What does power-beyond really mean?
/ What does power-beyond really mean? #1
quicksandfarmer
Elite Member
Coastal Rhode Island
Jinma 354, purchased 2007
I bought a new Prince valve recently, which can be configured as open-center, closed-center, or power-beyond. I was surprised to read the following description of power beyond in the instructions:
This option provides both an outlet and a power beyond port (also referred to as a high pressure carry over port). This allows another valve to be connected downstream. When all the spools of a RD-5000 series valve are in neutral high pressure oil can go through the open center core and out the power beyond port to the inlet of downstream valve. The downstream valve only receives oil when all spools of the first valve are in neutral. This option must be used with open center spools and the outlet of valve must be connected to tank.
A couple of things about this description don't jibe with what I thought I knew about power-beyond.
This sentence is ambiguous, but one way of reading it is that without power-beyond you can't connect another valve downstream. My understanding is that the whole point of open-center devices is they can be used in series.
This doesn't sound quite right either. My understanding is that the point of power-beyond is to overcome the shortcomings of open-center when using more than one valve at a time.
In the valve specifications, it says maximum tank pressure 150 psi, but it doesn't specify in which configuration. In an open-center circuit, a valve has to take full circuit pressure on its outlet, unless it is the final one in the circuit.
The instructions are not terribly helpful, but I get the feeling that they're recommending that power-beyond be used if more than one valve is used in a circuit, and that the valve is not capable of being used in a true open-center fashion.
Any thoughts?
Thanks.
/ What does power-beyond really mean? #2
I'm a long ways from being a hydraulics expert, but that sure sounds right to me.
I didn't actually use a power byond port on a valve, but on my B2710, when I used the auxilliary hydraulic outlet to go to and from an open centered two spool valve for my hydraulic top 'n tilt, that was the case. Since the 3-point valve was downstream from that auxilliary outlet and the new valve, the 3-point hitch would only work if both top 'n tilt valve spools were in neutral. Of course that was no problem because I didn't have enough hands to work any more valves all at once anyway.:D
/ What does power-beyond really mean? #3
I have posted this link from Baum Hydraulics a couple times to help understand power beyond.
Hope it helps.
Hydraulic Terms and Definitions
To address this
Yes, you can hook up valves in series without power beyond, but for the reasons given in the link, it is better to use a power beyond sleeve and return to sump for each valve.
/ What does power-beyond really mean? #4
Thanks for sharing 3RRL, that is great info
/ What does power-beyond really mean? #5
That description from prince is Perfectly accurate. You have to make the distinction between outlet and PB. The term outlet as they are refering to it is the outlet from the valve returning to the resovoir. It needs to be a low pressure, basically unrestricted path to the resovoir. The most restriction it should have is a return line filter. The PB outlet is an extension of the high pressure inlet on an open center valve when the valve is in neutral(which is the only time a "open-center" valves center is "open". When it is not in neutral, The fluid is diverted to a working port and on to a cylinder or motor. The fluid returning from the cyl/motor returns thru the companion work port for that spool, and goes to the outlet/return port and not the PB port. Any fluid that goes thru the pressure relief valve also goes to the return/outlet port.
Without PB, what is normally the PB port is tied together with the outlet/return and has a pressure limit(150PSI tank pressure?). I have two 5000 series valves, and the last 5000 series pamphlet I looked at had that max return pressure at 500PSI. At any rate, you can't connect another valve downstream, at least succesfully, because without a PB sleeve, putting another valve downstream on the first valves combined return/PB port will apply full system pressure where it dosn't belong, when the downstream valve is operated.
If you look at the diagram of the PB adapter sleeve(should be in the 5000 pamplet or is available on princes website), it is a threaded tube that looks like a pipe bushing with an "O" ring out near the end. This sleeve screws in and separates the outlet/return port from the high pressure open center port and gives you that high pressure capable outlet from the center of the PB sleeve.
The reason for the pressure restriction on the return port is that the return galeries in this type mono-block valve are at the ends of the spools and the final seal for this pressure is the "O" rings at the ends of he spools which have to be free enough to allow spool movement.
My first 5000 series valve was installed incorrectly. It had the 3PH and steering downstream of that combined PB/return port. This is only a problem if you are lifting something heavy on the 3PH, such as a HD 5' brushhog, and exceed the 500 PSI return port pressure rateing. After working this new Brushhog a few hours I was introduced to a warming sensation on might right boot caused by the blown spool "O" rings on the valve pissing warm hydraulic fluid every time I lifted the 3PH and brushhog.
Here's a link that describes my understanding of how an open center circuit works:
Fluid Power Systems
(this is a Navy training manual). The description of open center begins under the heading "Fluid Power Systems," second paragraph.
The key part of this description is "the system pressure goes through each directional control valve."
This is at odds with the description in the link that Rob gave, where it says:
This sleeve outlet prevents back pressure on the exhaust or return passage of a control valve which normally is not designed to take high pressure.
