ZTR 's ?
/ ZTR 's ? #1
GrayBeard
Pa.
ZTR \'s ?
I need advice on a good "mid" priced ZTR.(if there is such a thing)
I have a 5' finish mower on the back of the tractor but it really doesn't always suit my conditions.
I've got about 3 ac to mow and it's pretty much irregular shapes with some trees and hills.
I've looked at many brands, some very cheap and some off the charts, money wise. I don't need a 8-10,000 dollar mower.
I'm looking more at 3-4000 range. There really aren't many "middle" market ZTR's. (IMHO)
Does anyone know about Snapper (Fastcut) ZTR's ?
Any suggestions appreciated.
GrayBeard
/ ZTR 's ? #2
Re: ZTR \'s ?
My dad just bought a ZTR made by Bobcat for I think in the $4k range. It has either a 48" cut or a 52" I don't remember and it has either a 25 or 26 hp Briggs and Stratton vanguard engine. Sorry I don't know everythign about it but I did not reseach it, I have used it a few times (mostly playing) and it is one hell of a machine. A few guys that we bothknow that do alot of commercial mowing told us that the machine he got is a great machine for what he will do. Dad looked at grasshoppers, scags and ex-mark mowers and when he looked at price v. size v. features v. engine he chose the Bobcat brand. Scag made a mower called the Cub (I think) that was the smallest one they made that dad looked at with the same size deck and comparable Kawasaki engine and it was $1000 more, with Honda engine add another $1000. From what he found Scag, Grasshopper and Ex-mark are the top three around here but for the mowing he does, hills and landscaping he was better off with a 48" - 52" deck v. a larger one. He saw a Toro, Husky and another brand and they just weren't built to his specs, I would call this Bobcat a mid range/mid price mower like you are looking for.
/ ZTR 's ? #3
Re: ZTR \'s ?
Graybeard,
I just bought a Country Clipper JAZee (19HP Kawasaki, 52" Cut) for about $4,500.
I describe my selection process in This Thread where I listed a number of choices that are as close to your 3 - 4K range as I think you'll get in a "Good" ZTR for 3 acres.
/ ZTR 's ? #4
Re: ZTR \'s ?
GrayBeard, Gravely makes a nice one PM-152Z which is a 52" but it is probably closer to $5-6k ?(not sure) they all list price high but when all is said and done a little haggiling and the price can drop a good bit..Also the Hustler manufacture makes one called FASTTRACK Z which is a nice unit.. When buying make sure you get one with good pumps.The gravely has maintenance free spindles,no greasing. I should qualify my knowledge base on the below 60" ztr's is limited because I have been researching the 60" units and decided when I buy it will be a Hustler super Z(in my area $7K)The Gravely 260Z is a very close 2nd.
I'm not a salesman and I can't spend your money, But You do get what you pay for. I look at pumps (longeivity)ease of regular maintenace oil filter location and oil drain. Get a test drive. I have 3 neighbors who 2 had riding mowers and 1 had a tractor cutting 3 to 6 acres and now they all have ztr's 1 has gravely 50" 1 has kubota 60" 1 has a kubota 72" and they all love them. Comments are cut mowing time in half plus it looks better /forums/images/graemlins/wink.gif
I assume since your using a 60" RFM now and want to keep your price down you will be looking for something in the 48"-52" range which will also help in the trimming department.
The ztr's are faster but can only go as fast as your lawn surface permits ,so if its bumpy with your tractor it will be bumpier with a ztr, OH BTW the weight adjustable seats on the gravely 260z & Hustler super Z are standard on both machines and I wouldn't have beleived it but what a difference they make! It takes a lot of the jolt out your ride!
Well Hope this helps and wasn't too long of a read /forums/images/graemlins/tongue.gif
/ ZTR 's ?
Re: ZTR \'s ?
All good comments, thanks.
Most of the areas are "reclaimed" wooded areas on my place except for my small lawn aroung the house.
Surfaces are reasonable but not "golf course" quality.
Albeit I can mow with the larger tractor; it's just clumsy.
Tlme is not a great big factor, I actually enjoy being out away from the phone and other issues. So , I'm not looking for super speed.
I've even thought of getting the "throw away" Dept. store lawn tractor. I could probably get 2 or 3 of these over the years and most likely finish out my "mowing career" for about the same money.
Thanks again,
GrayBeard
/ ZTR 's ? #6
Re: ZTR \'s ?
Graybeard,
Your post caught my attention because I am debating whether to go with a finish mower for my 28 hp tractor or go ZTR before next spring.
I'm currently mowing next to the house with a Murray 30" rider and doing the rest of the 3.5 acres with a brush hog. The BH works ok to the extend it will mow close but it's too easy to scalp the ground. The small rider leaves a nicer cut but way too small to mow it all.
I've been leaning toward a finish mower since it would be far less expensive plus it seems a waste not to utilize the hp I've already got with my tractor.
Can you explain a little more why your turning from the finish mower to the ZTR? Is your problem with the finish mower mainly getting around the trees? I'm mowing a mostly flat and open area.
/ ZTR 's ?
Re: ZTR \'s ?
Okie,
The finish mower works great .It's a Ford 930B that I got a tremendous price on last spring.
Most of my "green space" is in pieces. That being long narrow spaces or small round ones.
I have used the 5' rfm but it's made for areas that are "large" with not to many trees. I also use a DR brush cutter for some spaces to confined to get the tractor into.
I can always sell the RFM but I'm not sure about which way to go after that.
If I had more "open" mowing, the RFM would be perfect.
GrayBeard
/ ZTR 's ? #9
Re: ZTR \'s ?
