OBD 2 codes
/ OBD 2 codes #1
kenmac
Super Member
The Heart of Dixie
McCormick CX105 Kubota MX 5100 HST,
My son has a chevy s-10 PU (4.3 v 6)
My code reader states code P0420 Which I believe is an 02 sensor.(Catlyst system efficiency below threshold Bank 1) Anyone which side of the vehicke is considered bank 1 ? Drivers side passenger side ??
Thanks
/ OBD 2 codes
Drivers side.
Thanks,
That answers why I'am still getting the code. I replaced the passenger side ( as I didn't know what were calling Bank 1). I won't buy another I'll just swap it out. I didn't throw the 1 I took out away
/ OBD 2 codes #4
my daughter had the same truck and engine.these engines are notorius for cataletyc converters going out we rreplaced hers twice .if i remember right that was the same code we got
/ OBD 2 codes
I hope it's not the cat. converter. The sensor was only $80.00. I'll know if I swap sides with the sensor & still get the same code. I wish the codes were a little more specific. I have a haynes manual on that truck . I'll look & see if there is any info. specific to that code
/ OBD 2 codes #6
Cat codes generally mean the cat is bad. The O2s are tested separately and have their own codes. Maybe you'll get lucky though. I use oem replacement cats cause I've had some comebacks with aftermarket units for GMs.
/ OBD 2 codes
Well I found it in my haynes manual. That code is in fact for the cat. I didn't know that my son had a muffler shop to install a high flow cat. to go along with his dual muffler set up. After talking to a guy at another muffler shop.He says, The high flow cats. aren't a match for the computer.So, the computer says (or thinks) the cat . is bad.Thanks for all the replys
/ OBD 2 codes #8
You might want to talk to your dealer and have them flash your trucks computer. But, then it might be even worse. I had to flash my Venture once to keep the oxygen sensor from coming on all. :D
/ OBD 2 codes #9
Also a "unofficial" option is a o2 spacer, this lifts the o2 sensor out of the exhaust streame and fools the computer. I see these on tuner cars a lot, where they have exhaust mods.
RalliTEK O2 Sensor Spacer
Re-flashing generally won't work, the re-flashes are meant to refine the cars function with OEM equipment/problems, not aftermarket mods
/ OBD 2 codes #10
Don't forget to use the O2 spacer on the downstream O2 not the upstream :) I don't use them but I have seen them on Subees.
/ OBD 2 codes #11
LOL, Guess what kind of shop I work at? :)
3 years ago I went through a class that played with the rear o2 sensor, sent false info into the computer. End result, A rear o2 sensor can control fuel trim more than the manufactures tell us. After that class, I became a firm believer in not adjusting what the engineers made. Ford is starting a data called "aft fuel trim" on their scan tools.
/ OBD 2 codes #12
It's a lot cheaper to just go to your local auto parts store and buy the $2 "anti-foul" plug spacers. You might have to drill the centers out and screw 2 together to get the increased depth necessary.
2003 International 7400 T/A Dump Truck (A66736)
2003 International...
1 PALLET OF HYDRAULIC HOSES (A66091)
1 PALLET OF...
AG Tires - 11.00-16SL (A68134)
AG Tires -...
DYNAPAC  CP271 PNEUMATIC ROLLER (A67714)
DYNAPAC CP271...
PORTA POTTY (A68842)
CATERPILLAR 312D EXCAVATOR (A65056)
CATERPILLAR 312D...