(emphasis is mine)
In the diagram of open center in the Navy manual, the exhaust passages clearly are meant -- in fact, required -- to take full system pressure.
Looking at the list of purported advantages to open-center in the article that Rob linked to, the advantages assume that either the exhaust passage of the valve can't take full pressure, or there is no system relief valve. So yeah, if you have equipment that's not meant for open center, or not plumbed properly, power beyond is going to work better.
I guess what I'm realizing is that open center and power beyond are different beasts. While you can mix them to a certain extent, they have different philosophies and put different requirements upon the equipment.
What has me a little mystified is why a valve manufacturer would label a valve as open center capable, and then say the exhaust gallery can't take more than nominal pressure. That makes no sense at all.
/ What does power-beyond really mean? #7
Fluid Power Systems
(emphasis is mine).
System pressure does go thru each control valve. Each spool valve in a valve body is a directional control valve. The return ports on these monoblock valves are not designed for system pressure for the reasons I mentioned in my last post. They are just designed to provide a path to the resovoir.
In that diagram, yes they are, but that is a VERY basic drawing meant to show the principal of open center flow, and does not reflect the actual flow in a Prince 5000 series monoblock valve(or most any other for that matter).
Open Center and PB are different features, but both can easilly be on the same valve. The term open center just refers to the flow thru each spool when it is in the center position. With the valve spools in the center position, there is no restriction to the flow and the fliud flows thru all the spools like the valve body is a piece of pipe. With open center, you only build system pressure when you move a lever and perform work with a hyd cylinder. When the levers/spools are in the center, there is no pressure, just high flow and no load on the engine which saves fuel.
An open center valve can be PB capable, or not depending on the manufacture. Without power beyond capability, it must however be the last valve in the system and it's outlet, a combination of the flow from the open center gallery and the returns from the work ports and the safety relief, must have a unrestricted low pressure path to the resovoir.
The valve is open center(with the correct plug in it's side). If you want to put another valve downstream of it however, you need the $13 PB sleeve from surplus center to separate the high pressure capable flow of the open center, from the low pressure return/relief gallery.
/ What does power-beyond really mean? #8
RonMar is exactly right. I have frequently seen photos and examples of loaders, which are hooked up incorrectly, even on dealer installs. If you have a FEL installed on your tractor, have an open center system and you have a 3 pt hitch, then you almost always should be using the PB port of the loader valve for the the 3 pt. (The exception could be if you are using the PB port of the 3 pt to operate the loader valve.
If your tractor is OC, with FEL and 3pt, AND the FEL valve has 6 lines to it then it is NOT using the PB port to power the 3pt (or any other valve down stream). If it has 7 lines then it is using a PB to power the 3pt or other valve. [4 lines for cylinder actuation, 1 line in from pump, 1 line out to sump, and 1 line out to power additional valves.
If your FEL does not have 7 lines and your OC system powers the 3pt after the FEL then you too are risking the warm oil on the right toe.:eek:
Mike
/ What does power-beyond really mean? #9
Another feature that wasn't directly mentioned.. but was touched on.. about having a hyd circuit provide fluid pressure while another circuit was also getting pressure.
this could be done with a priority valve.. like.. having power steeirng on a priority setup when fluid flow is limited and shared..
soundguy
/ What does power-beyond really mean? #11
Mike
I've been following the site for quite a while now trying to get a better understanding of the hydraulics on my tractor and how I could effectively add top-n-tilt capabilities. Mike, you seem to confirm what I was thinking that I need to do with my MF GC2300 (maybe others familiar with my machine could confirm this). (Awesome rollover box blade build by the way!) I have three lines going to/from my joystick valve that operates the FEL (four others for cylinders). One should be from pump, one for the sump return, and the third being the power beyond (which I'm assuming from this post to be operating my 3 point). I had always wondered if that third line was power beyond, but I couldn't figure out why it was installed... I guess I always just assumed that the 3 point was powered by the pump with plumbing internal to rear end. If I connect the power beyond from my FEL to the inlet of a new joystick or two spool valve (for TNT) I will need to make sure that I have power beyond on the new valve to properly operate the 3 point right? The power beyond on the new valve would plumb to where the power beyond from the FEL now goes (3 point) correct? Can I just tee or tap into the sump return line from the FEL with the new sump return line from the new TNT valve? Thanks in advance for the help once again!
/ What does power-beyond really mean? #12
Yes, everything you said is exactly correct.
Using power beyond is the best and correct way to feed other valves in the loop. Like I said in my post above, I've seen it done without using power beyond but it is not advisable nor correct for the reasons Ron stated in his posts. I have a Chinese loader valve that is plumbed that way and I'm switching it so I can have a PB port to feed the other valves in the loop.
/ What does power-beyond really mean? #13
Correct.
correct.
And again correct. Sounds like you have a handle on the situation...
