Shear Bolt vs Regular Bolt
/ Shear Bolt vs Regular Bolt #1
MikePA
Super Moderator
PA
Had TC25D, now JD X310
I stopped at my local TSC to buy some 1/2 x 3" Grade 2 shear bolts for my Brush Bull rotary mower. They didn't have any and the salesman said, "All the guys are using regular bolts of the same size." So, I went over to the fastener section. They had Grade 8, Grade 5 and Steel bolts, according to the labels on the drawers. No Grade 2 bolts. Is it OK to replace a shear bolt with a regular Grade 2 bolt?
/ Shear Bolt vs Regular Bolt #2
Mike, stick with the grade 2 even if you have to go elsewhere to find it. The higher grades will be tougher and may not shear when they need to. That could result in damage to your PTO driveline. As I recall, grade 2 will have NO markings on the head. The other grades will have various raised marks forged into the bolt heads. Hope this helps /w3tcompact/icons/smile.gif
/ Shear Bolt vs Regular Bolt #3
This is out of my Bush Hog Rotary Cutter Manual.
Thanks, Spencer and Rob!
Do either of you know if there is a difference between a Grade 2 bolt and a Grade 2 shear bolt?
/ Shear Bolt vs Regular Bolt #5
<font color=blue>...if there is a difference between a Grade 2 bolt and a Grade 2 shear bolt? ...</font color=blue>
Yep... the word shear.../w3tcompact/icons/smile.gif
Actually some "devoted" shear bolts will have a "groove" cast into the bolt...
The shear bolts on my snow blower have the groove, two of them I think.
So, is it safe to replace a Grade 2 shear bolt with a Grade 2 regular bolt?
/ Shear Bolt vs Regular Bolt #7
On my snowblower there are 2 shear bolts for the auger and 1 for the fan. The shear bolts cost around $6 each, and I am always going thru them. I use the grade 2 bolts (which the original shear bolts were) and use my lathe to make the grooves in them. You could also make the grooves in them by chucking the bolt into a drill and then hold a file to the bolt areas that you want the grooves to be. (A dremel works even better to make the grooves). I make up 20 of them in the beginning of the snow season and they cost a few cents each vs $6. BTW I always add 2 to the number of hash marks on a bolt to get the grade. 3 hash marks on the bolt head is a grade 5, 0 hash marks on the head is a grade 2. I find that if you don't make the groves in the bolts they are harder to drive out of the shaft after they shear,/w3tcompact/icons/sad.gif if you do have the grooves they just pop right out !!/w3tcompact/icons/smile.gif Hope this helps.
/ Shear Bolt vs Regular Bolt #8
Geez, this is an old thread but exactly what I am going through now. My neighbor picked up some bolts for at TSC and they keep breaking. When I bought my rotary cutter the original bolt lasted a long time even with an inexperienced operator, myself. I am going to the JD dealership to find out about the right bolt which is a Grade 2 and ordering it through them.
/ Shear Bolt vs Regular Bolt #9
Listen to Rob S. That's exactly what happened to me. I used a grade 5, hit a wellhead that nobody knew about and instead of the bolt breaking, the pto shaft got stripped at the yolk where it attaches to the tractor. You have to replace #2's more often but that's what they are supposed to do. John H.
/ Shear Bolt vs Regular Bolt #10
I went through this mess last summer. Rob S is right but JD didn't have the right bolt in stock and sold me a #5 which I am using. Am being extra careful with it.
1605 (A57192)
1605 (A57192)
2023 BOBCAT T770 SKID STEER (A62129)
2023 BOBCAT T770...
2019 Ram 2500 4x4 Crew Cab Pickup Truck (A60352)
2019 Ram 2500 4x4...
2011 FORD F-550 (INOPERABLE) (A60736)
2011 FORD F-550...
Preliminary Listing / Full Catalog Coming Soon! (A57148)
Preliminary...
24in Digging Tooth Bucket Excavator Attachment (A60352)
24in Digging Tooth...
