JD 2210 owners weigh in
   / JD 2210 owners weigh in #1
Reg312
Member
Missouri
JD 322 - AC 712 && 912 - Snapper ZTR
Got a chance to buy a 05 - 06 JD 2210 4x4 for 12 gees with 100 hrs. Includes -60" belly mower
-Quick attach front loader w/ 5' bucket
-Post hole auger w/ 12" bit
-60" rock/landscape rake
-48" roto-tiller
-48" Farmall bush hog
-Quick Hitch
Price seems good but I've noticed a lot of these for sale with low hours. Do they have a problem. I've read of transfer case problems, pto problems, brake problems. My main use right now is Bush hog - Post hole - FEL work.
   / JD 2210 owners weigh in #2
I have an 03 that I boulght new in Nov 03. It has 420hrs now and other than a snowblower vibration that I finally fixed last year it has been trouble free.
I have a fel 49", 62"mmm a 47" front snowblower, 48" box blade and a 60" strait blade. And a heated cab for the winter that I would never give up.
   / JD 2210 owners weigh in #4
2210 is the predecessor to the 2305 - they are vitually the same rig with a different (updated) look to the 2305.
I don't know of any outstanding issues that are "nagging" with either the 2210 or the 2305 - they are great little subCUT's and will serve you well. I've not read of transfer case problems, or brake problems. The only PTO problems I've read about have been, seemingly, self inflicted.
Have it checked out by your dealer - enjoy!
Scott
Thanks for the replies - Those reviews were at www.********************.com
Now just have to figure which way to go. A JD 790 w/Loader. The 2210 with the equipment listed above. A Case 245 w/loader and hoe. And a Kubota 2200 with a bunch of equipment just jumped into the mix. Pricing from $9000 to $13000.
   / JD 2210 owners weigh in #6
if you were to buy it all brand new that set up would set you back around $16, the tractor is just getting broke in so as long as every thing is in good shape I'd say it's a good deal.
   / JD 2210 owners weigh in #7
I've owned a 2305 for a year or so and it hasn't let me down yet. I'm very impressed with what the little guy can do. I run a 4' woods bushhog behind it with no problems. We used it last winter to drag firewood out of the woods. It's easier to get around in tight places than the larger tractors. It seems to get more use than the larger tractors because it's just so darn handy.
   / JD 2210 owners weigh in #8
I have a 790 with 70 hours on it and yesterday I graded about 5 miles of roads and a driveway with a 5ft box blade on about a gallon of diesel. For ground engaging work this thing is difficult to beat. When I'm using the loader a lot I wish for a hydro but otherwise I couldn't be happier with the tractor. Its a significantly larger framed tractor than a 2210 but is a non-syncronized gear tractor.
   / JD 2210 owners weigh in #9
This IS WHAT i GET WHEN i CLICK ON YOUR LINK.
Oops! We can't find the webpage you're looking for
   / JD 2210 owners weigh in #10
I bought a '05 2210 w/ 100 hours, FEL, 54" MMM, & Balest Box for 10k in June. I would think with all of the implements you are getting it is a good deal.
2007 Reitnouer 40 Ton T/A Flatbed Trailer (A49461)
2007 Reitnouer 40...
2021 CATERPILLAR 259D3 SKID STEER (A51242)
2021 CATERPILLAR...
2014 PETERBILT 367 (A50854)
2014 PETERBILT 367...
2012 Toro Greensmaster 1600 Walk Behind Mower (A48082)
2012 Toro...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
2013 MACK PINNACLE (A50854)
2013 MACK PINNACLE...
