Oil & Fuel New guy again, embarrasing oil filter question
/ New guy again, embarrasing oil filter question #1
jbman
Member
Hurdle Mills, NC
PT425
Hello all. I am a bit embarassed to have to ask such a simple question, but what oil filters do you 425 owners use, and where do you get them? It's time for my first oil change. I can see I have a DENSO 115010-5480 filter on the machine, dunno where to get one, and I can't seem to come up with any filter cross reference charts for the Robin engine. I'm used to just being able to look up the filters for my cars, but not so sure about how to find the correct filter for this engine. I can't even find this info in the archives here, so this is obviously a pretty obvious thing for everyone else, darnit.
Thanks for your time,
Jim
/ New guy again, embarrasing oil filter question #2
I bought my filters from jacks small engines (P/N 248-65801-00):
Replacement Oil Filter and Transmission Filters for Robin
Some other people have cross referenced this filter to other more commonly available ones (YRMV, not recommended by the manufacturer). Essentually a small toyota filter (3/4-16 stem).
Purolator L14476 (or P14476)
Hastings LF410
http://www.tractorbynet.com/forums/power-trac/40410-pt-422-oil-filter-cross.html
http://www.tractorbynet.com/forums/power-trac/53282-my-worries-over.html
Thanks Tim, I was hoping just to find something locally, but this'll work too. I assume the oil filters are the same for the 422 (22hp?) and the 425 engines, but I'll check into that one.
Thanks again for the help,
Jim
Hastings LF410
/ New guy again, embarrasing oil filter question #4
The Robin 22 and 25 Hp engines use the same filter.
It is possible (if you have a machine more then 3 years old) that you have a Kohler engine, which might take a different filter.
/ New guy again, embarrasing oil filter question #5
Here's what I wrote down in my manual as far as cross references for the Robin PT422 engine:
Stens 050-777
Fram PH4967
Wix 51394
NAPA 1394
Baldwin B-33
Pennzoil PZ37
Amsoil SDF10
Hopefully they are all correct and help you. :)
Thanks all for the info. Apparently many of you are much more competent when it comes to finding information than I am ;)
Very much appreciate the help. If I can't come up with a filter with all of this info, I'll give up and start knitting to fill my spare time.
Thanks,
Jim
/ New guy again, embarrasing oil filter question #8
Thanks, KMA for the info on the filters! I did have a FRAM wholesale ware house that found that PH4967 for me, you having it here is a confirmation.
Stens 050-777
Fram PH4967
Wix 51394
NAPA 1394
Baldwin B-33
Pennzoil PZ37
Amsoil SDF10
2136 (A65055)
2136 (A65055)
2019 Polaris Ranger Crew XP1000 4x4 Gas Utility Cart (A64557)
2019 Polaris...
REEL RAIN HARD HOSE TRAVELER (A64278)
REEL RAIN HARD...
2023 Globe Trailer GTDD30236 36ft. 75yd. T/A End Dump Trailer (A61573)
2023 Globe Trailer...
2022 EZ-GO ELITE...
UNUSED FUTURE MINI EXCAVATOR ATTACHMENT SET (A65055)
UNUSED FUTURE MINI...
