Good luck.I have an RK 37 H tractor and I cut grass in about two acres yesterday. As I was putting the tractor away I noticed I had an “F pedal check” notification. What exactly does that mean and is it something I can do myself?
Thank both of you for your responses. I did a more thorough inspection and found that the pedal rod/linkage has a short post on the end of it had slipped out of a metal clip (it has an open end). I reattached them and the notification went away. There are some small sapling in the field I mowed and one of them probably forced them apart. I did see wires and connectors and will keep them in mind as I mow.I have an RK 37 H tractor and I cut grass in about two acres yesterday. As I was putting the tractor away I noticed I had an “F pedal check” notification. What exactly does that mean and is it something I can do myself?
