JD 4320 Battery Leakage and Related Corrosion
   / JD 4320 Battery Leakage and Related Corrosion #11
My new 4520 was built March 31, 2008. I will check it and report back.
D.
My 4520 has the new style setup. That is a nice change, my 2005 4720 was having the issue.
D.
   / JD 4320 Battery Leakage and Related Corrosion #12
Here is a photo of the new style JD battery. The vent tube is connected to back corner of battery and goes down thru the flat and discharges to the ground.
I have to go look at mine again. I thought I saw the vent tube on the (passenger side of the tractor). As in if I am standing in the front looking at the battery it is on the left rear. Where is your vent tube again?
D.
   / JD 4320 Battery Leakage and Related Corrosion #13
D.
Standing in front and looking at the battery, the vent tube would be on your right side (see picture above). The dealer drilled the hole (per drill filings) for the vent tube. My new battery has a nipple on both right and left rear sides where the vent tube can be connected and the opposite nipple/connection has a soft vinyl cover on it. I noticed a plastic plug in the metal floor plate on the left where the tube could have gone down thru -- not sure why he chose to put it on the other side.
   / JD 4320 Battery Leakage and Related Corrosion #14
Cool Mine is vented to the other side.
D.
   / JD 4320 Battery Leakage and Related Corrosion #16
   / JD 4320 Battery Leakage and Related Corrosion #17
Tn, which Optima model (group) did you use and what specific modifications did you have to make?
If I'm not mistaken it's the group 34 red top. The Optima is just a tad bit bigger than the factory battery so when the mounting plate goes back on the holes are off. I took a drill and elongated the holes on the plates. This allows the bolts room to screw back into the original holes. The hood opens and closes the same and no problems with the hood latch which is on the plate. I may have a picture of the holes and will post if I do.
ETA: Sunnyside360, I guess you can tell I don't log on much. I'm just now getting your PM's from back in July. Sorry about that.
   / JD 4320 Battery Leakage and Related Corrosion #18
Tn, I received your PM and will go with the Optima Red Top Group 34 if/when necessary . Hopefully your problem is solved. Please let us know of any future problems with the Optima. Many thanks for the info.
   / JD 4320 Battery Leakage and Related Corrosion #19
Here is another pic that shows everything lines up as it should.
20ft Jumper Cables (A57454)
20ft Jumper Cables...
Forklift (A59228)
Forklift (A59228)
Aluminum Horse Colt (A57454)
Aluminum Horse...
Roll of 2-inch Vacuum Hose (A57454)
Roll of 2-inch...
Werner 14ft Fiberglass Extension Ladder (A57454)
Werner 14ft...
2025 KH72 72in Hydraulic 4-Way Clamshell Bucket Skid Steer Attachment (A56860)
2025 KH72 72in...