GrayBeard,
I started out with a 3510 35hp Branson tractor with a 72" finish mower for my five acres and now I own a Ferris 3000IS ZTR. The Ferris is the cream of the crop for mowing comfort, quality of cut and Heavy duty built. It is more than your indicated price range, the Hustler super z would be my second choice with a Scag bobcat or gravely as my third choice. One of my neigbors has a Husavana 52" and I believed he paid around $4800.00 at Lowes and he likes it a lot. Hope this helps.
db
/ ZTR 's ? #10
Re: ZTR \'s ?
dkb1215, When you got your ferris did you drop to a 60" cut or stay with 72" as your RFM had?? Reason I ask is I am currently using a 6' RFM and the ztr I would be looking at is a 5' The thinking here is the speed and manueverability would more than make up the 12" I'd be losing in width. I would keep my RFM as Back-up or part-time use. Just curious /forums/images/graemlins/smirk.gif
/ ZTR 's ? #11
Re: ZTR \'s ?
have been using a Grasshopper 721, 62" that I bought used for about eight years mowing about 5 acres. I don't see how you could ask anymore from a lawnmower, fast as you want to go, cuts beutiful, economical. It replaced a 48* John Deere and a 48" Cub Cadet. I think any of the better ZTR's will turn out to be the cheapest lawnmower you can buy in the long run.
/ ZTR 's ? #12
Re: ZTR \'s ?
We just got a Kubota ZD21 with a 60" Pro Deck.
It is a 21hp three cylinder diesel with a heavy duty commerical hand welded 7 gauge steel deck.
It is beyond awesome, where was this thing these last twenty years when I wore out half a dozen gasser riding lawnmowers?
Super smooth, super quiet, no vibration and cuts 10 acres of bahia grass in the horse pasture in less than 4 hours without a wimper, and turns around every tree in one pass in a couple of seconds.
These Kubota diesel ZTRs have to be experienced to be believed. Super heavy duty quality and first class workmanship.
/ ZTR 's ? #13
Re: ZTR \'s ?
dkb1215, what mower did your neighbor buy. Is a commercial husqvarna mower or is it the 48" cosumer z that they sold for around 3500-4000 in lowes last year. Thanks in advance.
/ ZTR 's ? #14
Re: ZTR \'s ?
I was in the exact position you are in last month, and just purchased a Gravely 52" ZTR Home. It has the same motor as their commercial mowers and seemed well built. After using it to cut my 3 acres I could not be more pleased. For Just over 4 thousand it is a wonderful mower! Good luck making your decision.
/ ZTR 's ? #15
Re: ZTR \'s ?
In a ZTR quandary as the rest of you seem to be. I am looking for a 72" diesel ZTR and have narrowed things down to Kubota ZD28/72 and a Gravely 272Z. Little more power from the Gravely, a little faster top speed (though that may not be a factor with my land). Seems the best prices I have to this point put the Kubota priced $1500 below the Gravely. Is the extra 3 horse power and the Eye-Q system on the Gravely really worth the extra money? Are there perhaps some other differences that are not evident that I should be looking for? Just looking for some thoughts from anyone with experience with either of these mowers.
/ ZTR 's ? #16
Re: ZTR \'s ?
Paint_ball, If I could get a kubota diesel for less than a gravely , it would be a done deal! The hp difference is more than made up in the torque of the diesel,not to mention the longeivity ,also the diesel will use less fuel than the gravely for a given amount of mowed grass..
Oh were you talking about a gravely with a diesel? well my bad!! You probably won't notice 3 hp and the eye-Q ,How many people will be driving the mower? It's more of a maintenance reminder than anything else..
/ ZTR 's ? #17
Re: ZTR \'s ?
Both the Kubota and Gravely I am looking at are diesel. 28 hp from the Kubota, 31 from the Gravely. I'd have to agree witht he Eye-Q being an electronic log book...just one more thing to go wrong in my estimation. One of the problems I have had with my current 48" Snapper ZTR mower is the poor design of the deck. It just packs the grass up into and around the two outer pulleys. It has to be blown out and picked out prior to each cutting or I risk a small fire (voice of experience on that one). Anything particularly good or bad about either the Kubota or Gravely that I should be aware of before my final decision?
/ ZTR 's ? #18
Re: ZTR \'s ?
Paintball_Barn, Well Both units are the top of the line and while you will probably be pleased with either, The Kubota has the tilt front axle that allows you to prop up front end to clean or inspect ,But it is also about 2" bigger in length and width over the Gravely. Gravely also offers an optional jack stand feature for the service /inspection thing.. /forums/images/graemlins/confused.gif
So it seems to be a toss up from my perspective so I would have to let a test drive decide for me..
Do you like red or orange better? /forums/images/graemlins/laugh.gif
/ ZTR 's ? #19
Re: ZTR \'s ?
I just purchased a ZD-28 72" ZTR from Kubota. It is GREAT! Puts so much fun back into mowing that my wife does it now. Only downside to the ztr is no suspension so my 20 acres of horse pasture are too rough for the mower. Why doesn't someone make a ztr with a suspension?
Redd
JOHN DEERE 772GP MOTOR GRADER (A58214)
JOHN DEERE 772GP...
2011 VOLVO VNL760 SLEEPER (A59904)
2011 VOLVO VNL760...
UNUSED FUTURE EQUIPMENT SEAT (A60432)
UNUSED FUTURE...
2014 Mazda 2 Hatchback (A59231)
2014 Mazda 2...
UNUSED KJ K2512 - 25' X 12' LIVESTOCK METAL SHED (A60432)
UNUSED KJ K2512 -...
TAG 18in Digging Tooth Bucket Excavator Attachment (A60352)
TAG 18in Digging...
