Front-End Loader Box Blade VS. rear angle blade VS. FEL for dirt driveway
/ Box Blade VS. rear angle blade VS. FEL for dirt driveway #21
schmism said:
for those of you in the box blade camp.
Does the county road dept maintain there roads with a earth moving scraper?
or with a (angle) road grader?
when it came to road/driveway maintance, you couldnt give me a box blade to use over my RB3572 rear blade. Makeing crown, pulling loose material from the edge back to the center, cutting ditches.
Shure some of that can be down with a box blade, but youll have a h3ll of a time pulling loose material from the edge back to the center with a box.
In the winter its much more effective at moving snow than a box blade is.
The grade master blades my be great for smoothing a road. but suffers all the same draw backs that a box blade do.
I couldn't agree more about the superior results with an angle blade. Every once in a while my neighbor, with a Kubota Grand 3130, hooks up his 5' box blade and ruins part of his driveway by grading it flat. It has no angle adjustment , and he is severely limited in his ability to do anything but make the road worse. Using a box blade with no angle adjustment makes it quite difficult to crown a road.
My angle blade does not have gauge wheels, but if you pay attention to what the implement is doing, I don't feel they are a necessity. If I had a lot of crushed rock on my road, I would prefer a 7 ft. landscape rake, set on an angle.
/ Box Blade VS. rear angle blade VS. FEL for dirt driveway #22
Box blades reposition dirt very well by adjusting the angle with your link arms... just not as far over as an unboxed blade does. You cannot get good results if you use it level on anything but your final smoothing over on a road... level the whole time and you just eat up your crown... have to give running water a fast exit off the road.
Scarifiers are something which is essential to dig the compacted base out your potholes to allow drainage to resume there--usually 1-4 softball to volleyball sized rocks under every one as well... we have lots of rocks in Maine:( Also they raise substrate when the surface has compacted super-hard to redistribute over the surface.
I feel your pain trying to do that work with a FEL--man, I would never even attempt that!
Just by virtue of versatility, great ballast on the back as a counterweight in a compact form, I would make the boxblade the first purchase.
/ Box Blade VS. rear angle blade VS. FEL for dirt driveway #23
I've used a boxblade for 3 years exclusively maintaining my 1/2 mile long road. It can be done if used properly. You might want to check out this thread Various Boxblade Uses. That said, there's a difference between maintaining and building or repairing a dirt road. I chose the boxblade because of it's versatility for many other uses, but it is not necessarily the best or only implement to use on a dirt road. At the time, I could only afford one implement of that kind.
For smoothing an existing road, I think that implement Brian (MtnViewRanch) suggested is one heck of a road grader. I can see the inherent advantage of getting a really smooth surface on an existing road with a decent crown and in fairly good shape with little or no trouble, providing excellent results without gauge wheels I can see that the design has some limitations trying to use it to do other tasks with it. It is appropriately named as a road grader because that's what it does best.
A rear blade gives the advantage to windrow or move material from one side to the other by angling and tilting the blade. I would consider this more of a shaping and moving implement. A lot of guys choose this implement in snow country for it's advantages there. It is very versatile and can be used for many other applications as well, but again, not necessarily the best for some applications. I have a good friend who swears by his. Used with gauge wheels, I can see excellent results in getting a smooth surface once the road is ready for smoothing.
The boxblade, IMHO, is the most versatile of all, but not necessarily the best for some applications. But like I said, it can be done. I've used mine not only for maintenance, but also to make new roads and trails. It can also move dirt and shape the road using various techniques. I use mine to cut deep gutters along both sides of my long dirt road and then to crown the road too. There are lots of photos in that link I posted above. I've got my road now to where just dragging it to smooth the road is all I need to do. If you needed to get it smooth from the start, gauge wheels on the boxblade gives excellent results like with the other blades.
They all have their advantages and drawbacks, with each one excelling in its specific design use, but some are more versatile than others. There might be other things you want that tool to do? That is why I chose the boxblade. It's sort of like having 3 sizes of screwdrivers. I guess that's not a very good analogy and hopefully someone will post a better one, but you get the picture.
/ Box Blade VS. rear angle blade VS. FEL for dirt driveway #24
You sent a picture? I didn't get the picture. I'm bummed that I don't get the picture. :rolleyes: :D
/ Box Blade VS. rear angle blade VS. FEL for dirt driveway #25
Wise guy.:D
Do you still have that grader for sale Brian?
I'll bet you could sell that to someone here after they see some of your finish grading on your road.
/ Box Blade VS. rear angle blade VS. FEL for dirt driveway #26
I'd like to know more about how it works...how does it work better than a box blade? Got any other pictures of it? Say... with dimensions and angles?:D
/ Box Blade VS. rear angle blade VS. FEL for dirt driveway #27
3RRL said:
Wise guy.:D
Odd that you ask that question. Just today I bought the 2 that a local dealer has had for, well since time began. I felt bad for them, they are in the industrial end of equipment and have no one to sell them to. (except me) I have tried to help sell them for them with no luck, so I bought them to help them out and will try to sell them myself. I have a 5' and 7'. I think that you should buy the 5' for Loretta and let her finish grade your road. I'll even paint it black and Honeybee Yellow.:cool: :D
/ Box Blade VS. rear angle blade VS. FEL for dirt driveway #28
Here ya go. Mine is considered a 7 footer. Actual width is 89". 24" sides. 84" long. Two blades extend 1" below sides at about a 20-25 degree angle side-side. Weighs in around 1400-1500lbs. I pull it with my 75 horse 7520 Mahindra that weighs just under 14000lbs with the loader and road scraper. A couple of reasons that it works better than a box blade is that it has 2 blades on an angle, long sides to help keep the blades from moving up and down as much as a 2' box blade will. The angled blades work great for removing wash boarding. This thing is like pulling a 7' square down the road, instead of a 7' x 2' rectangle. Shear size helps smooth better.
