Getting a free 3PH Log Splitter - need help
/ Getting a free 3PH Log Splitter - need help #1
keving
Gold Member
Virginia/WV
Kubota 7040HDC
Folks,
I'm fortunate that a friend of my sister is going to give me a 3PH log splitter that is about 20 years old and not too much use. I know that there will likely be some repair needed and I plan on changing the hydraulic fluid.
I have a Kubota 7040 with two rear remotes and next to no hydraulic knowledge. I realize I will need the appropriate connectors but I know there are going to be flow issues because my remotes are controlled in the cab.
Guide me o' wise ones....
Thanks for all your help!
/ Getting a free 3PH Log Splitter - need help #2
Put the appropriate quick connects onto the splitter, and use a bungee cord (or similar apparatus) to hold that valve open to provide the flow to the splitter.
No problem with flow rates?
/ Getting a free 3PH Log Splitter - need help #4
You should have no problem with flow rates from your tractor-do you know what the GPM rating for your machine is?
The bungee cord idea is the best way to get power to your splitter, just make sure it's plugged in first.
/ Getting a free 3PH Log Splitter - need help #5
I have 2 remotes on my CK30, one of them needs a bungee cord to hold it in position, the other has a detent that holds it in place. That is the one I use for my backhoe. Maybe you have a similar setup, check to see if one of the valves has a detent or lock to hold it in place and use that one.
/ Getting a free 3PH Log Splitter - need help #6
If it were given to me the first thing I would do is take all the hoses off and drain the fluid from them and the cylinder also. Who knows what is in it and is it compatible with the fluid in your tractor? Also is it contaminated with water or worse?
Chris
I think mine is similar... I'll check. Thanks!
/ Getting a free 3PH Log Splitter - need help #8
I find that valve detents usually are designed to cause the lever to pop back to neutral as pressure rises - sometimes at significantly less than relief pressure. For the log splitter you may get nuisance trips unless you bungee it.
larry
2019 HAULOTTE 5533A PORTABLE ELECTRIC BOOM LIFT (A65056)
2019 HAULOTTE...
CAT D6R Straight Blade (A68134)
CAT D6R Straight...
2012 Ford F-250 Crew Cab Pickup Truck (A64556)
2012 Ford F-250...
2007 WESTERN STAR  4900 TRI AXLE (A67714)
2007 WESTERN STAR...
2018 GENERAC MOBILE PRODUCTS MLT6S (A68842)
2018 GENERAC...
ROBINAIR MODEL 34788NI AC RECOVERY UNIT (A67714)
ROBINAIR MODEL...
