B7510 Won't start
   / B7510 Won't start #11
After shutting down the tractor, upon an attempted restart, only the Right (light/light) and
Left Glow-Plug lights would come on, and all I could here was a "Click,"which I attributed to the starter selenoid, b
Don't leave me hanging like this, dying to hear what happened.
   / B7510 Won't start #12
Thank You all for your help!
Here is a retrospective of the problem that will save y'all, but at MY experience and expense.
As you recall, the 7510 died between mows, as my wife shut it down for a bit.
In retrospect, here is my account of piecing together the pieces of the electronic puzzle.
My original dynamo failed on delivery and I purchased an OEM alternator from one of this sites sponsors and the dealer installed with out labor charges inlieu of labor to replace the part. No transport charges where ever waived.
dont ya just hate when you get halfway through a real good story and forget how it finishes.....:D:D:D
   / B7510 Won't start
Ok so here's what happened.
One of the wires that the dealer installed (poorly) in the the generator worked it's way out of the connector. It wasn't crimped well, and not soldered. When I put it back in in the field, and the tractor started, my wife drove back to the barn and the 7510 died 10 feet from the barn door.
I repaired the wire, soldering into the connector but nothing. All of the fuses "looked" OK.
However, upon checking each fuse with an ohm meter, the main fuse (Blue 20 amp, I think)
was blown, but the "Z" fuse looked intact. A lesson there. Always check with an ohm meter.
Now on to my new problem with the HST pedal not returning to neutral.
regards,
Steve
   / B7510 Won't start #14
Can you see a grease zerk fitting for your pedal underneath there anywhere? That's one of the points I'm always sure to hit on my B3030, but you have to look closely to find it.
2023 Fat Truck 2.8C Amphibious AWD Off-Road Utility Vehicle (A55852)
2023 Fat Truck...
Volvo L306 (A57148)
Volvo L306 (A57148)
1992 DFI PULL SPREADER (A57192)
1992 DFI PULL...
2007 CHEVROLET 3500 DUALLY 4X4 DIESEL TRUCK (A59575)
2007 CHEVROLET...
2000 Kenworth W900 - 3406E CAT Engine - 78,980 Miles (A55302)
2000 Kenworth W900...
1996 Dorsey Enclosed Trailer, VIN # 1DTV11520TA252324 (A57453)
1996 Dorsey...