I currently have a 5' and 7' for sale.
/ Box Blade VS. rear angle blade VS. FEL for dirt driveway #29
Whether you use a box blade or rear angle blade or your FEL (probably last choice), to build or perform rough grading of a driveway, I believe that the best tool without a doubt to MAINTAIN one is a landscape rake fitted with gage wheels. As you indicate you have a stone/gravel mix, it will work excellent. In fact, I believe you will like the results so well that you'll be out there frequently, just because it is so easy and fun to do a good job. Get one that allows you to angle the rake so that you can maintain a crown.
/ Box Blade VS. rear angle blade VS. FEL for dirt driveway #30
i will conceed that for building or repairing a heavily damaged (read washed out, or sever pot holes etc) a box blade is going to do the work quicker.
but i still stick to my "rear blade is best for maintaining a gravel drive"
/ Box Blade VS. rear angle blade VS. FEL for dirt driveway #32
OK, so the front blade cuts in 1" deep, the "spoils" go over the blade and then the rear blade fills in/levels with them. Right? The rear blade tip is level with the sides?
/ Box Blade VS. rear angle blade VS. FEL for dirt driveway #33
On the units that I have, both blades are 1" below the sides. I don't know about other makes.
/ Box Blade VS. rear angle blade VS. FEL for dirt driveway #34
Mtnview,
Did you say that you don't have the roadboss after all? Any idea on what the difference is between yours and the road boss if so?
/ Box Blade VS. rear angle blade VS. FEL for dirt driveway #35
Charlesaf3 said:
Mtnview,
I found out that I don't have the Road Boss back in Feb at the Tulare AG show. I stopped at the Road Boss booth and was talking to the owner telling him how great the graders are and that I have sent him many customers and asked him when he had changed the style of their grader.:) He sort of gave me an odd look and asked what did I mean by change.:confused: I said that your hitch now bolts on and mine is welded on and my sides are about a foot longer than the new graders. (He happened to have a 7' model there on display, same width that I have) He said that I didn't have a Road Boss,:eek: but that I most likely had a Road Master blade and that they were the closest to his than anybody else's blade.:) That they were actually heaver than his,(because of the longer sides) but that the Road Master didn't have replaceable skid shoes and that the Road Boss was the only grader that had double sets of holes punched in the blade mount so that the cutting edges can be lowered thus doubling the life of them. Had nothing bad to say about mine,:) just that the Road Boss had better serviceability, (bolt on skid shoes and 2 locations for the cutting edges). He also mentioned that the Road Master guy had gone out of business.:( One of the things that he did mention was that a lot of other light weight blades are out there and that they just don't work as well as a heavy grader blade.
Anyway, it looks like I do not have a Road Boss Grader , but I will continue to recommend them because they are a good implement to have to maintain a dirt road in my opinion. ;)
One last thing, I have a 5' & 7' Road Master for sale if you know anybody that needs one.:D
/ Box Blade VS. rear angle blade VS. FEL for dirt driveway #36
MtnViewRanch said:
The better it works and the easier it works, the more money it costs. I have never seen anybody that bought a $350 implement and have it work like a high dollar one. You usually get what you pay for when it comes to attachments and implements.
Now there is a very very accurate statement!
/ Box Blade VS. rear angle blade VS. FEL for dirt driveway #37
Thanks Mtn view. I take it you like the road master as well? Longer sides seem better at a guess...
Would shipping the road masters out to the East Coast be a pain?
/ Box Blade VS. rear angle blade VS. FEL for dirt driveway #38
Also, do you think putting rear wheels on the road boss/road master would help, by lengthening it even more?
/ Box Blade VS. rear angle blade VS. FEL for dirt driveway #39
I would say that I don't feel that the Road Master needs any altering what so ever. It has worked great for me so far. I am planning on using it quite a bit this weekend, I will get a few pictures.;)
I have borrowed a 5' grader blade & have been trying that out. There is a bend in my driveway (as in, it isn't straight) so rather than crown it I've decided to "tip" it to one side so the water will run off the one downhill side. One thing I have noticed is that the blade is too narrow for my liking when you have it angled all the way. I found a guy about 40 minutes from me that buys & sells tractors & tractor implements for a hobby. He has brand new 7' grader blades for $375 so I might buy one of them so I'll have my own. He had box blades there too but he said it wouldn't do what I wanted. The way he explained it to me it sounds like a box blade is like a giant hand plane. He said it is good for moving a bunch of material from a high area to a low area but not good for doing my driveway. He said before I got to the top it would be full of material then I'd have a big pile of material half way up the driveway. Also wouldn't be able to pitch driveway.
Tell me more about a York rake. I think he had some of those too. I thought those were for collecting rocks from the dirt.:confused:
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A61307)
2023 Unverferth...
1999 John Deere 7810 (A60462)
1999 John Deere...
2012 INTERNATIONAL 4300 CHEM TRUCK (A60736)
2012 INTERNATIONAL...
2022 New Holland C327 Compact Track Loader (A61307)
2022 New Holland...
2020 BOBCAT E42 MINI EXCAVATOR (A60736)
2020 BOBCAT E42...
2017 FORD F-550 SERVICE TRUCK (A58214)
2017 FORD F-550...
