Broken Seat Spring.....HELP!
/ Broken Seat Spring.....HELP! #1
schlichting
I broke one of the springs in the suspension part of my seat in a JD 4310....I tried to find a part to replace it, but they only had the entire seat suspension for $430 listed. I took the crazy thing apart...what an adventure that was, and now I need to find a spring to replace the broken one. I suppose I should replace the shock as well....but sitting on the tractor without that suspension seat really stinks. Any ideas on what I can do to fix it would be appreciated!
/ Broken Seat Spring.....HELP! #2
McMaster Carr is a good source for all kinds of things like that.
/ Broken Seat Spring.....HELP! #3
I saw your seat suspension on the JD On-line parts site. Here's what I'd do:
1: If just the end broke off, soften it over a torch and wind a new pigtail on it.
2: If it broke in the middle, take the good spring out and hang it from a wall hook, fence post, loader bucket, don't matter.
Take a heavy object: cement block, iron weight, floor jack, etc. whatever it takes to stretch it about and inch or so.
Get over to Home Depot, Lowes, TSC, ACO, Farm & Fleet, whatever and find an equivalent spring based on the rate. This means for the length you need, get it to stretch the same amount. A good spring scale would certainly help in this deal.
If you can't find a 'pretty close' equivalent, make one up from a garage door spring chosen for which the rate is about the same for the length you need. These stores carry a full line of springs with rates and lengths suitable for all farming equipment. I even found one perfect for the tail pullout on my windmill, there. You can wind a pigtail on the end of it by softening the end where you cut it with a propane or other gas torch. Get it red hot and wind it with a pliers or vice grips.
I've had to do this quite a few times, so its second nature for me now.
Check the shock absorber out for leaks while you are at it. A bad damper could have put a heavier strain on the suspension causing the springs to be over strained.
Might want to cut back on the Big Macs until the seat suspension recovers from surgery....
/ Broken Seat Spring.....HELP! #4
Grammer makes most of John Deeres tractor seats,look them up online the have a rep in the USA,that can fax or e-mail you a parts breakdown
Tommy
Affordable Tractor Sales
The big macs, and I suppose many other things, like being 6'6" and 300lbs cannot be easy on that poor little suspension. Thanks for the advice.....it would be cool if I could get a beefed up suspension so I won't have this problem again.....
Well.....I still need help. I have tried talking to John Deere and they will only sell me an entire suspension for $430...not just the spring that broke. I have tried getting in touch with companies that sell springs and have not had any luck....I have tried talking to Grammer and they said they can't sell to individuals, and wouldn't have what I need...they get them from Germany. I also found out that the suspension that I have on my 4310 is probably not made by Grammer, because it is not labeled as such, and most have told me that if Grammer made it, they would put their name on it. So anyone with any ideas????
/ Broken Seat Spring.....HELP! #8
Do you have a picture of it and some dimensions?
/ Broken Seat Spring.....HELP! #9
These seats are not made for us. I've broken three now. The scissor designs are just no good since the scissor multiplies the forces. Trying to suspend 300 lbs with lateral force on a low angle scissor is just stupid.
I tried air ride, the compressors fail.
The best bet so far has been the old vertical spring style seats with the adjuster in the back. Think old JD type. I have so far used two of those as replacements on other stuff.
Shame they only make seats for little guys. My doc says that losing weight for me would have to start with the bones and he bets I have at least 150 lbs of those leaving not much room to pare muscle and fat. Blubber fat and big are two different things.
/ Broken Seat Spring.....HELP! #10
Been down that road before too. They don't make replacement parts they intend to sell. They mean for you to buy a new suspension.
/ Broken Seat Spring.....HELP! #11
I fixed my spring seat suspension and the air ride seat in the big tractor.
There are two types of spring attachment points in these scissor spring suspensions. One has slots cut for the spring hooks and the other used socket head bolts and some kind of plastic or nylon hook for the spring to go on. I have the latter and they have broken. Replacements from Messicks are more than $7 each and will just fail again.
I made some spools of 4130 bar stock on the lathe that the socket head bolts will go through and put a big washer on top. The spools have a recess for the spring to pull against and the washer holds the spring down. These should not fail.
The air ride seat had a soldered wire connection to the little compressor that broke. Lengthened the wire, rerouted for less flex and straighter intersection and soldered it back in place. All is well.
The scissor spring suspensions and the air ride suspension I have are similar in design with the recess for the air bladder already in place. I will make the upper bracket for the air bladder, remove the springs and convert the spare spring seat I have to an air ride seat. Bladder and a Viair compressor all less than $100 and a little of my time isn't too bad for an air ride seat and an on board air compressor to boot. I'll put it on something.
/ Broken Seat Spring.....HELP! #12
Don't know if someone talked about using large washers and a
bolt to hold the spring together???
willy
/ Broken Seat Spring.....HELP! #13
2023 GMC 1500 Sierra Elevation Crew Cab 4x4 Pickup Truck (A60352)
2023 GMC 1500...
2016 Caterpillar 349FL Hydraulic Excavator (A56857)
2016 Caterpillar...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2023 CATERPILLAR 304 EXCAVATOR (A62129)
2023 CATERPILLAR...
2022 Behnke Trailer (A55973)
2022 Behnke...
