2305 MMM making bad sound....
/ 2305 MMM making bad sound.... #1
mattasimms
First time posting ...LONG time reader!
I have a 2305 with a MMM and just started using it today for mowing (new construction and new sod), but have had the tractor for about a year and a half now.
What is happening is the MMM is making a vibration and noise when i go around certain turns or put it in reverse. I can not see where the blade is rubbing on the frame of the deck, or where the belts and pulleys are causing any damage. I did take off the covers for the pulleys and wash all rocks and dirt out of here. I mowed for about an hour and nothing i can find is rubbing.....is it ust out of line and the belts are causing the vibration? It also sounded real bad when i hit the brake (it was almost like something that touches the brake pedal linkage may be in the way of the belts...
Thanks for your help!
MS
/ 2305 MMM making bad sound.... #2
MS
Welcome to TBN!
Maybe a blade is bent?
D.
/ 2305 MMM making bad sound.... #3
When i had my 2305, it made the same kinda sounds on steep hills (going sideways). In my case, it was the pulley rubbing against the lift arm. I never found a way to solve my problem but it went away when I upgraded to the 2520 :eek:
/ 2305 MMM making bad sound.... #4
TAKE IT TO THE DEALER!!!!! mine was the mid pto shaft hitting the brake lever pivot...updated kit for the problem. have them call d-tac at deere if they are clueless. make sure your deck height is adjusted properly also lead to same concern(never adjusted RIGHT from day 1!!)
2007 PETERBILT 386 (A65643)
2007 PETERBILT 386...
2021 Big Tex 14ET 18' Tandem Axle Trailer (A62679)
2021 Big Tex 14ET...
NEW, ATS Mini Excavator (A62679)
NEW, ATS Mini...
Kubota V3300-T Turbo Diesel Industrial Engine  84 HP  Pump Takeout (A63689)
Kubota V3300-T...
New/Unused AGT 3000PSI Hot Water Pressure Washer (A65583)
New/Unused AGT...
211453 (A62131)
211453 (A62131)
