Suggestions on transporting a Ford 801 I plan on buying?
   / Suggestions on transporting a Ford 801 I plan on buying? #1
theedudenator
I have access to a 3/4 ton Chevy truck.
Are there places that will rent trailers for a tractor?
The move will be about 40 miles
   / Suggestions on transporting a Ford 801 I plan on buying? #2
U haul rents car trailers that will handle a 4K load. According to the 801 spec sheet I saw it weighs 3300 lb. so your good there. I don't know the width of an 801 so can't say whether it'll fit on a U haul car trailer. If it is wider than the U haul trailer can handle you'll have to find someone maybe with a deckover trailer.
   / Suggestions on transporting a Ford 801 I plan on buying? #3
Where are you located? If you only need to move it once call a wrecker company. If you do it at a odd hour and flexible with your schedule they will move it on a roll back fairly cheap.
Remember you got to put gas in that truck. If its gas plan on 8 mpg so about 10 gallons round trip or $40 then about $50 for the trailer. I bet you could get it moved by a wrecker for about the same or right around $100
By the way I have a 861. They are good tractors.
Chris
   / Suggestions on transporting a Ford 801 I plan on buying? #4
Where are you located. Someone called my a couple of weeks ago about moving a Ford tractor in the southern Ohio area from my craigslist add.
   / Suggestions on transporting a Ford 801 I plan on buying? #5
If you go to U-haul, DON'T tell them you are moving a tractor. They ONLY rent for moving cars/trucks. Tell them it is a 3/4 ton truck you will be hauling.
Ford 801 is about 3300 pounds. Filled tires add about 7-800 pounds. Front end loader adds about 1000-1500 pounds. Wheel weights add about 1000 pounds. Fuel and fluids can add a couple hundred. Add up the options you have to get your approximate total weight.
   / Suggestions on transporting a Ford 801 I plan on buying? #6
Some things we have done, some things i just want to do myself: Even for the same money i still would want to pick up new tractors by myself (also because i want to see before i buy)
3300 lbs is allmost 1500 kg. Last year i picked up my 3011 (about 1600 kg) about 120 km down, having the cruise control of my 850 TDI at 100 km/h, 2000 rpm, doing 20 miles per gallon on the highway.
The most statisfying things, which i insist on doing myself:
-pickung up newly purchased equipment
-Bringing in the harvest
Less statisfying things to have done by a contractor:
-spreading liquid hog manure
   / Suggestions on transporting a Ford 801 I plan on buying? #8
Saw a guy loading a tractor the other day onto a tandem car trailer . He drove up the ramps , the back of the trailer went down , the back of his 4X4 came off the ground and away it all went .:eek: Handbrakes don't work too well when the back wheels are in the air .:rolleyes:
   / Suggestions on transporting a Ford 801 I plan on buying? #9
Iron Horse said:
Saw a guy loading a tractor the other day onto a tandem car trailer . He drove up the ramps , the back of the trailer went down , the back of his 4X4 came off the ground and away it all went . Handbrakes don't work too well when the back wheels are in the air .
I was at a job the other day and my truck and trailer were pointed down a fairly steep hill. As I unload the rear of the truck gets pretty light, and as I unloaded at this job it occured to me that the rear may get a little TOO light for this downgrade. I stopped, got off and chocked the trailer and truck wheels, and sure enough when I pulled the chocks after I unloaded there was some strain on them. I'm glad I didn't learn this lesson the hard way!!
   / Suggestions on transporting a Ford 801 I plan on buying? #10
Thats why i brought my jack stands with me, when picking up my tractor ;)
2015 Ford Explorer AWD SUV (A50324)
2015 Ford Explorer...
2021 CATERPILLAR 259D3 SKID STEER (A51242)
2021 CATERPILLAR...
2011 Nissan Titan SV 4x4 Crew Cab Pickup Truck (A50323)
2011 Nissan Titan...
2015 Chevrolet Express Passenger Bus (A50323)
2015 Chevrolet...
16ft Trailer T/A Equipment Trailer (A50322)
16ft Trailer T/A...
2017 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2017 GENIE GTH-636...