/ What does power-beyond really mean? #15
They already said it, but if you need further confirmation--You are correct in your thinking and plan! That is the proper way to do it. And thanks for the compliment.:)
Mike
/ What does power-beyond really mean? #16
3-12-08, Hi all, I've read the thread about "power-beyond" valves and still am not seeing how to plumb one extra control valve and necessary lines onto my Kioti 3054 so that I can power a front brush grapple and still use the present six way control valve on the FEL. I want to tap into the distribution valve that some dealers are calling the PB valve and then into the extra control valve to control this grapple yet leave my six way FEL valve still usable. I will then have both control valves next to each other that I can operate seperatally. Bucket valve to raise and lower/tilt the grapple and the extra valve to power the clamp of the grapple. I feel that this is the cheapest way to have control of the hyd cyl on the grapple, and still have the FEL valve doing the tilt and up and down of the grapple. When I take the grapple off I'll then have the FEL 6-way to control the bucket as before. But I don't know what parts to purchase to get there. I need someone to spell it out to me. I've tried the local hyd. shops but they want me to spell it out to them. The dealers: I'm not so sure know. One dealer would make up six sections of hose and some fitting and include a $170 single spool valve for $350 total. That is pretty expensive to my thinking. When I asked how to hook it up I was told that "I would be able to tell when I saw the hoses and could the figure it out." I asked for a simple sketch and they told me that they would have to add a half hour labor to the order to produce an engeering drawing and send it along with the order. I suspect they are thinking that I'm trying to get free advice or they just don't know either. Any help from you experts is welcome. Please don't suggest to go back to the grapple supplier, I already did that with a lot of "each tractor is different" no help answer. Thanks again
/ What does power-beyond really mean? #17
Hi CalTrac and welcome to TBN.
I suggest you start a new thread to get better exposure and answers to your question. A lot more people will see it then. Also, you might want to check to be sure about your fel valve being a 6 way valve. Most are (2 spool) 4 way ... up, down, curl, and dump. Does yours do more than that?
/ What does power-beyond really mean? #18
CalTrac
Your current valve should have 7 hoses on it. one high pressure input, one high pressure output(PB) and one low pressure return line that goes to the resovoir, and 4 working lines that run to the lift and curl cylinders on the loader. If you had an open center single spool valve with PB, it would have 5 lines to it. Two would be the working lines to the grappel or whatever cylinder you wish to control. The other three would be the same as the first three I listed above for your 2 spool loader valve.
To add this additional single spool valve you would do the following:
1. At the loader valve disconnect the high pressure outlet line and move/re-connect it to the high pressure outlet port(PB) on the new single spool valve.
2. At the loader valve disconnect the low pressure return line and add a "T" into the line where it exits the loader valve.
3. Buy a new HP line that can run from the loader valve HP(PB) outlet to the new single spool HP inlet.
4. Buy a new line that can run from the low pressure outlet on the new single spool valve to the "T" added in step 2.
5. Buy and install whatever combination of lines and quick connects that will run from the new single spool valves working ports to the grapple cylinder, and allow proper movement and the ability to easily change buckets.
So for parts I have:
1EA PB capable open center single spool control valve
1EA HP line with proper fittings to fit loader valve PB outlet to new valve HP inlet.
1EA line to fit new valve return port to "T" on loader valve return port
1EA "T" fitting to fit/interface loader valve, existing return line, and new return line from new single spool valve.
It would be easest if the new valve has the same port type/size as the loader valve. If I knew the port sizes and hose lengths, I could probably point you to the parts at Surplus Center.
Another option that might be a little neater would be to replace your existing 2 spool valve with a 3 spool valve. This is the route I took in adding my grapple circuit, and is probably the simplest way of doing this.
Another way would be to add a solenoid controlled valve into the plumbing similar to what I described above. You would use an electrical switch to open and close the grapple.
Yet another way would be to add a solenoid controlled diverter valve onto the working ports of your existing valve. Switch one way, the spools control the loader and bucket like normal. Switched the other way, one of the loader spools controls the grapple.
You might get more responses if you start a new thread with this issue/question and include some detailed pics of your current valve installation.
/ What does power-beyond really mean? #19
If I want to add more hydraulics, and my valve for my FEL does not have a PB port, I could get a new valve with a PB port and go through the new one first and run my FEL valve off the PB port of the new valve?
/ What does power-beyond really mean? #20
Yes, that should work, as long as you provide a low/no pressure return line from the new valve to the reservoir.
2017 Caterpillar DP70N1 15,500lb. Straight Mast Diesel Forklift (A64194)
2017 Caterpillar...
2003 Kenworth T800 Log Truck (A62679)
2003 Kenworth T800...
IRANCH IRGC40 ELECTRIC SCOOTER (A64280)
IRANCH IRGC40...
2004 Gradall XL3100 Highway Speed Wheeled Excavator (A64194)
2004 Gradall...
🚜 2022 Mahindra 1635 HST Tractor Package – ONLY 36 HOURS – FULL SETUP READY TO WORK!
🚜 2022 Mahindra...
2008 PROGRESSIVE 20' X 7' BUMPER PULL TRAILER (A65643)
2008 PROGRESSIVE...
