ZG227 Mower Question--Brake Pedal and Starting/Running And Stepping off with Brake On
   / ZG227 Mower Question--Brake Pedal and Starting/Running And Stepping off with Brake On #1
TxDoc
Wamba, TX
Kubota ZG227, wanting BX25D
I've got a ZG227 mower. While under warranty, I had intermittent problems with starting and while holding the brake pedal or having the brake pedal locked while starting.
They said they were not sure what the problem was, but thought they got it fixed. That was during mulching season here, Winter, to many of you
After warranty ran out (I did buy the extended insurance, but don't think this qualifies), the problem has recurred.
If I cannot get it to turn over, with the brake pedal locked, I must release the brake from being locked and tap, tap, tap the brake until it finally starts to fire, and I can roll. I had envisioned a simple switch that the pedal pressed on under the deck, but that was wrong!
I am really not sure how that mechanism actually works. Maybe that is why the dealer said it was not easy to run down. I have a shop manual, but don't have hours to try and see if there is a switched involved in some way and if I just need to order it and install it?
While I have some folks who might know, I wanted to ask this question, with two parts. I thought I had read this was true, but I may have only had a bad dream.
1-I can press on the seat and start the mower and let it warm up while I get ready to mow. It will start and run. BUT, if I am mowing, and disengage the blades, lock the parking brake, and push the control bars out to the side, and get off the mower, it will die. If it will start and run with me off, why wouldn't it do so when the controls are essentially in the same configuration while mowing and stop?
2-Do you have to be on level ground to START the mower or KEEP it RUNNING when you get off, as described above in the first part?
I appreciate any suggestions, questions, ideas, or opinions
Auger Skid Steer Attachment (A50322)
Auger Skid Steer...
Excavator Bucket (A50514)
Excavator Bucket...
John Deere 2700 Mulch Ripper (A50514)
John Deere 2700...
2011 Ford F150 (A50515)
2011 Ford F150...
24' Free Standing Panel with Swing Gate (A50515)
24' Free Standing...
2008 GMC C7500 Altec LRV55 55ft Forestry Bucket Truck (A50323)
2008 GMC C7500...
