Case-IH 5230_2 4.50 star(s) (2)
Information, reviews, photos, discussion topics, owner pages, and specifications about the Case-IH 5230_2.
50-100 HP Tractors
About the Case-IH 5230_2
Case-IH 5230_2 Discussions (0)
Here are the most recent 5230_2 topics from our community.
No discussions tagged.
[ad placeholder]
User Reviews (2)
Read what TractorByNet members think about the Case-IH 5230_2 Subcompact Tractor
5
50 %
4
50 %
3
0 %
2
0 %
1
0 %
4.00 star(s)
HHelms
5230_2 Case-IH
5230 2 wd with Koyker 500 loader
Model Year: 1994
It seems like a great tractor so far. At 3500 hours it starts easily, has plenty of power, and doesn't burn any oil. Rear main has a slight leak. Radiator had to be repaired for a bad factory weld on the upper cap. Front cab glass was loose, but easily repaired. Just normal stuff on a used tractor. One downside is that the CC, Pfc, remote sense, Power beyond, hydraulic system is not compatible with most spools. So if you are thinking of adding a loader spool, be prepared to spend some serious cash. In retrospect I would buy a used loader that came off of a 5000 series tractor, that already had the spool. Of course you would still have to buy the power beyond plate for the remote stack ($400from Case) Using the remotes for a one way cylinder with a high flow return (post driver) is prohibited in the owners manual. The oil normally returned through the remotes is used to pre-charge the transmission. We are currently using it to pull a 3 yd paddle scraper to clean and deepen our dry tanks, thanks to the drought. It has no problem even in the tightest places. It will pull the scraper loaded in any gear. Maneuverability is great.
Pros: Turns tight. Always starts easily. Runs cool under load. Pulls good. Easy to work on.
Cons: Hydraulic incompatibilities.
Photo Uploads:
5.00 star(s)
huntinman802
5230_2 Case-IH
case IH- 5230
Model Year: 1996
this is just a great tractor! it is the main tractor that we use to bail hay. it will start up on a cold day and runs like a champ.
Pros: runs great, doesnt burn any oil, starts right up, decent road gear, good pulling power, very smooth ride
Cons: only 2wd,
[ad placeholder]
Case-IH 5230_2 Owner Pages
View owner pages to see photos, customization and comments about member-owner Case-IH 5230_2s
Case-IH 5230_2 Community Rankings
#146 user rating of 1508 50-100 HP Tractors items
#191 Viewed of 1508 50-100 HP Tractors items
#339 discussed of 1508 50-100 HP Tractors items
#998 user rating of 19625 items overall
#1366 Viewed of 19625 items overall
#1991 discussed of 19625 items overall
