Case-IH JX95_3 4.00 star(s) (5)
Information, reviews, photos, discussion topics, owner pages, and specifications about the Case-IH JX95_3.
50-100 HP Tractors
About the Case-IH JX95_3
Case-IH JX95_3 Discussions (16)
Here are the most recent JX95_3 topics from our community.
  1. J
    2006 Case JX95 Light Wiring Help Needed
    I have a good friend that I'm trying to help get his hazard lights and dipped lights hooked back up. The problem is a guy that did some work on his tractor unplugged the wires from the two...
  2. C
    Case Jx95
    I have a Case Jx 95 that I have replaced the steering fluid tank 3 times and after I replace it everything works great and then the tank will melt and loose all my fluid. Why is this thing melting...
  3. W
    JX95 stuck in ground speed pto
    Yesterday I hooked up to a tiller and went to engage the pto... the lever moved with some difficulty, I assumed it was just dirted up from not using it for a year. But when I let the pto clutch...
  4. P
    JX95 Low Transmission Pressure light
    I have a 2008 JX 95 that I am wanting to use to run a PTO powered trailer pump. When I back the pump into the water and run the tractor, I'm getting the "low transmission pressure" warning light...
  5. D
    case jx95 pto
    how do you adjust the pto will enguage ok but doesnt disenguage properly?????
  6. D
    Post driver hookup Case jx95
    I have a Case JX95 that I want to hook up to my new Shaver HD12 post driver. The hydraulic into the driver is the usual quick coupler but, the return from the post driver is a 1" diameter hose. I...
  7. T
    JX95 just died in the field, any ideas?
    We were hauling round bales out of the field yesterday, when all the sudden the JX95 just up and died. There is no fuel getting to the injectors. We run all older IH's ( 56 and 66 series ) with...
  8. B
    Temperature gauge JX95
    I have a JX95 and my temperature gauge is not functioning. I have power at the sending unit and I have power at the gauge. I tried plugging in a new dash cluster and the gauge did not work on it...
  9. bdog
    Oil capacity JX95
    Just picked up a 2006 JX95. I have a owners manual on order but was hoping to do a oil change in the next couple of days since it is rainy here anyway. Any ideas on much oil she holds?
  10. R
    Case-IH jx95 vs JD 5420 vs Kub M9000
    I am considering getting rid of my open station 1994 JD 5300 for either cab JX95 or JD 5420 or Kubota M9000. I want a little more hp with cab but stay in the larger utility tractor category. All...
  11. A
    brush (grill) guard for Case JX95
    Is there a place to buy or order a brush guard for the front of my tractor - I'd rather buy one than make one. It's got to have some kind of protection to keep the brush from pushing on the hood...
  12. A
    New Jx95 - Implements?
    I've got a couple of pastures to maintain in South Texas. The first is a 500 acre pasture with about 300 acres of open field, sand hills, to mow and about two miles of river bottom that's got...
  13. O
    jx95/2255?
    Im 99% sure I know the answer to this, But might as well ask... 2255 fel wont fit on a jx95 will it???
  14. S
    JX95
    Looking to purchase a new tractor around 90 horse. Looking at a JX95 or TD95(New Holland equivalent). Only need 2wd since not using a loader. The biggest piece of equipment I have that I want...
  15. B
    NH TN75DA versus Case JX95
    i have been doing a bunch of research on this site and have basically narrowed my choice down to those two tractors. Actually, after reading all of the position comments about the TN-A tractors...
[ad placeholder]
User Reviews (5)
Read what TractorByNet members think about the Case-IH JX95_3 Subcompact Tractor
5
20 %
4
60 %
3
20 %
2
0 %
1
0 %
4.00 star(s)
cherokee1
JX95_3 Case-IH
Downgrade On Quality
Model Year: 2008
This is an update on my previous review for which I can find no way to edit. The tractor still goes as it was intended but I see now why people have clutch problems. The clutch cable adjustment can't be reached to adjust the clutch as it wears. If you can't adjust it, then it will slip and glaze and fail. I don't feel right to give it a lower rating on account of poor maintenance access but I probably should. I am having to cut a hole in the cab floor to reach the clutch cable yoke to adjust the free pedal of the clutch. It is impossible for me to do otherwise. I'll add that there is no easy way to pull the lower dash cover to reach anything under there to replace the clutch cable or do anything else. After hours of looking I still can't figure out how to get the thing off without pulling the entire dash, steering wheel and instrument panel. This is an outrageous design. The brakes on this tractor were simply not working. We purged the system and found it full of black solids. The brakes were horribly hard to reach to service. Even the bleed ports were hard to reach. Be careful if you do service the brakes and do not use DOT fluid. The fluid required is the same as BMW and has to be ordered from our parts store. The hydraulic couplers leak like sieves. They should use quality ones like Faster like they do on the newer tractors and the loaders. This one has Fasters on the loader and they have not leaked in 11 years.
