Purchasing My First Tractor
/ Purchasing My First Tractor #1
villa14
I'm just starting to learn about farm equipment and I have been given the opportunity to raise my own hay on 100 acres, wheat on 34 acres, and have 30 acres of pasture for a horse training facility of 200 acres total. The tractor (with a loader) must be big enough to load manure, mow, rake, and bale the hay that I will raise. My problem is that I am not sure which tractor would be best for the job.
From the small amount of research that I have done so far, I am looking at the following tractors:
~John Deere 5403
~John Deere 5425
~Kubota M7040
~Kubota M8540
~New Holland T5040
~New Holland TT55
Do these seem like appropriate tractors for the job that I need to do? Does anyone have any other suggestions?
Thanks in advance for your help!
/ Purchasing My First Tractor #2
Right off, let me be the first to welcome you to TBN. You'll never find yourself in short supply of opinion here, 'cause there's an ample supply to be had! ;)
Good choices so far. Look atthe 500 series Massey Fergusons too. Real bang for the buck there. You'll get a lot of happy Mahindra owner on here. I'd suggest looking there too.
I farmed for 35+ years on approx 200 acres, with a 60 hp JD tractor as my biggest most of those years. That's a good match. You'll find uses for larger power, but if you plan on ONE tractor for now, 60hp range is a good place to start.
In time, you'll find the need for more than one tractor. (Some of us can't seem to get ENOUGH of 'em) I'd suggest starting with one versatile enough to do just about everything on your list. (Not too big...not too small)
/ Purchasing My First Tractor #3
we have a horse training facility similar to what you have. i bought a kubota m8540 4x4 with loader. it handles the kicker baler and wagons with ease, even on fairly steep fields. we spread manure until the snow gets to deep. then in the spring when the fields dry out, i load the spreader with the 8540 and spread it with a ford 7610. the tractor also does well on fuel because it doesn't have to work very hard to do these chores.
/ Purchasing My First Tractor #4
~John Deere 5403
~John Deere 5425
~Kubota M7040
~Kubota M8540
~New Holland T5040
~New Holland TT55
I would also look at Kioti DK65 tractors.coobie
/ Purchasing My First Tractor #5
Are yuo only interested in new.. or would you look at slightly used? or 'classic' machines?
late 70's and up larger fords and NH are pennies and nickles on the dollar of new machines.. spend some time looking and get a good one and it will have decades of life left in it.
soundguy
soundguy
I'm looking for primarily new tractors. Thanks for the input so far!
/ Purchasing My First Tractor #7
Just my opinion and it isn't worth all that much, but with the size of property and what you are planning on doing, it sounds like you should get about the biggest tractor that you can afford now and then get a smaller one to help out later on. Multiple tractors are a great thing to have where multiple chores need to be done.:D Maybe let us know the area that you are in and there might be someone here that would be able to recommend a brand and or dealer close by for you to check out.
/ Purchasing My First Tractor #8
Just my opiniion, but of the tractors on your list I'd pick the M8540. You've got 200 acres to work which is quite a bit. A smaller tractor will do great for many tasks but will take longer to do your big jobs (if it can do the big jobs).
What are your plans for the 100 acres of hay? Round bales, square bales, small bales, large bales? Will you do all of the haying on that 100 acres with a single tractor? How do you plan to transport and store all of that hay?
/ Purchasing My First Tractor #9
That's what I was hinting at.. that size property is begging for a big ole' 2wd no-frills 70-135hp tractor PLUS a 30hp tractor with loader and 4wd... etc.
soundguy
If I were to purchase the Kubota M8540, what would an appropriate hay baler be for the tractor as well as the amount of land I will be utilizing? Does compatibility with the tractor matter? I'd be looking to do square bales.
/ Purchasing My First Tractor #11
we use an older jd336 kicker baler. it makes great bales and rarely misses a knot. around here you can pick up a decent 336 for 2,000-4,000$. i paid 2,500$ and it works great. that tractor will also handle higher capacity balers. many farmers around here also use new holland balers, both brands are very reliable. for mowing the hay, we use a new holland disc mower conditioner. it is a 9ft. model. you could also use a haybine, but they are not as fast as a disc mower. the 8540 handles the mower with ease. when mowing or bailing i take the loader off and put front weights on. after one or two tries you'll take the loader off or on in five minutes. very easy to do. for snow i use the loader up front with a hd back blade with skid shoes on the rear. can move alot of snow in a hurry with this setup. ps. you wouldn't need front weight's if your property is fairly flat. i use them also with the brushhog doing hilly areas. hope this gives you some idea of what this tractor will do. i'm sure other brands will do the jobs you want also, but i'm very happy with kubota.
/ Purchasing My First Tractor #12
As for compatability.. just make sur ethe machine and your tractor both have the same pto spec ( 540 or 1000 ), and that you have sufficient pto hp and are a safe weight for the machine.
soundguy
/ Purchasing My First Tractor #13
~John Deere 5403
~John Deere 5425
~Kubota M7040
~Kubota M8540
~New Holland T5040
~New Holland TT55
One of my neighbors does about 200 acres of oat hay (unirrigated) with a 1970s Steiger (150+ hp engine, 4WD, articulated, cab) and a big old IH tractor (100+ hp, 2WD, cab). His grain drill, tandem discs and field cultivators are 15-20 ft wide. He mows the hay with a self-propelled NH swather with at least 10-ft wide cutting head. He has two NH small square balers that he pulls with smaller 60 hp tractors. He has a nice NH older bale wagon to stack the hay.
It takes a lot of hp and big implements to work that much hayfield. Before dropping big bucks on a new 60-90 hp tractor, I'd check around with neighbors who are farming similar size spreads and find out what they're using and get recommendations.
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A59904)
2017 FREIGHTLINER...
2006 Freightliner Auger Truck (A63118)
2006 Freightliner...
2018 CATERPILLAR TL1255D TELESCOPIC FORKLIFT (A62129)
2018 CATERPILLAR...
2018 CATERPILLAR...
2007 CATERPILLAR 725 OFF ROAD DUMP TRUCK (A60429)
2007 CATERPILLAR...
2019 CATERPILLAR 289D SKID STEER (A62129)
2019 CATERPILLAR...
