Farmtrac 360 DTC Clutch
   / Farmtrac 360 DTC Clutch #1
Qapla
Gator Country
New Holland TC40D HST 4WD FEL/BH
Our 360 has the Backhoe/Front Loader attachments. This is our primary use for the tractor. It has been working quite fine until Yesterday.
It was used the day before and was evidently working normal (my brother was using it). Then I went to use it the next morning. There were problems:
The clutch pedal seems to have no real resistance now (almost like stepping on a wet sponge)
The tractor has no "get-up-and-go" in the upper range.
The mid and lower range seem to still work as before, however the clutch still has no real resistance at the pedal as before.
Any ideas?
I forgot to ask ...
Does anyone know where I can get a service/repair manual for this tractor?
   / Farmtrac 360 DTC Clutch #3
Sounds like the return spring on the clutch pedal broke. If you look under the floor plate on the side with the clutch pedal, you should see a place on the pedal as well as on the frame/plate where the spring attaches.
There is a spring on the pedal that is fastened to the tractor toward the back of the machine. The pedal returns to the up position just fine.
Is this the spring you are talking about (it is still there) or should there be another one that pulls the clutch lever from the front?
Qapla!
2013 Ford F-650 Flatbed Truck (A51692)
2013 Ford F-650...
1334 (A57192)
1334 (A57192)
Honda EM3500SX Portable Gasoline Generator (A55851)
Honda EM3500SX...
UNUSED FUTURE WALK BEHIND POWER TROWELL (A52706)
UNUSED FUTURE WALK...
GMC 3500 Extended Cab 4WD Pickup Truck - 6L V8 Gasoline Automatic (A57024)
GMC 3500 Extended...