Pros: Solid, simple, spacious cab, good fuel economy
Cons: Horrible, terrible maintenance access
5.00 star(s)
cherokee1
JX95_3 Case-IH
Could Sell It For What I Paid
Model Year: 2008
That is even with all we have done to it, although it does not have that many hours for these last six years. Feeding, baling, utility loader, 3.5 yard scraper, 10' offset disk, etc. is what we use it for. It handles the 15' FR-15 with ease and cuts some 3" junk! Like most similar tractors, most of the hours are feeding cows in the winter when it gets bales and slogs out to feed almost every day. It is reasonable on fuel. It has the same engine as the JX80 we have that gets great fuel economy, but the turbo slurps fuel much faster; probably never more than 2.5 gallons per hour. It runs about spot on to the Nebraska Tractor test. It is no frills, comfortable, reliable and no computer!!!! We have not had any problem after the shuttle shift lever broke off and had to disassemble and weld it back together. That linkage needs lubrication and could use bearing type connectors. When they ship the linkage gets a little corroded and sticky. After fixing that, we have had not another problem except the linkage still needs lube. It is a complicated pathway. The other problem we had was that the clutch linkage adjustment was installed backwards!! The electrical connectors up in the headliner won't stay hooked up. We need to put tighter connectors there. The lights are great! You can work in a nice pool of light at night. AC is just OK but good enough for summer to be comfortable and avoid the dust of baling. The cab is spacious. That is one reason I bought the tractor. Everything else with a cab just seemed cramped and tedious. The loader has a problem, it apparently gets air in it and you have to recycle it to get it to hold position on the curl. I'm told this is because CaseIH is too cheap to put a regen circuit in it or something. I wanted the larger tires, but didn't get them and am sort of happy we didn't since the CG is improved with the smaller tires. It has some leaks, but these engines are pretty reliable. Getting a battery is a bear. I gave up and just went with a commercial large truck battery and built a battery holder for it. I'm doing the same for almost all the equipment. Batteries are cheaper and have massive cranking amps. I'm making as many as possible standard. These things seem to hold their value, so there must be something good about them.
Pros: Spacious cab, tight turning radius, good ride.
Cons: Shuttle shift linkage is a little stiff.
4.00 star(s)
ghessels
JX95_3 Case-IH
Solid Value in a Tractor
Model Year: 2006
Tractor came up as a local trade in, enough horsepower for our TMR, all the features we needed. No regrets with the purchase! Basic no frills machine, does everything we have asked of it. Really happy to have it on the farm, helping with the beef cows and stockers.
Pros: High horsepower, loader, 4-wheel drive.
Cons: Manual PTO, no shuttle shift.
3.00 star(s)
Anonymous Poster
JX95_3 Case-IH
JX 95
Model Year: 2005
I purchased JX 95. It didn't have a thermostat in so I had one installed. It was a TX tractor. A thousand dollars later, I now have a tractor that runs hot. When I put it work hard. By hard I mean I have some alfalfa ground that I decided to brake up (9 acres). I had a Allis 190 I have used in the past with good success. The tractor ran for about 4 hours before the clutch went out. Its probably a okay utility tractor but a tractor for moderate to heavy field work that a 95 horse tractor might be called on to do? I don't think so.
Pros: I like the mechanical front wheel drive.
Cons: Reliability?
4.00 star(s)
Pkneibert
JX95_3 Case-IH
Expensive Repairs Within First Year of Ownership
Model Year: 2008
I purchased a used 2008 JX95 about 18 months ago. It had about 1400 hours on it when I purchased it. I only use the tractor to maintain recreational duck hunting property in Missouri. So far a new Hydraulic pump and a new clutch. Plus a few other minor items. Total repair costs so far in excess of $7,000. I would expect a tractor with 1500 hours on it to NOT require a new hydraulic pump and clutch. Who knows how the previous owner treated the tractor, but he only put 1400 hours on it in 3 years. Anyway, I might just be snake bit on this tractor, but I am disappointed in the reliability.
Pros: Easy to operate, comfortable cab, 4wd is very capable, dual PTO speeds.
Cons: Repairs have been frequent and expensive.
Photo Uploads:
[ad placeholder]
Case-IH JX95_3 Owner Pages
View owner pages to see photos, customization and comments about member-owner Case-IH JX95_3s
Case-IH JX95_3 Community Rankings
#203 user rating of 1508 50-100 HP Tractors items
#30 Viewed of 1508 50-100 HP Tractors items
#87 discussed of 1508 50-100 HP Tractors items
#1380 user rating of 19625 items overall
#304 Viewed of 19625 items overall
#647 discussed of 19625 items overall
