Massey Ferguson JD2135_2 4.40 star(s) (5)
Information, reviews, photos, discussion topics, owner pages, and specifications about the Massey Ferguson JD2135_2.
25-50 HP Tractors
About the Massey Ferguson JD2135_2
Massey Ferguson JD2135_2 Discussions (4)
Here are the most recent JD2135_2 topics from our community.
  1. Kenneth S
    Massey Ferguson 2135 won't go into reverse
    Hello all, I just bought a 1965 Massey Ferguson 2135 for $1500.00, it has few problems that are easy to fix but the one main problem is it won't go into reverse. If you try to force it to go into...
  2. F
    Massey ferguson 2135 pto seal change
    Gentlemen--I just purchased a Massey Ferguson 2135 that for one thing has a PTO seal leak. I did a search on this board and came up with one for a 135 which said to be sure PTO was in ground...
  3. L
    Need Repair Manual for Massey Ferguson 2135 with Continental engine
    I made the mistake of loaning my repair manual to a "friend" that has never returned it and I need to change the clutch on my little 2135 Massey turf tractor with the 4 cylinder Continental engine...
  4. F
    Massey Ferguson 2135 Loader Mount
    I am a new owner of a Massey Ferguson 2135 Turf Special. I have acquired a loader that I believe will fit the tractor nicely. It's a DuAl 110 loader. I also was fortunate enough to acquire a...
[ad placeholder]
User Reviews (5)
Read what TractorByNet members think about the Massey Ferguson JD2135_2 Subcompact Tractor
5
60 %
4
20 %
3
20 %
2
0 %
1
0 %
4.00 star(s)
rikker
JD2135_2 Massey Ferguson
MF 2135 Industrial Backhoe/Loader
Model Year: 1966
I borrowed this backhoe to build my house---waterline, septic field, digging out trees, etc. Bought it and kept it because it was so useful and still is. Have done many septic fields, trenching, back filling, etc. for friends and family.
Pros: Very strong hydraulics for digging and lifting.
Cons: Not 4-wheel drive, have to pull myself out w/hydraulics when stuck.
Photo Uploads:
3.00 star(s)
leslane
Clutch Problems
Model Year: 1965
Other than the constant clutch problems, this isn't a bad little tractor. A little weak on power with the 4 cylinder gas engine, but that was to be expected. I had the clutch replaced when I bought the tractor and it didn't last a year. It really doesn't get worked hard either, I mostly use it for the front loader to move my firewood rounds from where I cut them to the log splitter. I think I will shop around for a different tractor mechanic this time. I never had clutch problems on either of my other 2 Masseys so I have to believe that the work may have been less than stellar. Other than all that, nice little turf tractor.
Pros: Easy to operate.
Cons: Little weak on power.
5.00 star(s)
d4fritz
Old Yeller
Model Year: 1968
Refurbished the tractor in 2004. Since then I have used it at my deer camp for planting 56 Acres of food plots. Old Yeller is a work horse. She just keeps on working. It is a diesel has a MF200 loader, wheel weights and tires filled with water. This tractor can do just about anything, it just keeps on working. I have the following implements: MF Backhoe, MF Dozer blade, MF grader box, harrow, all purpose plow, FordMac bush hog, Gill seeder, Holland square bailer and Fella disc cutter.
Pros: Dependable.
Cons: None.
Photo Uploads:
5.00 star(s)
smashed54
Great Little Tractor!
Model Year: 1961
They call it "The Bull"---enough said!
Pros: All.
Cons: None.
5.00 star(s)
rikker
MF 2135 Industrial Tractor/Loader/Backhoe
Model Year: 1966
Bought the tractor to dig my waterline and install septic field on my then rural property 25 years ago. Have used the backhoe to dig many friends' septic fields and waterlines over the years. Now I use it mostly to carry wood and give the youngsters rides. The tractor was recently losing power at low rpm's, so I just had the Cessna injector pump and injectors rebuilt. Now it purrs at low rpm and is strong at high rpm's. The MF dealer, Java Farm Supply in N. Java, NY has been great. I guess the tractor is now set for the next 20 years.
Pros: Durability, utility.
Cons: Nearest dealer is 60 miles away.
Photo Uploads:
[ad placeholder]
Massey Ferguson JD2135_2 Owner Pages
View owner pages to see photos, customization and comments about member-owner Massey Ferguson JD2135_2s
Massey Ferguson JD2135_2 Community Rankings
#471 user rating of 2355 25-50 HP Tractors items
#406 Viewed of 2355 25-50 HP Tractors items
#472 discussed of 2355 25-50 HP Tractors items
#1202 user rating of 19625 items overall
#1089 Viewed of 19625 items overall
#1183 discussed of 19625 items overall
#11 Ranking of Most-OwnerPages in 19625 items overall
