Ford 7000_3 5.00 star(s) (1)
Information, reviews, photos, discussion topics, owner pages, and specifications about the Ford 7000_3.
50-100 HP Tractors
About the Ford 7000_3
Ford 7000_3 Discussions (16)
Here are the most recent 7000_3 topics from our community.
  1. J
    Ford 7000 Head Gasket Repair
    Hello all! New to the forum. Had a question on the Ford 7000. Did it come in gas as well as diesel? Or just diesel? Reason I'm asking is we ordered a new head gasket kit and it came with the gas...
  2. G
    Ford 7000 motor oil and hydraulic filters part numbers
    I have a ford 7000 with CarQuest motor oil filter #85714 and CarQuest hydraulic filter 85158. What are original Ford part numbers? I just paid $182 for a hydraulic filter considerably smaller...
  3. R
    ford 7000 over charging battery
    The alt on my ford 7000 is over charging the battery(blowing the covers off) , I suspect that the regulator is bad. I have tried to get a new one but can,t find one anywhere,out of stock or not...
  4. R
    ford 7000 turbo
    What type of oil should I be using for the power steering,I heard that power steering fluid,automatic tran fluid and 10w30 motor oil can be used.Just wondering.
  5. R
    Ford 7000
    Where in canada could I buy decals for my ford 7000
  6. M
    Rebuilding a steering box on a ford 7000
    I have the steering box disassemble and ready to be put back together. I'm having trouble with the balls and worm gear. Asking if someone could send a diagram
  7. M
    Ford 7000 PTO Shaft
    Hello ! Can everyone know how to remove Ford 7000 front PTO shaft. Enyway thanks
  8. Tractorboy88
    Ford 7000 Tach Drive
    Ford Gurus. Id like to get my tach back to working on the 7000 for spraying/spreading. I've got a new tachometer and cable, but the tach drive on the back of the pump is missing. It was removed...
  9. B
    FORD 7000 Starter Wiring
    Hello Everyone, I've searched and read the forum for years but this is my first post. I recently purchased a FORD 7000 deck top row crop that needs some work. It appears in pretty fair shape, a...
  10. D
    Ford 7000 steering problems again!!
    Guys, 7000 ford was giving steering problems, would turn easy then get hard to turn so I changed the steering pump out flushed the air out. Worked much better, about 10 hours of use getting the...
  11. D
    ford 7000 steering problems!!
    Fellows, need help on this problems ASAP. Getting ready to go to the hay field but my for 7000 steering is acting a fool, Changed the filter this spring no problems. Last week the turning...
  12. crackerjack222
    Ford 7000 Alternator/Voltage Regulator
    Ok, so I am in the process of rebuilding a Ford 7000 (same as 5000, except with t-charger). Last problem is wiring the new alternator and voltage regulator. The original wiring was trashed, ie...
  13. GManBart
    Ford 7000
    I happened to see this at a local shop today...they had just closed, so I don't know if it's for sale (yet). Sure looked sweet, and I had to share....just love the looks of these early 70s big Fords!
  14. MaherAgriculturalServices
    Looking to buy Ford 7000 with cab and air
    Looking to buy a Ford 7000 cab and air let me know if u know where one is at... I'm from Texas so closer the better thanks
  15. D
    Ford 7000
    Hi Does anyone have a Ford 7000? Until fairly recently I did and I thought it was a great machine. Here is the story of my experiences My Ford 7000 Cheers Dave
  16. N
    Weight of a Ford 7000
    Does anyone know the weight of a Ford 7000? My wife just bought one and she wants me to pick it up. I need to know a weight as I wasnt able to find it on the net. Thank you in advance.
[ad placeholder]
User Reviews (1)
Read what TractorByNet members think about the Ford 7000_3 Subcompact Tractor
5
100 %
4
0 %
3
0 %
2
0 %
1
0 %
5.00 star(s)
duke 8100
7000_3 Ford
ford 7000
Model Year: 1975
awesome piece of kit only prob as all fords could be a porous block dads tractor we had 4 one brought s/h]
Pros: high hp [for its time]
Cons: porous block, engine smoke at high hours
[ad placeholder]
Ford 7000_3 Owner Pages
View owner pages to see photos, customization and comments about member-owner Ford 7000_3s
Ford 7000_3 Community Rankings
#1 user rating of 1508 50-100 HP Tractors items
#295 Viewed of 1508 50-100 HP Tractors items
#87 discussed of 1508 50-100 HP Tractors items
#1 user rating of 19625 items overall
#1926 Viewed of 19625 items overall
#647 discussed of 19625 items overall
