DK55 hydraulic rod broke
/ DK55 hydraulic rod broke #1
curly
Union, SC
2013 Kioti CK35 HST
I was clearing some land with bushhog and grapple and heard a very loud snap that did not sound like a limb snapping. Then I saw a hydraulic geyser up front. The top cylinder that works the curling part for the bucket had snapped the rod in half.
I have no idea how that happened. I was pulling on a rather large vine at the time. The bracket that the rod attaches too was bent and thats what prolly put the pressure on the rod, but man, that's about a 1 inch rod, and that bracket was pretty darn thick metal too...can't figure out how it happened. May have bent the bracket knocking down a tree a few minutes (or seconds) earlier and the rod couldn't come out of the cylinder right so it just snapped it.
But have have been working the snot outta that thing lately, so I reckon stuff does break :) Took it off and dropped it off at the local hydraulic shop to get it rebuilt this afternoon.
/ DK55 hydraulic rod broke #2
Bummer. This is the first time I've heard of that on a TBN post. I hope the repair works out.
How were you using the loader when pushing on the tree earlier. Were you pushing or pulling? I've heard that back dragging with an FEL puts unusual amounts of stress on loader hydraulics but hadn't heard of this type of misadventure before.
I was just pushing on the trees. But then there are some large vines (6-7 in diamiter) that I wouold grab with the grapple and pull backwards to pull them down from the tress as they are obviously grown up and entangled.
I have done some pulling on things with the grapple, pulled the grapple off of the tractor a few times. Not recommended...tends to break hoses and connectors when the grapple falls :rolleyes:
And that woods bush hog will cut down about anything. I've been chewing up 6 in diameter pines with it. It is incredible. The slip clutch is great, I'm sure I would have broken a few hundred pins by now had I gone that route.
/ DK55 hydraulic rod broke #4
I've never pulled a 6 inch vine but I've pulled a lot of 2-3 inch vines that were strong enough to cause me to give up after losing traction while pulling. No ill effects.
It will be interesting to see what they hydraulic shop says after they've disassembled the thing.
/ DK55 hydraulic rod broke #5
Curly,
What are you doing down there? Well, if that rod is about an inch, it's probably 25mm. I believe those Kioti cylinders are metric. Look on this website, Bailey Hydraulic Cylinders Manufacturer, they have metric rod blanks. This will let you know what the rod costs per inch, then the machining, then of course seals which cost under 20 bucks aftermarket. Stop breaking stuff, will you?
Curly,
I just talked to Chip and I think he said the rod was 1 1/4...could be wrong. He machine everything there...has the largest lathe I've ever seen in my life.
Hey, I'm plenty happy NOT breaking stuff. I was making some good progress on an area that we can see from our porch and had to quit. Didn't get to do any tractoring yesterday, but I did run a lot or errands.
I got a Millermatic 212 on it's way to my house so I went and bought some argon/co2 and other misc welding stuff. I bought a $1500 welder (can't weld yet) so I could weld 2 hooks on my bucket:eek: But 15 years ago I bought a $600 mitre saw to build a $8 bird house :D. I have probably made thousands of cuts on that saw since then though so it has more than paid off. And I've accumulated a shop full of woodworking tools because of that first saw. If I can get interested in welding liike I did woodworking it will turn into a very worthwile tool for me.
/ DK55 hydraulic rod broke #8
I bought a $1500 welder (can't weld yet) so I could weld 2 hooks on my bucket:eek: But 15 years ago I bought a $600 mitre saw to build a $8 bird house :D. .
We may be twins separated at birth.:eek:
/ DK55 hydraulic rod broke #9
This sounds like the disease that affects most TBN'ers, with no known cure!! :D
I wonder if I need a plasma cutter to go with that welder :D
/ DK55 hydraulic rod broke #11
You don't have one yet? Man, you are less affected by the disease than I thought. I'm embarassed to say I have a nice new Hypertherm I got on sale that hasn't made it out of the box yet. :eek:
Wanna sell it :D
Got the cylinder back today. It was $260 to rebuild with a new rod, and I think a whole new cylinder was abour $430.
/ DK55 hydraulic rod broke #15
Geez Curly, I think you got a decent deal. You definately didn't get ripped off as these rods are sold by the inch and then you have machining and seals too. I would be happy with that price.
Yeah, I'm pretty happy with the place near me that I do bidnez with. They do could work and I can't complain about the prices either.
I believe the quote I got from a Kioti dealer was about $130 for the correct size rod. That does not incluse seals or any labor to rebuild anything...so yeah, I'm ok.
2012 VOLVO DBL SLEEPER ROAD TRACTOR (A62130)
2012 VOLVO DBL...
2015 Caterpillar 308E (A64126)
2015 Caterpillar...
2022 John Deere 5055E (A64126)
2022 John Deere...
2020 Ford Fusion Hybrid Sedan (A64557)
2020 Ford Fusion...
White Oak Boards (A65640)
White Oak Boards...
2023 SANY SY225C9C5KL EXCAVATOR (A63276)
2023 SANY...
