Grapple Markham Grapple w/John Deere QA setup
/ Markham Grapple w/John Deere QA setup #1
kennyd
Advertiser
Westminster, MD
John Deere 3720 CAB/TLB, JD455
I spoke with Melissa yesterday to order my LD-48 Grapple and we talked about the JD QA setup they are offering-She is still learning the tractor side of the business since they primary bread&butter is SSL attachments. So I thought I would let all the JD owners know that their QA setup will fit all the current JD loaders because they are adding two sets of pins for the two different spacings. The extra cost is $80.00 for this setup.
So, just to give a list-it will fit these JD loaders:
210, 410, 420, 430, 460, 200xx, 300xx, 400xx, 5xx
I will get pictures when mine arrives:D
/ Markham Grapple w/John Deere QA setup #2
What no 200cx Kenny????
And you beat me to ordering a 48" from Markham.......
/ Markham Grapple w/John Deere QA setup #4
BTW, what did you order? spacer tines?
I got the LD-48", JD QA, NO spacers (can add then latter if I need them), No hoses/coupler's, Wider top(they are all 30" now), and Serrated teeth(They all have then now also)
/ Markham Grapple w/John Deere QA setup #6
Congratulations Kenny, that grapple sure has been a big hit here, and for a good reason. Looks like Markham's products are great.
Will it be a big install or I suppose you have everything for up front already?
I can't wait to see photos of it and also using it.
Thanks Rob. I already have the hydraulics to run it, I added a diverter to my FEL a few years ago to run the angle on a FEL snowplow that I had built. The plow is gone now-so it will be nice to use my investment again:D
FEL Remote
Joystick Handle
Here are some pictures, getting hoses tomorrow:D
Weight according to the truck scale near work is 420lbs.
/ Markham Grapple w/John Deere QA setup #9
Kenny: Looks to me like you need a place to test that out! We're doing firewood now. Not getting any trees from Phil, getting all the downed oak I need from the new place behind our house where we go plinking.
Looks Fun!
Wayne
Got the hoses today, so here a few more pictures...
/ Markham Grapple w/John Deere QA setup #11
That looks nice! Now as you mow the yard you can use it to pick up items in your way!:p
/ Markham Grapple w/John Deere QA setup #12
I like the hose cover they put on the cylinder. I need to add that to my Millonzi. JC
/ Markham Grapple w/John Deere QA setup #13
KennyD....where do you get the Fabric "Hose Sleeve"?
/ Markham Grapple w/John Deere QA setup #15
I've said it before Kenny, but after seeing your Markham grapple on your JD, it's worth mentioning again. It looks great and you did a super clean job setting it all up.
Nice going!
/ Markham Grapple w/John Deere QA setup #16
Kenny,
After you get a chance to use it, please let us know how you like it.
I am thinking of getting the same unit.
Thanks
Glenn
/ Markham Grapple w/John Deere QA setup #17
same here kenny, let us know how you like it. im considering one as well, for my 4115. im curious about the weight of the unit as to its effectiveness.
thanks again for the detailed thread!
YANMAR VIO55-6A EXCAVATOR (A63276)
YANMAR VIO55-6A...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
Bobcat Skidsteer Snowplow
Bobcat Skidsteer...
2016 WEILER P385A ASPHALT PAVER (A62129)
2016 WEILER P385A...
Abaco Machines DVL500 Vacuum Lifter (A61573)
Abaco Machines...
