Improve Hydraulics on JD 1050
   / Improve Hydraulics on JD 1050 #1
jgbanshee
Gold Member
PA
JD 310SE, 325G, 35G, 4300, 5300, 5210, 445, 450 Crawler, CAT D3B, Ford 2N, 7000, 5000, 4000su, 3610, 445D, 345C, 340B, 1100
Has anyone did anything to improve the hydraulics for the loader on a 950/1050? My loader (#80) just moves so slow. I know the pump is only putting out 6 or 7 i think GPM. I have changed the hydraulic filter.
   / Improve Hydraulics on JD 1050 #2
There is no magic cure for speed...to go faster you need more flow-a higher output pump, which is not going to be easy or cheap since it's directly coupled to the engine.
   / Improve Hydraulics on JD 1050 #3
You might try using larger couplers on the loader connections. Mine are the smaller ones, not JD or ISO sized. Be sure to check the metal piping for dents and kinks. My front weights got caught up in the piping there an kinked them. Really slowed the loader drop-down. Listen for whistles and gurgling sounds when unloading: That should tell you where the restrictions are....
   / Improve Hydraulics on JD 1050 #4
Actally its smaller lines and fittings that will accomplish faster cycle rates.
   / Improve Hydraulics on JD 1050 #5
Can you please elaborate on that statement:confused:
   / Improve Hydraulics on JD 1050 #6
Smaller pipes theoretically increase reaction time, but on the 80A loader lines, they are quite restrictive (i.e. the flow resistance is higher, so a pressure drop occurrs if there is a restrictor: as in the connectors at the 80A interface block. The ports are only about 1/8 inch. I switched to ISO size AG fittings on my 1070 and the loader drop reaction is much improved (especially after I fixed the kinks in the lines at the crossover pipe on the loader frame).
CATERPILLAR CB-224C DOUBLE DRUM ROLLER (A52707)
CATERPILLAR...
Harper TV130 3.5 Yard High Dump Turf Vacuum Sweeper (A59228)
Harper TV130 3.5...
2016 Dodge Grand Caravan Van (A59231)
2016 Dodge Grand...
2004 Saturn VUE SUV (A59231)
2004 Saturn VUE...
2022 Polaris Ranger 900XP 4x4 Utility Cart (A55853)
2022 Polaris...
FORD 8530 TRACTOR (A58375)
FORD 8530 TRACTOR...
