Gravely Mow In 2008
/ Gravely Mow In 2008 #1
Solo
Fairmont,WV
New Holland Boomer2030
There was lots of nice equipment and a lot of nice people. My wife even enjoyed herself. :)
Solo
Here are a few more. :)
Solo
/ Gravely Mow In 2008 #3
Nice Pics!! Keep them coming! - Kris :D
Kris
I hope someone else here took some pics. That's all I have.
Solo
/ Gravely Mow In 2008 #5
Well, Good job!! anyway. I wish I could have been there!
- Kris :D
/ Gravely Mow In 2008 #6
Thanks for sharing your photos. That cut off saw is a scary beast. Also interesting to see that newer Gravely walk behind. Wasn't that an old 30" brush cutter attached to it or is that a new one?
It was an old style cutter that Gravely still makes. The new 2 wheel machines need a special adapter to run the old attachments.
Solo
/ Gravely Mow In 2008 #8
Sorry! They are two serial of Gravely implements . The older as mine with safety clutch. dont fit on Quick hitch and on the newer Gravely M or Rapids. You need the last serial implement for Quick hitch. This is one reason why I Choose a Grillo . I want make one adaptor for use and fit My Very good Gravely Impl On my Grillo Same front PTO rotation as the Gravely. The quick hitch Gravely implements are hard to find Here. Good luck ! Oldmech
/ Gravely Mow In 2008 #9
Sorry! They are two serial of Gravely implements . The older as mine with safety clutch. dont fit on Quick hitch and on the newer Gravely M or Rapids. You need the last serial implement for Quick hitch. Oldmech
Oldmech- This is not true! With a Gravely retro-fit kit you can attach the older attachments with a clutch on them to the commercial and professional series tractors as well as the newest Rapid tractor. Although on the Rapid only the small tractor. The other 2 bigger machines Ariens says no. To put them on the small Rapid tractor you would need the special adaptor Solo is talking about which allows a traditional gravely quick hitch then put on a retro-fit kit and the older attachments go on to that. - Kris :)
Here are some pics of the Retro-Fit Kit 044613.
Solo
/ Gravely Mow In 2008 #11
Thanks you very much! I understand We need one other adaptor (044613) For modify our Old Gravely clutch implement to quick hitch and for fit to Rapid M via adaptor kit 78510. All is right ! Except the price ! For me I think 9 hp engine is enough. with hydro we can go very slow for tough jobs. Thanks again for info and picts Good luck Oldmech
/ Gravely Mow In 2008 #13
BEWARE of the before and after paint job pictures.
