ZTR Choices
   / ZTR Choices #1
WVBill
Veteran Member
Usa
Sold my Kubota B6100 when I moved to WA
I've been reading tractorbynet, lawnsite.com and various manufacturer's web sites for the past several weeks, learning all I can about my options for a ZTR to cut my 3.5 acres (less house and numerous flower beds & trees) in the Northern Shenandoah Valley where VA, WV and MD come together.
I narrowed my choices down to the following list. All have 50"-52" decks. (Although I'd have loved a 60" machine, I borrowed my neighbor's Toro and found that there are quite a few places in my yard where I couldn't get to and I figured the time I would have to spend coming back to those with a smaller mower would eat up any time advantage the larger deck would have given me.) The list, with my opinion on each:
Encore Z52 - Although it has commercial-quality independent pumps/motors and a heavy guage formed/welded 52" deck, the rest of the machine looked less substantial. 21HP Kawasaki engine. Quoted Price - $5,799. Eliminated due to price.
Exmark Lazer Z CT - Nice machine. Commercial-quality independent pumps/motors and a heavy guage formed/welded 52" deck. Overall, high quality. 19 HP Kawasaki Engine. Quoted Price - $5,889. Eliminated due to price.
Snapper Fastcut - Commercial-quality independent pumps/motors but a light duty stamped-steel deck which was only 50". 20HP B&S Vanguard Engine. Eliminated due to the stamped deck at only 50". Quoted Price - $4,499.
Simplicity Consumer Z - Commercial-quality independent pumps/motors but a light duty stamped-steel deck which was only 50". Independent front suspension would have been a plus in the rough areas of my yard. Quoted Price - $4,599. In the "final three" but eliminated due to the 50" deck. Had it been 52" vice 50" I'd have chosen this one.
Hustler FasTrak - Integrated IZT Pumps/Motors and a heavy guage formed/welded 52" deck. Good solid machine much smaller (both length and seating height) than the rest. 20 HP Honda Engine.
Quoted Price - $4,899. In the "final two" but eliminated primarily because of two factors I though would be significant drawbacks in mowing the rough areas of my yard: The wheel base is much shorter than the rest and I think a longer wheelbase will handle the bumps better, combined with the seat has no suspension (not even springs under it) - it relies on the fact it's made of a thick foam. This felt comfortable enough on my test drive but I worried about durability of it's cushieness (also, I'm a big guy so I'd really be compressing that foam on the bumps).
And the winner is:
Country Clipper JaZee - Integrated IZT Pumps/Motors and a heavy guage formed/welded 52" deck. 19 HP Kawasaki engine. The deck flips up for easy access to clean it and sharpen blades. I tried the Joystick control and found it to be very comfortable. Quoted Price - $4,599. I considered the JaZee Two but the only difference between it and the JaZee is that it has 20" v.s. 18" drive tires.
I pick it up this afternoon - I'll let you know how it mows.
   / ZTR Choices #2
Bill, What no gravely to test, Oh well I'll look for your results as my wife has just given her blessing to adding a ZTR to the line-up... I had looked pretty seriously about 2 months ago at exmark$$ , ferris (mid range), gravely (best price) all 60" pretty much commercial quality from all.
I'll be mowing 4+ acres and need to look at all I can find in the 60" variety used or new..
   / ZTR Choices #3
</font><font color="blue" class="small">( Had it been 52" vice 50" I'd have chosen this one.
)</font>
Seems to me like you are over analysing this if your making a decision based upon 2".
   / ZTR Choices
I just finished my third mowing session with my JAZee last night and I continue to be all around VERY satisfied with my selection.
The time to mow by 3.5 acres has gone from about 3.5 hours to about 2 hours.
Cut quality is much improved over my 5-year old Craftsman GT and is every bit as good at either of my neighbors. One has a 62" Commercial-level Toro and the other has a 61" Scag Turf Tiger.
For my first mowing the grass was a bit longer than I usually let it get (maybe 6"). The JAZee handled it at up to top speed without complaining. Clipping dispersion was as even on this first mowing as it has been on two subsequent mowings of shorter, less "juicy" grass.
The mower comes with two springs supporting the seat and I found that my 250lbs caused the seat to bottom-out when I took some of the rougher areas of my yard at full speed. The mower also comes with a third spring in a storage location that I easily moved up to support the seat. The ride is now very comfortable at full speed throughout my yard.
I flipped up the deck (very easy to do) after the first mowing and found very little build-up. I have not yet flipped up the deck to check again because clipping discharge is still strong and even and a quick look down the discharge chute before starting doesn't show any build-up. I'll probably check, just for comparison, before my next mowing.
The joystick control is quite comfortable, responsive, and easy to get used to (at least going forward). I'm still getting used to it for backing up.
I have found that it's VERY easy to scuff the turf with the wheels when doing tight turns. I need some practice in that area.
In summary, I'm pleased with my Country Clipper JAZee. It was the right choice for me.
   / ZTR Choices #5
Bill, Thanks for the info ,you have covered all the bases with your feed back,I guess with the joystick control you can make use of the cup holder with the free hand /forums/images/graemlins/grin.gifThanks again and happy mowing /forums/images/graemlins/confused.gifmowings not much fun but at least a new piece of equipment may make it easier for awhile /forums/images/graemlins/cool.gif
   / ZTR Choices
Funny you should mention the cup holder - that's the one thing I'm not 100% satisfied with.
It's not very deep and when I tried using it for a 1/2 Liter bottle of water the bottle got bounced out pretty easily.
I think maybe a beer can coozie around the water bottle might help hold it better.
   / ZTR Choices #7
Another ztr choice! I just examined a Hustler SUPER Z! I liked very much what I saw the 27hp kohler has an oil cooler mounted on the back of the engine also the rear wing just above engine has an auxilary hydraulic fluid cooler under the wing with an electric fan blowing on it(cooler=longeivity)also a large hydraulic filter ,It also has the weight adjustable seat for driver comfort (test drive proved it).
Lastly it is the fastest on the market @ 15 mph not that it would make the difference in cut quality or decision making as all the ztr's are fast (wanna race?)
The pumps look to be larger than most comparable units on the market and have steel lines for most of the flow of fluids,
and the price is quite attractive a 60" is $7k
Anybody seen them or own one yet? /forums/images/graemlins/cool.gif
Any problems with it?
2018 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2018 Ford F-150...
Husqvarna YTH 18542 Riding Mower (A53117)
Husqvarna YTH...
2011 RAM 2500 (A53843)
2020 FREIGHTLINER CASCADIA 126 TANDEM AXLE SLEEPER TRUCK (A52141)
2020 FREIGHTLINER...
Mini Excavator (A52377)
Mini Excavator...
Suzuki Kingquad 700 ATV (A53117)
Suzuki Kingquad...
