Branson 3510i PTO question
/ Branson 3510i PTO question
Has some debris got caught in the shifter linkage?
Just a mite of a splinter from when I hit some dead branches that somehow took a magical path is all it took to lockup the shifter! Dead on analysis, thanks a ton.
/ Branson 3510i PTO question #24
This is a great site I have been reading for a couple of days. Since you own a Branson tractor I have a question about a pending purchase of a Branson, 2004, 4220 with loader and backhoe. The tractor has 500 hours and appears to be in very good condition. The dealer has it for sale. I have two concerns and would appreciate some advise. The dealer did a clutch job after taking the tractor on trade-in. Would you be concerned about the tractor needing a new clutch at 500 hours? Finally, I am familiar with the major tractor brands but not with the Branson. Do you know any reason why I should not buy a Branson? I have a deposit on this tractor and must make a decision by Monday. Thanks, John
/ Branson 3510i PTO question #25
I have a 2004 Century 3040 which I believe is similar to the Branson 4220. I bought mine used also and now have about 280 hours on it. I've owned it for about 2 years now and it's been a great tractor with plenty of power and made really heavy. I had to do some adjustments to my cluth when I first got the tractor since the original owner never once used the PTO but that's all I've ever had to do to it . I don't know what to say about the clutch replacement at 500 hours . All I can tell you is that I don't regret buying my tractor and if it's a good enough deal I would go for it.
/ Branson 3510i PTO question #26
Clutch life is probably 60-95% controlled by driver. I can give a good example-
I was in the ARMY in Germany in 1968. I was a Courier, they gave me a new 1968 Chevy 1/2 PU with 500 miles on it. I was the only driver, I kept the key in my pocket. I turned it in for a new 1969 PU. It had 35,000 miles on it and it would still squeal tires on a hard second gear shift.
Another driver for another Battalion got an identical truck. They put three clutches in his with similar mileage and time period.
/ Branson 3510i PTO question #27
Absolutely the driver is the key to the clutch life. Loader work is also harder on a clutch than normal starting and stopping. A good operator knows how to use the momentum of the machine to aid the starts and direction changes when using a loader that makes every thing much easier on the clutch. I have a 2004 Century 2535(400 hours) which is the same as a 3510 Branson. For a compact tractor it does an amazing amount work. w jones
2004 Mack CH613 Concrete/ Water Mixer Truck (A64194)
2004 Mack CH613...
2007 Honda CR-V AWD SUV (A64557)
2007 Honda CR-V...
2016 Ford F-250 Ext. Cab Pickup Truck (A64556)
2016 Ford F-250...
2015 Chevrolet Impala Sedan (A64557)
2015 Chevrolet...
2014 Chevrolet Tahoe SUV (A64194)
2014 Chevrolet...
3097 (A63117)
3097 (A63117)
