd agree with JSharp, clogged return screen or filter.
Could also be internal bypassing of fluid.
Or even a pressure relief valve set too low. It happens over time where the spring gets weak.
jb
   / What causes hydraulic pump to "groan" ? #5
andrewj,
Is this your new Tractor acting up?
2015 DODGE RAM 1500 CREW CAB TRUCK (A51406)
2015 DODGE RAM...
2018 JCB 505-TC 5,500lb 4x4 Rough Terrain Telehandler (A49461)
2018 JCB 505-TC...
2009 L3 GENERATOR SET (A51222)
2009 L3 GENERATOR...
2025 Safety Basket Forklift Attachment (A50322)
2025 Safety Basket...
2005 JOHN DEERE 310G BACKHOE (A50458)
2005 JOHN DEERE...
2015 FREIGHTLINER  CASCADIA (INOPERABLE) (A50854)
2015 FREIGHTLINER...
