Zetor 7245
   / Zetor 7245 #2
They are a pretty standard split.
This tractor has a dual clutch with the PTO disc captured in the PPA so I would just replace both at the same time.
   / Zetor 7245 #3
Hi and welcome to the forum. :wave:
I'm going to move your thread on over to the Zetor section. Best of luck with that clutch!
   / Zetor 7245 #4
Be sure your master cylinders are not bad... most of the time with Zetor you just need a new master cylinder and a good purge of air to fix your problem.. iv rarely seen a zetor clutch actually burn up.. and been around them for a very long time
New Power Line 500 Metal 3pt. Spin Spreader (A50774)
New Power Line 500...
2005 Kobelco 135SR Hydraulic Excavator (A50322)
2005 Kobelco 135SR...
2019 KENWORTH T680 TANDEM AXLE SLEEPER (A52576)
2019 KENWORTH T680...
2013 Toyota Prius Hatchback (A50324)
2013 Toyota Prius...
2 Axle Deckover Trailer (A50774)
2 Axle Deckover...
2022 Bobcat T66 (A50120)
2022 Bobcat T66...
