Mowing What Mower?
   / What Mower? #1
JohnKim
I have a Kubota L2550 and am about to buy a finnishing mower. Should I get a 5 ft or will the 2550 handle a 6 ft okay? Thanks for any info
   / What Mower? #2
I have a 6' Landpride RFM. I used it on a B7800 with no problems. Now have a L3240HST and use the same mower. It works fine except when I get close to the top of a real steep hill and it slows the tractor down. I had a cheap piece of junk RFM before the Landpride. Get a good one if your going to use it. If your going to just have it for looks it doesn't matter. If your mowing a level yard then that will make a difference in your needs.
   / What Mower? #3
I'd say go with the 6 footer - if the grass is too thick you can always slow down or take a narrower bite. Most times it will be ok.
   / What Mower? #4
I agree with Dick go with the 72" you might be surprised even in thick grass because your PTO set at 540 RPM = approximately (depending on your final drive) near 17,000 FPM with a 24" blade. And I'm guessing without doing discrete math to back it up.
   / What Mower? #5
hey guys, hope you dont mind if i ask a question, but was wondering about the landpride mower you have, johnthomas. is it rear discharge and are you happy with it? i have a 5ft side discharge mower, and it has been a great mower, cuts good and no repair issues at all. i am thinking about going with a 6ft landpride rear discharge, patriot model, and was wondering about your experience with yours. hope i dont step on any toes, by butting in on this thread, and if so, i apologize.
   / What Mower? #6
JohnKim,
My tractor is a B2150 and I have the 72 inch Kingkutter finish mower from TSC. It is a great combination. I set the mower up high for my pastures and low for the lawn around the house.
Terry
   / What Mower? #7
I have a 5' Sitrex rear discharge that I pull behind my L3240.
I think a bigger mower would be nice to get my 2 acres mowed faster. I just can't see spending the $ though. I've never had it bog down.
   / What Mower? #8
I have the landpide 6' patriot model and I love it....
I have not had a singel issue with it and it provides a very good quality cut...it cuts about 3+/- AC a week...
Good luck
   / What Mower? #9
That tractor will have no problem with a 6' finish mower. I used one with my old L2500 which I think had 22.5 pto hp, for 8 years until I traded the tractor in, with no problems.
   / What Mower?
Okay, Thanks guys for all the help. Bought a 6ft today and mowed with it for a couple of hours. Does good behind the little 2550. Just got the 2550 a week or so ago. Sold an old Ford and bought the Kubota. Really surprised at the power this little tractor has. always been a Ford man but sold on Kubota now.
TEST YOUR BID BUTTON! (A58375)
TEST YOUR BID...
2024 CATERPILLAR 255 SKID STEER (A52709)
2024 CATERPILLAR...
2020 VOLVO 760 TANDEM AXLE SLEEPER (A57880)
2020 VOLVO 760...
2002 TOYOTA 7FDKU40 FORKLIFT (A57880)
2002 TOYOTA...
2022 Brush Wolf ALPHA-XP Skid Loader Brush Cutter (A56435)
2022 Brush Wolf...
2018 Ford Fusion Hybrid Sedan (A56859)
2018 Ford Fusion...
