Rear Window Protection
/ Rear Window Protection #1
ddivinia
Elite Member
Red Oak, Texas
JD 5525 and 5093e Kubota SVL75
Does anybody know of an outfit that sells rear window guards? I want to put a steel mesh protection system of sorts on the back of my JD 5525 cab. I want the rear and right side window protected specifically. If it did both sides, I would be fine with it.
Any ideas?
D.
/ Rear Window Protection #2
Find a shop that can measure and make up expanded metal coverings that can be bolted on.:)
/ Rear Window Protection #3
Good advice on the shop/fabrication idea - IMO.
You'll likely invest alot of time and money (shipping.. whew) huntin' for a 3rd party manufacturer to sell you somethin' that a local shop could build and give you later support (modifications-repairs, etc.) for.
I was havin' trouble with sticks pokin' thru my front grill and the JD grill guard was too "frilly" and wouldn't stand up to anything like a determined tree branch.. So, I had a local guy mig and tig a "hefty hummer" on my tractor.
AKfish
I would much rather order something and have it show up than have to haul my tractor somewhere or have them come out, etc. Bolt on isn't so easy with a cab but I have figured out a couple ways using the spots for the add on taillights and some screws/bolts ont he top. Then I will want it powder coated or something, etc.
I suspect nobody makes jack for it and I will be making my own. Just too dang busy these days.
D.
/ Rear Window Protection #5
I hear ya... that's what winter is for up here - tractor mods and other projects!
You just need a few more months of WINTER.
AKfish
/ Rear Window Protection #6
Or do it yourself. It doesn't seem to be a tough job.
I don't have a cab on my Mahindra 5525, but I do have an expanded metal screen attached to the ROPS via hose clamps to protect my backside, especially when using the brush hog.
You can get all the parts for window covers from Home Depot or Lowes.
AKfish
I figure it will end up being a winter project.
D.
An open station with ROPS tractor is a whole different ball game than a cab. It is nowhere near as simple.
D.
Actually, A brush cover kit is made specifcally for your tractor. Please be seated before viewing the price list.
4000 & 5000 Series Ag Tractors
These fellows could probably build you somthing as well.
Forestry Guards, Addington Equipment
HTH
GR is $4200 - have to put a whole cab cage on there. That is pretty excessive. Heck, maybe I need to produce theses - i think there is a market for rear flying protection without having to do a full FOPS.
D.
/ Rear Window Protection #11
I have seen the rear window mesh screen gaurds on Jd 7000 series tractors with bat wing mowers. Dealer had several on his lot with them. About 3' square.
Were they cab tractors?
If so, how did he attach them?
D.
500 BBL FRAC TANK (A67714)
500 BBL FRAC TANK...
CATERPILLAR PAVER (A65053)
CATERPILLAR PAVER...
2015 WINSTON TANDEM AXLE 24FT EQUIPMENT TRAILER (A66091)
2015 WINSTON...
2017 Ford Explorer AWD SUV (A64557)
2017 Ford Explorer...
2017 Ford F-550 Altec AT37G 37ft. Insulated Bucket Truck (A66736)
2017 Ford F-550...
CATERPILLAR PC306 PLANER (A65053)
CATERPILLAR PC306...
