Storage areas on the Kioti
/ Storage areas on the Kioti #1
curly
Union, SC
2013 Kioti CK35 HST
Anybody got any handy tool boxes mounted to their Kioti. Or other ideas for storing handy tools on the tractor as you work, shovels, chain saws etc. See a lot of JD pictures with their solutions, I'd love to see some Kioti pictures/solutions. The only place I can think to add a tool box is to just remove the small one from behind the seat and put a larger one there. The Kioti doesn't seem to have a handy place to actually mount anything.
Thanks,
Curly
/ Storage areas on the Kioti #2
That is what I have seen when there had been pics of storage areas that people have added to their Kioti's. I believe someone mentioned a certain model # of a tool box from ACE Hardware fit perfectly and was way larger that what the factory mounted. I can't remember where it was posted though :(. I know some guys also fabricated brackets to hold shovels and some small hatchets. Maybe they will chime in and post there pics again.
/ Storage areas on the Kioti #3
Sportsman's Guide Medical Boxes mounted on the rear fenders of my LK3054. They hold bungees, wrenches, pins, small hammer, etc. Two is always better than one and it keeps the machine balanced too ;)
I wish my back fenders were flat like that. Seems like every spot on my DK55 is curved in some way or another...so as not to allow anything to be attached. :rolleyes:
/ Storage areas on the Kioti #5
The wimpy toolbox on my CK30 was in the way of my b/h seat, so it had
to go. I installed one of those cylindrical plastic manual holders with the
screw top on the back of my driver's seat. Of course, I do not have a
SMV reflector there. I have a few wrenches and screwdriver in there.
On the subject of chainsaw scabbards, I have seen several posts of nice
scabbards, but there is no flat place to put one on my tractor. I recently
made a carryall box to fit on top of my hood guard. I will take some pix.
Thanks, pics are good. :D
/ Storage areas on the Kioti #7
I will try and get a picture later, but I found a little black plastic tool box mounted under the left side (sitting on the tractor) floorboard that is big enough for some small wrenches & screwdrivers. I never knew it was there until the last oil change when I just happened to see it out of the corner of my eye. Neat little spot for it but it is not very big.
/ Storage areas on the Kioti #8
put giant vertical french ammo box in place of original tool box on ck30hst, picture somewhere in this forum several years ago. got it from sportsmans guide.
painted it orange, works great.
mike
/ Storage areas on the Kioti #11
Here is my emergency tool storage box. The b/h seat was in the way of
the original. I just keep a few tools in there.
/ Storage areas on the Kioti #12
For larger items (chainsaw, helmet, chains, snatch block, etc.) I use this
quick-attach carry-all box. It mounts on top of my hood protector with
a few brackets and wing nuts.
/ Storage areas on the Kioti #13
This was the best solution I could come up with. 4" PVC pipe with a screw cap bolted through ROPS with 1/4" carriage bolts, acorn lock nuts on front. Carries all I need when away from the shop.
3 Point Hitch Root Rake (A65579)
3 Point Hitch Root...
3-Pt Hydraulic Post Driver (A66408)
3-Pt Hydraulic...
2007 Allmand Max-Lite ML20 20KW Towable Light Tower (A64194)
2007 Allmand...
John Deere 950 Tractor (A65579)
John Deere 950...
UNUSED 2023 JCB S3246E ELECTRIC SCISSOR LIFT (A65053)
UNUSED 2023 JCB...
2018 Bell B30E 30 Ton Articulated Dump Truck (A64194)
2018 Bell B30E 30...
