Zetor 5211 Battery
   / Zetor 5211 Battery #1
pratera
My factory battery went out a few years ago and since then I can't seem to find a suitable replacement, no battery has lasted six months on my tractor. I'm not sure what size to get and only use the tractor once a month or so. Any suggestions for battery size/ type or how to make them last longer?
   / Zetor 5211 Battery #2
Car batteries are too small for the 4hp starter motor. Get one from a big rig.
Are you sure its the battery, not the alternator ?
Not 100% but the old battery lasted nearly a decade, tractor only gets used about once a month so I think it develops a memory when it gets low. Anyone know any inexpensive heavy duty diesel batteries? The one that used to be on it cost over $300
   / Zetor 5211 Battery #4
You got a short
I use the Walmart batteries. $75 or so and they last.
If its super cold I plug it in or use ether.
2018 FORD F-150 (A50854)
2018 FORD F-150...
2017 Bad Boy Outlaw XP 61in Zero Turn Mower (A48082)
2017 Bad Boy...
2020 KENWORTH T680 TANDEM AXLE SLEEPER (A51219)
2020 KENWORTH T680...
Drill Bit attachment (A50322)
Drill Bit...
2011 IC Corporation PB105 School Bus (A49461)
2011 IC...
2009 JACK COUNTY 130 BBL VACUUM  TRAILER (A50854)
2009 JACK COUNTY...
