mahindra 2015 4wd 4x4 question,,,
   / mahindra 2015 4wd 4x4 question,,, #1
bandit99
Maine
bx 2200
would the tractor be able to handle a 4 ft rotary cutter for light bush-hogging? I saw on one website that they sold a light duty 4 footer that required only 15 hp min. Got a chance to buy a used 2015 right but it has to be able to handle light mowing with a rotary cutter. Thanks for any replys. Hopefully I'll hear from someone who has one!
   / mahindra 2015 4wd 4x4 question,,, #2
Yes, it will handle the 4 footer in light applications.
   / mahindra 2015 4wd 4x4 question,,, #3
That 2015 has a 20 hp engine at 17.5 hp at the pto. About the same as my 2005 Kubota B7510HST that I used with a 4-ft King Kutter rotary cutter in 4-ft tall weeds with no problem. Just have to move slowly and take your time with the mowing.
BTW: I traded that 7510HST last March for a Mahindra 5525 (54 hp engine, 45 hp pto) with the ML250 FEL (6-ft bucket). Mahindra's are nice machines.
   / mahindra 2015 4wd 4x4 question,,, #4
No problem whatsoever. The engine in the 2015 is rated at 23 HP in almost all applications, as this is a common Mitsubishi industrial engine. Mahindra/Mitsubishi rated it at 20 in this tractor for some reason. Our dyno shows 20 HP at the PTO on this model, so about 23-24HP is what we are seeing. The new 2015's ae called 2216's, reflecting closer to accurate HP ratings.
   / mahindra 2015 4wd 4x4 question,,, #5
I have the model you are looking at, I have used it for hogging no problem
   / mahindra 2015 4wd 4x4 question,,, #6
Here is the stuff I have been cutting with mine
   / mahindra 2015 4wd 4x4 question,,, #7
I have a 2015 4WD. It does very well with the 4 foot hog. Power is not an issue. I have also used a 5 foot hog, and it handled that fairly well too. The issue with the 5 footer is more the weight than anything else. I'd go with the 4 footer.
Thanks for the replies,,, The pics really helped. That is much more than what I would be mowing. Have a chance to buy a used 2007 Mahindra 2015 (gear) with loader and 73 hrs for around $8000. It has a home made plow attached to the fel. Have had a JD 790, so I wasn't sure it would enough power.
   / mahindra 2015 4wd 4x4 question,,, #9
Sounds like a good deal, mine was around $10k new.
2018 Toyota RAV4 Hybrid XLE AWD SUV (A50324)
2018 Toyota RAV4...
LOT LOCATIONS (A51219)
80in HD Tooth Bucket with Side Cutters (A51039)
80in HD Tooth...
2001 STERLING WATER TRUCK (A50458)
2001 STERLING...
2015 JEEP PATRIOT (A51406)
2015 JEEP PATRIOT...
PALLET OF BRAKE AND AXLE PARTS (A50854)
PALLET OF BRAKE...
