Zetor 6745 power steering fluid
   / Zetor 6745 power steering fluid #1
shanehobson
New Zealand
Ford 3000 (x2), Kubota F1900, Kubota B2150HST, IH434, Same Minitauro 60, Zetor 6745 (x2)
My Zetor 6745 steering doesn't feel very good so I checked the power steer fluid reservoir (sitting in front of the radiator).
It appears to have a red fluid in it, which is very low.
Could this be Dextron ATF fluid ?
My other 6745 has a clear fluid in the same reservoir. It could be clean STOU.
Can anyone tell me which fluid I should be using ?
Where do I drain, refill power steer fluid ?
Is there a filter that should be replaced ?
Thank you
Shane
After a lot of reading this is what I've found.
The Zetor power steer can use either ATF or STOU.
ATF is preferred as it's viscosity remains constant when outside temperature changes. STOU tends to get thicker in cold weather making the power steer less responsive.
There is a simple metal screen and a large magnet built into the filler cap. The return fluid flows through this screen and magnet before dropping into the tank.
The 6745 with STOU in the power steer is used solely for my hay baler, so never sees cold weather. So I'll likely just top up the STOU.
The 6745 with ATF in it is my year round tractor, so I'll top it up with ATF.
On both tractors I will paint onto the top of the power steer tank the fluid type that it is filled with.
2007 Bomag BW120AD-4 Tandem Vibratory Smooth Drum Roller (A52377)
2007 Bomag...
UNUSED 40' CONTAINER (A51248)
UNUSED 40'...
UNUSED AGT SA-FT HYD PALLET FORKS (A51248)
UNUSED AGT SA-FT...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A52377)
2019 Allmand...
SCAN FOR HAULING AND FINANCING INFORMATION (A51247)
SCAN FOR HAULING...
2019 Doosan LCV6W Towable LED Light Tower (A51691)
2019 Doosan LCV6W...
