I have mine and one that I had sent to me that someone replaced, & have disassembled them for inspection, there are no o-rings on the SPOOLS to seal them only tight fit, (but the fit is not to good for low visc hyd flid as factory use the ole 30 weight oil) the hyd oils are thinner and flow around the spools so the FEL leaks down faster than most.
Yes, you are right, but there are two o-rings(on each spool opening) one at the top and one at the bottom. They are allowing fluid to pass by(leak out). I guess the hole in the bottom is for allowing the fluid to leak by.
now it almost sound like you were talking kits for the FEL cylinders?
Have not proved it but that is probably right. I guess they should be marked that way.
or the relief valve. the relief valve can be worked on, as there may be seals in that I took mine apart so long ago that I forget if there are any there or not?
Just saw where you can order the refiefvalve. BUT If I could get itto come apart, it might save some money and fix that leak. It seams to be the worst.
,,,,,James
