Ferguson TO-20 4.80 star(s) (12)
Information, reviews, photos, discussion topics, owner pages, and specifications about the Ferguson TO-20.
Vintage Tractors
About the Ferguson TO-20
Ferguson TO-20 Discussions (14)
Here are the most recent TO-20 topics from our community.
  1. R
    1949 Ferguson TO-20 Hydraulic pump body cracked
    Will a 9n Ford pump fit? As I understand, many parts interchange. Any wisdom would be appreciated!
  2. E
    Oil & Fuel Ferguson TO-20 oil pan issue
    Hi There.... I sadly report that my 1949 TO-20 bit the dust. I spun a bearing. I was using a grooming mower and was going around my meadow a total 0f 700-900 feet per loop. After completing the...
  3. F
    I Need To Know How To Time Ferguson TO-20
    So, if the tractor wasn't out of time it is now. There, I confess, I might have made things worse then they were. Sorry. Ok? (LOL!) But really, I'm in need of instructions or links to video on...
  4. M
    Oil & Fuel Ferguson TO-20 Fuel Line
    I hope this post finds you all having a fine day. Not bad here in N. Dakota. I have a 1950 TO-20 that is leaking gas from the fuel line. The line looks to be very corroded. It seems like an...
  5. S
    1950 Massey Ferguson TO-20 Starter.. Can it be rebuilt?
    Hello, I have a 1950 Massey Ferguson TO-20 that just quit out on me today. Left the key on over night and next morning it would not roll over. Seems the terminal heats up right away when I try...
  6. B
    Ferguson TO-20 pto hydaulic problem
    I have a 1949 Ferguson TO-20 that I have a problem with. When you put in the clutch, the 3 point implement drops slowly. With the clutch engaged the pump works fine. I have removed the entire...
  7. Y
    Ferguson TO-20 Lift problems
    Hello everyone, brand new to TBN and I come to you for the wealth of knowledge you all have. Now down to the problem I have. I purchased a 1951 Ferguson TO-20 last year so that I could have a...
  8. J
    Ferguson TO-20 Restoration Project
    Ferguson TO-20 Restoration This project will take a long time to get done, as it will be a "here and there" effort as time and funds are available. I thought I would start by sharing a few...
  9. mag944
    Ferguson TO-20 Carb velocity stack
    Just picked up a '51 TO-20, running with choke pulled out only. Tore down the Marvel Schebler carb and one (plastic?) piece, I think it is called a velocity stack, is broken. None of the rebuild...
  10. J
    Any Ferguson TO-20 owners here??
    I should say NW Oregon/SW Washington owners....Husband and I are soon going to pick up our very first vintage tractor, Ferguson TO-20...These were built from 1948 to about the end of 52, I was...
  11. T
    Ferguson TO-20 Throttle Friction Disk
    I've messed with this many times over the years but have not found a suitable friction material for the throttle, and I'm tired of it not holding a speed. I've tried cork gasket material which...
  12. buckeyepost
    Ferguson TO-20 wheel weights
    I just bought a 1951 TO-20 to mow my 5 acres with and it has a set of wheel weights on the inside of the back wheels that I heard might be of some value and I don't need them for mowing. Anyone...
  13. Lazy
    Ferguson TO-20,30 Hydraulics
    Hi I could use some help understanding the hydraulic system on the Ferguson TO-30 tractor. We purchased a dealer shop manual and parts manual, but they don't help me much. If anyone has experience...
  14. S
    Opinion 1951 Ferguson TO-20
    I have the opportunity to purchase a 1951 Ferguson TO-20 with finish mower. I've been looking for a small tractor to help cut about 10 acres as well as some plowing and other miscellaneous "first...
[ad placeholder]
User Reviews (12)
Read what TractorByNet members think about the Ferguson TO-20 Subcompact Tractor
5
75 %
4
25 %
3
0 %
2
0 %
1
0 %
5.00 star(s)
happyparrothead
TO-20 Ferguson
First Retirement Restoration Project
Model Year: 1950
Long way to go but look forward to each and every day!
Pros: Just a really fun project!
Cons: None.
4.00 star(s)
tired t020
TO-20 Ferguson
TO-20
Model Year: 1949
Dependable tractor. Can sit for months and starts right up. Hyd. work fine. I repainted the tractor a couple years ago. Looks like new. Tires are good, filled with calcium. Have a plow and blade for it. Plow is single bottom. Overall, a good piece of equipment.
Pros: None.
Cons: None.
Photo Uploads:
5.00 star(s)
frankysmth
TO-20 Ferguson
1951 Harry Ferguson
Model Year: 1951
Bought when I was out of state 2 years ago. Just got it on my property 3 weeks ago. - Replacing radiator, water pump, thermostat. - Fixed hole in gas tank. - Drained & changed hydraulic oil - Installed 1 3/8" PTO shaft - Oil & filter - Gas lines & filter - Need to fix brakes on left side - Hope to paint
Pros: Learning a lot.
Cons: Need to learn more.
4.00 star(s)
mdm123002
TO-20 Ferguson
Ferguson TO-20
Model Year: 1949
Does not tip over easy good thing because no roll bar. You got to do 12 volt conversion and change to electronic ignition or the battery and points will drive you crazy.
Pros: Starts easy and easy to work on.
Cons: Power take of and PTO are both on or both off which is a problem for some implements like post hole diggers.
