Tiller agric tiller question
/ agric tiller question #1
dogranch
haralson county georgia
branson 3820
I bought an Agrice AFMJ 70 tiller off my brother IL and dont have a manual.
I searched the forums to find the wieght of the oil for the chain bath but cant find how much. There is a fill plug on top and a drain near the bottom and about
half way up the chain cover. Being young and inexperienced i figured one of the wiser people out there could give me a recommendation on how high to fill it. I am trying to get my lot tilled up before the spring grass planting season is over and dont have time to get a manual right now. I'm sure someone has some piece of equipment that would have the same set up and know an amount of oil to put in it.. I'm guessing dump it in the top till it starts to flow out the middle.
Any recommendations appreciated. I can get pics later if that helps.
thanks
dogranch
/ agric tiller question #2
I'd say your plan of pouring gear oil in at the top and stopping when it spills out the hole halfway up, is a good one !
/ agric tiller question #3
The chain cover has 3 plugs. The one at the top is the vented fill plug. The one in the middle is used to check the tension on the chain. The lowermost plug is the full plug. To fill the chain housing, remove the top and lowermost plug. Pour the oil in the top until it comes out the lowermost hole. Replace both plugs. remove the middle plug and check the chain tension.
The bolts on the bottom of the chain cover must be loosened (or removed) to drain the oil or an oil drain pump can be used.
A better way to apply the proper chain tension is:
1. Raise the tiller off the ground.
2. Disconnect the PTO shaft at the tractor so you can spin the tines by hand.
4. Back out chain tension bolt so tines can spin freely by hand.
3. Spin the tiller tines by hand checking for "freeness".
4. Tighten the chain tensioner bolt until the tines become harder to spin by hand.
5. Back out the chain tensioner bolt 1 turn and set lock nut.
Chain should now be at propper tension.
By the way, a good place for replacement parts is DN Equipment. They have tines, chaines, sprokets, chain covers, etc.
I have an owner's manual for my AL50 at the office. I e-mailed Agric and they e-mailed the manual to me. I will download it to this post on Monday.
thanks for the help rocking g. i'll set it up tomorrow and see how it works. It seems pretty old but looked more heavy duty than other brands and for 700 bucks it was better than a new one and i'm sure will pan out better than the grey rice patty models.
/ agric tiller question #5
This for Rocking G,
Any possibility of getting a copy of the manual? I have purchased a used tiller also w/no book of course. Thanks for any help you can give. jm4650@hotmail.com
/ agric tiller question #6
Hopfenmuller,
I have the manual on my computer at the office. I cannot download to this forum because of the size - I even tried to zip it. I have to send it to you personal e-mail tomorrow morning.
/ agric tiller question #7
Good Buy!:thumbsup: I have an Agric 65. 80/90 in gear box. watch for leaks inside as there is a seal that can go bad. the other end is a greased bearing. Tough units, I run mine on a B7800, almost too big for it but she handles it ok. Be careful when backing up so you don't damage the flap in the rear. If the chain comes unhooked and you don't notice it you can bend the heck out of it.:(
/ agric tiller question #8
hopfenmuller,
fresh to this site, and still not sure how it works. however was wondering if you happen to still have the manual for the AFMJ 70 Tiller? if you do could you please send a copy to my email: biggmannn411@aol.com
thanks in advance!
/ agric tiller question #9
Hopfenmuller,
Rockin G,
I was wondering if you happen to still have the manual for the AFMJ 70 Tiller? if you do could you please send a copy to my email: biggmannn411@aol.com
also had a question with your fill instructions...
judging from your instruction, it would seem, that the oil capacityl that this part of the implement requires is about 1/2 quart or less, is this correct?
i guess i can wait for the manual and see if this answers my questions. Praying you still have it!
thanks in advance!
/ agric tiller question #10
ANyone have a manual for an Agric AL 50 tiller. I need to replace gearbox bearings . And not sure how it comes a part!
Thanks Marc
/ agric tiller question #11
Hopfenmuller,
Hello,
Sorry to jump in on an old post but I am in dire need for an Agric AL series manual. I have an AL60 and cannot find my book and have looked all over the net with no luck. Would you kindly send me an electronic copy?
/ agric tiller question #12
I need to replace bearings on my AGRIC AFMJ70. Anyone have a parts manual?
/ agric tiller question #13
I am out of the country until next week. I think I still have the Agric Tiller Manual on my computer but it is too big to download to the forum.
If you would like a Manual please PM me your e-mail address so I can send it to you. The earliest will be next week when I return from over seas.
2020 GMC AT4 CREW CAB TRUCK (A65054)
2020 GMC AT4 CREW...
2020 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A61568)
2020 Chevrolet...
42in. Pallet Forks (A65640)
42in. Pallet Forks...
2004 International 4300 ASM Altec AM855 55ft. Bucket Truck (A64194)
2004 International...
2024 JOHN DEERE TURF GATOR TX 4X2 UTV (A63276)
2024 JOHN DEERE...
International 130 Manure Spreader (A66408)
International 130...
