Ballast Will a front end loader clear these weights if used
   / Will a front end loader clear these weights if used #1
dogtired
Part number 718215036 100 lb front end weights .
Will they fit with the loader attached and will the loader clear them ?
   / Will a front end loader clear these weights if used #2
Probably not. Why would you want weights if you have a FEL? A half a bucket of dirt will be more than any weights you can put on the front.
   / Will a front end loader clear these weights if used #3
You didn't state which tractor you have but.....You cannot leave any New Holland or Midwest casting weights (new Holland clones) on the Boomer series. I have tried 100 lb and now own 3 60 lb weights. But you can put them on easy enough as I do when I remove the loader to mow. I just use clevis pins with fender washers instead of bolts to keep weights from bouncing off.
Jeff
Well flat lander :)
Will be doing work on some slopes / need front end weight for safety when working on them with the rear end pointing down hill.
Need to get center of gravity down if possible
Jeff
Sorry
I have a TC 40 A with the 16 LA loader
thanks
   / Will a front end loader clear these weights if used #7
the weights will have to come off with the loader on. I install two 100lb weights when I remove the loader and put the brush hog on for the one time a year mowing that I do. With the front grille guard on you can only fit two weights on but without the front grille guard you can attach an extension that will allow up to 5 weights to be used; again all without the loader installed.
I use a twin spindle cutter that weighs about 750 lbs bechind my TC40 and mow on hilly ground and it was ok with the 200 lbs but I would have peferred 400 lbs.
2016 PETERBILT 365 (A58214)
2016 PETERBILT 365...
2011 Kubota KX080-3 Midi Excavator (A56857)
2011 Kubota...
SKIDDED FRAC TANK (A55745)
SKIDDED FRAC TANK...
2025 GPS Trailer (A56859)
2025 GPS Trailer...
UNVERFERTH 330 8 AND 1/2 INCH EXTENSION STUB TUBE WELDMENT FOR FRAME (A55315)
UNVERFERTH 330 8...
Enclosed Service Truck (A55788)
Enclosed Service...