5.00 star(s)
Lord Ord
TO-20 Ferguson
Oh! What a Tangled Web We Weave
Model Year: 1948
The review of my old Ferguson. I bought it in the early 1990's after it spun a rod bearing. The crank was stepped 60 thousands and I couldn't (or wouldn't!) afford to put a new crank in it. I replaced the insert and put it back together. I ran okay if you didn't wind it up. I've used it since then for picking things up and plowing snow and whatever else I needed it for. I bought a salvage yard with my brothers in 1997 and when we started this old tractor was all we had to move cars, pull engines, clean debris with a York rake and plow snow or dig a trench. After we bought a loader the old tractor came home and resumed it's gentile retirement. It is a very tired old tractor but I hope to fix it some day. In the meantime I use it still to replace my aching back. Would I sell it? Nope, it's too tired to be worked as it should but it does what I need it for. I truly like this cantankerous old beast. I rarely spend more than an hour each year to bring it back to life for the season. If you want perfection buy a new one and trade it in every 3 or 4 years. If you need an old dog to leave sit 95% of the time buy a TO-20 Ferguson! It has the road speed that an 8N or 9N Ford could never hope to copy. The overhead valve engine is superior to the flat head design of most other tractors of the period AND it uses much less fuel than a Ford. The only thing I don't like is the foot brakes for left and right turn are not on the same side. It takes up a bunch of leg room. I finally gave up and removed the L/R pedals and rely on the main brake pedal. Overall, I like my old machine. It will stay with me until I find a better machine or a donor machine so I can upgrade but I'll stay with a vintage tractor. I will never buy a new one. I will never have one that relies on a computer to run. I can fix 90% of any issues with a few wrenches and a little time!
Pros: Inexpensive, good road speed, tough.
Cons: 6 volt charging system must be replaced.
4.00 star(s)
markmark
TO-20 Ferguson
Not Bad
Model Year: 1949
This tractor isn't too bad when it comes to the smaller jobs. It woul be nice to have hydraulic hook ups to run accesseries. Still, it is useful. I plow my drive very well and very rarely get stuck. It does what it is supposed to do. Even after all the years it has on it.
Pros: Still running strong after all these years.
Cons: No hydraulics. Could be a little bigger.
5.00 star(s)
jigsaw
TO-20 Ferguson
Such Good Memories
Model Year: 1950
The first tractor I ever drove was a Ferguson TO20. I used to rake hay all summer with it. I found this old Ferguson decaying away. It had not been started for over 10 years. Was supposed to be complete. Price was right so I bought it to restore. Found out the hydraulics had been cannibalized and engine needs an overhaul. Have found all the parts for the hydraulics and have that system rebuilt. Now working on the engine. Looking forward to getting it finished. Have no plans to use when complete. Maybe snow removal in winter. Brings back good memories.
Pros: The original Ferguson system hydraulics.
Cons: Was beaten and abused in prior life.
5.00 star(s)
wolfnyu
TO-20 Ferguson
Fergson TO-20
Model Year: 1951
Just bought this tractor runs and drives okay, but the hyd. won't lift a finish mower not sure of problems.
Pros: Older runs good.
Cons: Parts may be hard to get.
5.00 star(s)
Geneaol
TO-20 Ferguson
1950 Ferguson TO20
Model Year: 1950
A co-worker said he wanted to offload a tractor so he could buy a backhoe. He said it ran, so sight unseen, for $500.00, I took him up on it. I have less than 1/2 acre with 1/2 fenced off and full of weeds when it rains so I figured I could use a tractor to play around with back there. I would have been better off if I had hired an alien, which we have more of than old tractors. I've spent more time and money on parts, tires, brakes, oil, generator conversion, water pump, points and plugs, coil, than I have come close to playing around back there. BUT I'VE GOT TRACTOR FEVER! Sometimes I spend hours digging caked on dirt off just to visit my FERGUSON TO20.
Pros: I love old country memories. Not that I would like to live them over, there was some tough times.
Cons: Needs to be used often.
5.00 star(s)
Anonymous Poster
TO-20 Ferguson
1951 Ferguson TO-20 with Front Loader
Model Year: 1951
Just starting to work on this tractor. Will use it to maintain dirt road. Need to get a rear blade and figure out how to use the draw bar.
Pros: Like the Ferguson.
Cons: This one has had some hard use.
5.00 star(s)
ezridener
TO-20 Ferguson
1948 Harry T Ferguson
Model Year: 1948
The only work I've done to this tractor was paint rewire and battery. It has mowed 10 acres and tilled every summer.I wish I could have had a brand new one! Regular service I believe has extended the life of the ole tractor. Oh yeah, I have put tires on it 1 time.
Pros: Works for my needs.
Cons: Live pto.
5.00 star(s)
ezridener
TO-20 Ferguson
Harry T Fegensen
Model Year: 1948
I have only changed oil and regular tune-ups, this old tractor has made taking care of 16 acres a pleasure.
Pros: Nice equipment.
Cons: Plowing power low.
[ad placeholder]
Ferguson TO-20 Owner Pages
View owner pages to see photos, customization and comments about member-owner Ferguson TO-20s
Ferguson TO-20 Community Rankings
#29 user rating of 679 Vintage Tractors items
#19 Viewed of 679 Vintage Tractors items
#31 discussed of 679 Vintage Tractors items
#637 user rating of 19625 items overall
#354 Viewed of 19625 items overall
#698 discussed of 19625 items overall
